POV-Ray : Newsgroups : povray.off-topic : musical notation font Server Time
2 Jul 2025 14:24:19 EDT (-0400)
  musical notation font (Message 30 to 39 of 39)
Subject: Re: musical notation font
Date: 18 Jun 2018 12:38:48
Message: <5b27e018$1@news.povray.org>
Am 18.06.2018 um 17:07 schrieb jr:
> hi,
> Le_Forgeron <jgr### [at] freefr> wrote:
>> You would like support of unicode 1D100...1D1FF like in freeserif
> I wrote a little test scene to see but cannot access that range.
> the docs (3.3.1.9.4 + 3.3.2.7.2) specify a 64K limit on the chr() function, as
> well as for the corresponding literal ("\uNNNN").
> how does one access font glyphs located after the limit?
At present you simply can't: POV-Ray's innards have never grown beyond
the old UCS-2 standard (yet); in other words, it only supports
characters from the Basic Multilingual Plane, period.
Here are the key components that have to be changed to get there:
(1a) The `\uNNNN` escape sequence has to be extended to allow for 6 hex
digits; in the current parser update, I'm implementing this as
`\Unnnnnn` (note the uppercase U); or
(1b) the `\uNNNN` escape sequence has to be re-defined to specify UTF-16
code units (rather than UCS-2 code points).
(2) The internal string representation in the parser has to be changed
from UCS-2 to /something/ else; I'm leaning towards UTF-32 encoded UCS-4
because it means keeping string length related stuff simple and
unambiguous. (This would also extend the numeric range of the `chr()`
and `asc()` functions.)
(3) The TrueType handling code needs to be extended to look for `cmap`
types 0/4 and 3/10 (currently: 0/3, 1/0, 3/0 and 3/1), and support
`cmap` format 12.0 (currently: 0, 4 and 6).
Date: 18 Jun 2018 19:20:20
Message: <5b283e34$1@news.povray.org>
My goto resource for this sort of thing is LilyPond
(http://lilypond.org/), an open source music typesetting program.
 From what I can see there's a "Feta" font included with it
(http://lilypond.org/doc/v2.19/Documentation/notation/the-emmentaler-font),
presumably in OpenType format, although maybe you could convert to TT
yourself.  I also found links to these other music fonts, also not in TT
format as far as I know, but again maybe you can convert:
https://www.chiark.greenend.org.uk/~sgtatham/gonville/
http://www.smufl.org/fonts/
On 6/16/2018 4:42 AM, jr wrote:
> hi,
> I'm looking for a TT font that has all/many notes and other musical notation
> symbols.  must be free to use, recommendations please.  thanks.
> regards, jr.
Date: 18 Jun 2018 20:39:06
Message: <5b2850aa$1@news.povray.org>
>> hi,
Doesn't preclude the need for full plane 0+ support, but I'll mention a
few years ago I was playing in POV-Ray with Egyptian hieroglyphs in
particular - as well as a couple other plane 1 and plane 2 fonts.
Using the AegyptusSubset.ttf at:
https://mjn.host.cs.st-andrews.ac.uk/egyptian/fonts/newgardiner.html
I could render the 13044 human with club/staff character with:
#declare Text00 = text {
     ttf "AegyptusSubset.ttf" "\uE044"
     0.1, 0
     pigment { color Color00 }
     translate <0,0,-0.05>
     no_shadow
In other words, while I never worked out how it works, once you find the
'wrapped' base hex value you can index from there so long as working
with an extracted font with just the plane 1 or 2 values. I was already
working with font subsets of plane 1 and 2 so unsure how to extract just
plane 1 or plane 2 from a font with plane 0 too. A potential hack to get
at planes 1 and 2 today - for what it's worth I guess.
Bill P.
Date: 19 Jun 2018 02:57:24
Message: <5b28a954$1@news.povray.org>
Am 19.06.2018 um 02:39 schrieb William F Pokorny:
Actually that's still accessing the BMP, and it's not a hack but a
feature of that particular font: Since it only deals in hieroglyphs, it
can provide a mapping of all its glyphs into the Private Use Area of the
BMP (U+E000 to U+F8FF).
"Complete" fonts do not have this luxury, as the currently assigned code
points outside the BMP far exceed the 6400 code points of the BMP
Private Use Area.
Also, even specialized fonts are not required to provide such a Private
Use Area mapping.
Even if a font provides a PUA mapping, the mapping may be systematically
different from the officially assigned mapping outside the BMP. For
example, the PUA mapping might reflect an experimental mapping predating
official inclusion into the Unicode standard.
And last not least, applications dealing with UCS characters are free to
use Private Use Area code points for special purposes, so there's no
guarantee that future versions of POV-Ray will continue to provide full
support for this mechanism; for instance, in overhauling the parser I
was (and still am) toying with the idea of setting aside 128 of those
code points to internally represent non-ASCII octets from source files
for which the character encoding is not (yet) known; such code points
would be translated "back" by a later stage of the parser, even if they
happen to have been entered via "\uNNNN".
Date: 19 Jun 2018 05:00:00
Message: <web.5b28c5789973151b635cc5ad0@news.povray.org>
Kevin Wampler <nob### [at] nowherenet> top posted:
I've no s/ware to convert to TTF, but thank you.
jr.
Date: 19 Jun 2018 08:26:59
Message: <5b28f693$1@news.povray.org>
> Private Use Area.
> Use Area mapping.
Thanks much for the explanation. It means too I was likely working with
extracted font bits mapped differently. The other extracted fonts at the
time didn't have the offset to U+E000, but rather acted like plane 0
fonts in total though they came from planes 1 and 2.
Bill P.
Date: 19 Jun 2018 09:15:01
Message: <web.5b2901049973151b635cc5ad0@news.povray.org>
hi,
there is a current thread on comp.lang.c which discusses this issue, subject
"fixed width unicode subsets".
regards ,jr.
Date: 19 Jun 2018 12:00:02
Message: <5b292882$1@news.povray.org>
Am 19.06.2018 um 15:12 schrieb jr:
> hi,
Related, but (judging from a semi-cursory glance) nothing new to me in
there.
I know the how-to. What I need is a couple of round tuits.
Date: 17 Jul 2018 19:50:01
Message: <web.5b4e7fd49973151b458c7afe0@news.povray.org>
Just serendipitously found this:
https://web.archive.org/web/20080514063612/http://home.pacbell.net/tylereng/musical.zip
as part of:
https://web.archive.org/web/20080514063612/http://home.pacbell.net/tylereng/index.html
Date: 17 Jul 2018 19:54:50
Message: <5b4e81ca@news.povray.org>
Wow, that is impressive!
>> hi,
>> notation
>> regards, jr.
