POV-Ray : Newsgroups : povray.pov4.discussion.general : Next Generation SDL: What's wrong with Lua, JavaScript, ... : Re: Next Generation SDL: What's wrong with Lua, JavaScript, ... Server Time
7 Apr 2026 21:10:38 EDT (-0400)
Date: 12 Apr 2009 07:50:00
Message: <web.49e1d52de7a64ad8addfbead0@news.povray.org>
"clipka" <nomail@nomail> wrote:
> But even then I must say that I'd actually not like the syntax -
> for POV needs, it would mean an unreasonably large number of
> braces-inside-parentheses "({ ... })" where only one type of
> brackets would suffice; and a host of "new" statements which -
> as proven by current SDL - shouldn't really be necessary.
> Not to speak of all the colons (":").
There's always the option of inserting a pre-processor into the pipeline, which
could assume new objects if an object class is supplied, or existing objects if
its reference is supplied; no need for "new" in the user's SDL source. The
properties would have obvious "property value" construction.
My overall thought is that we could use existing language parsers/compilers, to
take advantage of the superior structuring, and pre-process any POV object
definitions into that language, so that users can create appropriately precise
SDL source.
p.s. I might be confusing some Java concepts with JavaScript concepts, thinking
in particular about the class structuring that JavaScript might not support -
apologies for that; I learned [sic] the two at around the same time. Even so,
then
