POV-Ray : Newsgroups : povray.pov4.discussion.general : rounded intersections? : Re: rounded intersections? Server Time
5 Apr 2026 12:54:01 EDT (-0400)
Date: 2 Oct 2008 11:54:57
Message: <48e4eed1@news.povray.org>
scott <sco### [at] scottcom> wrote:
> That's only to render quickly though, internally all surfaces are stored as
> mathematical descriptions.  In theory you could write a raytracer to render
> these surface descriptions directly with no tesselation.  In fact, if you
> create a shape with rounded edges in a CAD program, you can export it to a
> common interchange format (STEP) which is plain text.  In that you will see
> that the solid is completely defined by mathematical curves and surfaces, no
> tesselation.
  That doesn't change the fact that the CAD software tesselates the surface
before rendering it. Or have you seen one which doesn't?
