POV-Ray : Newsgroups : povray.pov4.discussion.general : Addressing the secrete rotation in text{} object : Addressing the secrete rotation in text{} object Server Time
29 Mar 2026 14:12:24 EDT (-0400)
Date: 13 Mar 2025 14:05:31
Message: <67d31e6b$1@news.povray.org>
In an offline email exchange with jr, I drifted off into a discussion
(OK, it was more of a monologue) about how the text{} object has a
secrete rotation to avoid axis aligned numerical issues. The rotation is
the equivalent of a user specifying - always - 'rotate
<0.001,0.001,0.001>' on text{} objects.
It's something that was added to the parse code at some point. It's
there in v3.7 - probably earlier versions too. The v3.8 source added a
TODO note about trying to find some better approach.
For the next release of the yuqk fork (R19) I've currently reduced the
rotation to: 'rotate <0.0001,0.0001,0.0001>' as a longer trial, but I'm
having second thoughts (*).
After setting up some more formal test code, I'm left unsure of the best
way to proceed - in no small part because I don't know what really
caused the issues for which the patch was applied. If anyone remembers
anything, please pass it along.
I'm starting to think pulling the patch altogether might be a better
long trial. A user can always add the rotation. In fact, likely a
cleaner, more minimal rotation about just the z axis) when artefacts
show up.
Attached is an image and a yuqk scene file where I've set the thickness
of the text objects at 1e-6; Artifacts show up even at a thickness of
1.0. The rotation is effectively another issue that can bite or not
depending on many things. Centering the text{} object about the origin
lessons the chance the secret rotation will cause a problem.
The left render shows the result for the current secrete rotation of
<0.001,0.001,0.001>.
In the middle no secrete rotation is applied.
On the right, the current R19 rotation of <0.0001,0.0001,0.0001>. It
helps, but I think not in a way that really addresses the issue and, who
knows, maybe it's not large enough for the situation for which the patch
was added.
Bill P.
(*) - Another thing I played with was to add a counter / inverse
rotation in SDL to the secrete one in an attempt to get back to no
rotation. While it sometimes works, there is too much numerical noise in
rotating and un-rotating (on combining the two opposing matrices). The
overall results were less stable.
Download 'textsecreterotation.jpg' (22 KB) Download 'textsecreterotation.pov.txt' (2 KB)
Preview of image 'textsecreterotation.jpg'
