POV-Ray : Newsgroups : povray.pov4.discussion.general : Ideas. Updated f_wood(). povr branch. : Re: Ideas. Updated f_wood(). povr branch. Server Time
27 Mar 2026 10:39:36 EDT (-0400)
Date: 14 Sep 2021 09:37:00
Message: <6140a57c$1@news.povray.org>
On 9/13/21 11:47 AM, Alain Martel wrote:
> Very interesting. Mostly useful for wooden objects that are viewed from
> a relatively short distance.
Thanks. Mostly, Yes. :-)
> Is there any way to have undisturbed rings in the centre with the
> disturbance increasing as you get farther ?
First, to be clear, the turbulence in the previously posted image was
accomplished with two 'external' to f_wood() turbulence warps. One for
fuzz in the rings and another for the log level. The f_wood() function
doesn't have any inbuilt turbulence - unlike the traditional wood pattern.
In povr certainly a fade is possible, as the Turbulence(1) and vector
turbulence (DTurbulence) functionality of POV-Ray is brought out as
inbuilt functions.
If not using that sort of functionality... I think one could probably do
something like an inward black hole warp(2), apply turbulence, then an
outward black hole warp. Similar to scaling patterns up (or down) prior
to applying turbulence and then reversing it.
While, the fade used is the opposite you asked about, attached is a test
isosurface image based upon f_wood() where I'm using the ring count
value to fade the rings to nothing in height while moving out from the
center.
FWIW, the, povr only, core SDL for the isosurface is:
#declare Fn00 = function (x,y,z) {
      f_wood(0,f_hypot(x,z),Core,Width,Rings,Seed,Mean,Sigma)
#declare Fn01 = function (v) {
      f_distribution(7,// A triangle distribution. Wikipedia version.
          f_dec2x_f32(v,0),
          A,B,C,ReturnMode,nullArg
      )* ((f_dec2x_f32(v,1)*-0.0035)+0.059) // The fade to nothing.
#declare Iso99 = isosurface {
      function { abs(y)-Fn01(Fn00(x,y,z)) }
Bill P.
(1) - The povr branch has fixed the forever standing Turbulence()
octaves distribution mean drift issue.
(2) - The povr branch has a black hole type 1 without the clamping
and/or reaching outside the black hole radius issues of POV-Ray's
black_hole. The povr type 1 forms would likely be needed for other than
linear fading / strength 1.
Download 'iso00_f_wood.jpg' (286 KB)
Preview of image 'iso00_f_wood.jpg'
