POV-Ray : Newsgroups : povray.pov4.discussion.general : POVRAY v4 SDL, Basic/Advanced/Intermediate : Re: POVRAY v4 SDL, Basic/Advanced/Intermediate Server Time
14 Oct 2026 20:49:05 EDT (-0400)
Date: 18 Nov 2009 21:44:51
Message: <4b04b123$1@news.povray.org>
Louis schrieb:
> Making a language easy is not really an issue, if it's too low level, someone
> will aether build a library or a simpler language on top of it.
> If you want something simpler, make your compiler that generates DSL. Just like
> a M$ Workflow diagram "gets compiled to" (generates) C#, which gets compiled
> into IL which at last gets compiled into a CPU instruction set.
> If you don't like keyboards, code with your mouse using a modeler :-)
It would be of quite some benefit to be able to share scene files and
include files between POV-Ray users, without needing to get half a dozen
or more different libraries, on-top languages and what-have-you-nots to
cooperate.
(Even if your suggested approach would be the way to go, it would not
change the fact that thought should be put into the design of the
language - if not how to make it easiest for users, then how to make it
most flexible for adding libraries or auto-generating code.)
