POV-Ray : Newsgroups : povray.pov4.discussion.general : GPU usage : Re: GPU usage Server Time
2 Jul 2026 02:08:24 EDT (-0400)
  Re: GPU usage
Date: 1 Jan 2009 19:21:43
Message: <495d5e16@news.povray.org>
Patrick Elliott wrote:
> This comes up about once a month. The practical answer is, "No, not
> really, since GPUs are optimized for the type of math that is used by
> scanline systems, not physics based raytracing, and their floating point
> systems are almost always using lower bit depth than the CPU of the same
> machine, so nearly everything POVRay does would fall in the category of,
> "Nope, the GPU can't do that, or if it did, it would produce results
> that are poorer than the FPU of the main processor."
Modern GPUs are very programmable; they aren't tied to scanline rendering
anymore. Ever heard of protein folding on GPUs?
Raytracing *can* be done in GPUs.
See http://www.clockworkcoders.com/oglsl/rt/
However it would be a HUGE amount of work to modify POV-Ray to run on CUDA /
OpenCL. Lots of algorithms would need to be rewritten from scratch, and a
few may be impossible.
