POV-Ray : Newsgroups : povray.pov4.discussion.general : GPU usage : Re: GPU usage Server Time
9 Nov 2026 13:18:15 EST (-0500)
  Re: GPU usage
Date: 31 Dec 2008 14:26:01
Message: <495bc749$1@news.povray.org>
Doom wrote:
> I was curious, with the OpenCL 1.0 spec, and also with ATI/AMD releasing
> open-source code now for utilizing the GPU processing power, could it be
> possible to utilize GPU acceleration within POV-Ray?  I know a lot of POV-Ray
> is CPU intensive and utilizing the threads in the GPU would drastically speed
> up render times.
> anyones thoughts?
This comes up about once a month. The practical answer is, "No, not
really, since GPUs are optimized for the type of math that is used by
scanline systems, not physics based raytracing, and their floating point
systems are almost always using lower bit depth than the CPU of the same
machine, so nearly everything POVRay does would fall in the category of,
"Nope, the GPU can't do that, or if it did, it would produce results
that are poorer than the FPU of the main processor."
Now, if you didn't mind getting "poorer" quality, and the *slight* speed
increase you might get from it was worth it... maybe. But, unless its
enough to give you real time, its not worth the effort, since the only
reason you might want to downgrade the results, to get better
performance, is as a game engine. And actually, I kind of wish you could
do that. I am getting seriously tired of things like the layers alpha BS
in Second Life, which a raytracer would never have in the first place. lol
void main () {
   If Schrödingers_cat is alive or version > 98 {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
