POV-Ray : Newsgroups : povray.pov4.discussion.general : Run external code from : Re: Run external code from Server Time
15 Oct 2026 10:43:49 EDT (-0400)
Date: 18 Apr 2010 16:01:00
Message: <4bcb64fc$1@news.povray.org>
Am 18.04.2010 21:44, schrieb H. Karsten:
> ok it's possible to run external code before and/or after the rendering in
> PovRay.
> What if having a syntax to run it from inside the script like a macro
> #declare Result=external_code_lua("Path/Name",Arguments)
> #declare Result=external_code_python("Path/Name",Arguments)
> #declare Result=external_code_php("Path/Name",Arguments)
> #declare Result=external_code_perl("Path/Name",Arguments)
> #declare Result=external_code_java("Path/Name",Arguments)
> #declare Result=external_code_bin("Path/Name",Arguments) (using stdout as
> return-value)
> Think of it: depending on the language using, you can make PovRay
> object-orientated!
>  From my personal taste, I would like to use Lua. It's designed to be used inside
> other programs, or scripts. It's object-orientated, fast, free, opencource (I
> think its MIT-License) and small.
Would there still be a big benefit in that, presuming the POV-Ray 4 SDL
itself would be object-oriented and as fast as Lua or some such in the
first place (which I consider a prime goal for POV-Ray 4)?
