POV-Ray : Newsgroups : povray.pov4.discussion.general : Missing close brace causing segfault in >v3.8 parser code. : Missing close brace causing segfault in >v3.8 parser code. Server Time
8 Apr 2026 18:00:56 EDT (-0400)
Date: 3 Oct 2021 12:23:25
Message: <6159d8fd$1@news.povray.org>
This issue affects my povr branch because in branched off of the updated
parser. Expect this issue in release which include the parser updates
(ie not the v3.8 release or earlier).
See: https://github.com/POV-Ray/povray/issues/439
Two examples where the parser should catch the still being defined
function state and suggest a missing brace as the cause:
// povray +mv3.8 +iScalarFunction_missedBrace.ini
// Missing close brace causing seg fault with v4.0(master) parser updates?
#declare Fn = function {pattern {bozo
}   // <--- Missing close brace }
#declare Vn = Fn(1,2,3);
#debug concat("\nVn = ",str(Vn,1,3),"\n\n")
#error "Parse Test. Stop early"
or
// povray +mv3.8 +iVectorFunction_missedBrace.ini
#declare Fn = function {pigment {bozo
         color_map {[0,rgbft 0][1,rgbft 1]  // <-- missing }
#debug concat("\nVn = ",vstr(5,Vn,",",1,3),"\n\n")
Bill P.
