POV-Ray : Newsgroups : povray.pov4.discussion.general : rounded intersections? : Re: rounded intersections? Server Time
31 Mar 2026 02:39:16 EDT (-0400)
Date: 1 Oct 2008 06:09:25
Message: <48e34c55@news.povray.org>
>  Their problem is that automatically creating rounded corners for any
> given object:
> 1) is impossible in the general case,
> 2) in many cases where it's possible it results in extremely slow renders,
Those first two are not really problems though - ie we shouldn't say not to
include a feature because it won't work with all possible objects and might
result in extremely slow renders sometimes.
> 3) would require tesselating the object and rendering the resulting mesh
>   (with the corner modifications).
That's not the only way to do it.
>  POV-Ray, however, handles mathematical primitives (such as boxes and
> planes) and their CSG. Rounding their corners is a problem which is
> several orders of magnitude harder.
But not impossible, look at any CAD software that manages it with
mathematically defined CSG.  The problem I see with POV, is how to specify
which edges you want to be rounded, so far we have no way of specifying
edges in the SDL.
I have no idea how CSG objects are stored internally in CAD software, but at
each stage of the CSG you can somehow specify edges and faces etc to apply
rounds and chamfers to.  I don't know how you would attempt to replicate
this in a text-based way.
Internally, the POV engine would need to see what faces were connected to
the specified edge, and remove/generate the correct geometry to round that
edge.
