POV-Ray : Newsgroups : povray.pov4.discussion.general : comma at end of last element in list : Re: comma at end of last element in list Server Time
18 Mar 2026 17:07:50 EDT (-0400)
Date: 15 Oct 2008 15:30:04
Message: <48f644bb@news.povray.org>
Trevor G Quayle <Tin### [at] hotmailcom> wrote:
> [-- text/plain, encoding 8bit, charset: iso-8859-1, 14 lines --]
> Dan Connelly <djc### [at] yahoocom> wrote:
> > What I'd like to see is an allowed comma at the end of the last element in a list.
 This would facilitate the populat
> ing of lists from within a loop.  There's now the need (AFAICT) a silly check for
the last element to omit the comma.
> > Dan
> Usually I workaround by adding the comma before the number, that way there is no
> comma at the end of the list.  This works usually because most items that I have
> created that use lists (meshes, splines, polygons) have a float preceding the
> list, usually the number of items conatined in the list.
  Also you could skip using commas completely. Just put your elements in
parentheses (to avoid ambiguity in situations like "2 -1") and you don't
need commas at all.
