POV-Ray : Newsgroups : povray.off-topic : GRAVITY the movie-- some observations Server Time
17 Apr 2026 00:45:33 EDT (-0400)
  GRAVITY the movie-- some observations (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: GRAVITY the movie-- some observations
Date: 20 Jan 2018 05:38:26
Message: <5a631c22$1@news.povray.org>
Am 19.01.2018 um 23:40 schrieb Kenneth:
> If that's true, then one of the main 'set pieces' of the film-- the orbiting
> space station being destroyed by fast-moving debris hitting it-- seems
> unnatural. Wouldn't that debris naturally be in some different orbit, because of
> its different speed? (Unless the debris was from an explosion-- blasting out in
> all directions from some particular orbit.) I don't remember if such an
> explosion was the cause.
Yes, such an explosion was indeed the cause. IIRC that explosion in turn
was caused by another collision.
Date: 20 Jan 2018 11:10:01
Message: <web.5a63699f9c546dbda47873e10@news.povray.org>
> But you can have circular orbits, elliptical orbits, and you also have
> 360-degrees of rotation around both orthogonal axes - so you could
> be travellingat 70,000 mph in one direction, and get t-boned, or hit by
> an object head-on in the "oncoming lane".
Yeah, I completely forgot about those little facts; there are an infinite number
of 'great circles' around the Earth for any given orbit... as well as their
reversed directions!
> It depends on the mass.  Two equal masses [w][c]ould occupy the same orbit.
Like Clipka says, I think the different masses of the various objects (in the
same orbit) can be ignored. Let's say there are two objects: the U.S. Space
shuttle, and an apple(!) I'm guessing that both can be launched into the same
orbit, given the correct trajectories and forces. Assuming both are in nicely
circular orbits, they are actually 'falling' around the Earth. Neglecting air
resistance, any two objects 'fall' at the same rate, regardless of their masses.
(The old Galileo experiment, from the Tower of Pisa.) So it follows that the
Space shuttle and the apple-- in the same orbit-- are going at the same speed or
velocity. (If their speeds were different, one would head further off into
space-- attaining a higher orbit, or maybe a more eccentric one?)
I find that it's far more fun to CONJECTURE about things than to actually look
up the facts  :-P  Just like the ancient Greeks! (Well, they did OK with
geometry, I guess...)
Date: 20 Jan 2018 11:41:45
Message: <5a637149$1@news.povray.org>
But not that great with Irrational numbers or beans. ;-)
Regards
Date: 21 Jan 2018 11:37:29
Message: <5a64c1c9$1@news.povray.org>
The main thing that bothered me was that Clooney basically tells Bullock
to point directly toward the Chinese module and hit the gas.
But:
1. Isn't it really hard to move between two locations in a straight line
in Space, so close to a large body such as the Earth? Aren't successful
orbital maneuvers really complicated, time-consuming and hard to pull off?
2. Wouldn't it take a really long time to cover the distance between two
space stations at the rate she was moving in her suit (e.g. slow enough
so she could stop herself by grabbing on with her hands, IIRC)? Or do
space stations typically live within a few kilometers of each other?
Never got to see the movie in imax.
Mike
Date: 21 Jan 2018 12:04:04
Message: <5a64c804$1@news.povray.org>
> But:
I think the real problem is that orbital mechanics is not cinema
friendly. The public expect (from their experience on Earth) that if you
accelerate towards an object you get closer, quicker in a straight line.
Not that your orbit will get higher or lower. That is what stopped me
watching any of the Star Wars follow ups.
Regards
Date: 21 Jan 2018 12:11:37
Message: <5a64c9c9$1@news.povray.org>
Well, that's not fair, since in Star Wars the space ships have very very
powerful engines. If you have a powerful enough engine, you can make a
house fly in a straight line.
Mike
Date: 21 Jan 2018 12:33:05
Message: <5a64ced1$1@news.povray.org>
>> you accelerate towards an object you get closer, quicker in a straight
>> line. Not that your orbit will get higher or lower. That is what
>> stopped me watching any of the Star Wars follow ups.
Fair or not it broke my sense of disbelief. Pedantic moi?
But then I'm not a great movie fan.
Regards
Date: 26 Jan 2018 12:02:20
Message: <5a6b5f1c@news.povray.org>
Which remind me of a curiosity: if the apple goes faster, it goes
higher... and performs then less revolutions than the station.
When you're a satellite, if you want to move ahead of another one, you
need to SLOW to be able to jump from behind to the front.
Date: 27 Jan 2018 07:06:51
Message: <5a6c6b5b$1@news.povray.org>
I wish someone had told the Star Wars makers, that fact.
Regards
Date: 28 Jan 2018 08:49:43
Message: <5a6dd4f7$1@news.povray.org>
Am 26.01.2018 um 18:02 schrieb Le_Forgeron:
Actually it depends how quickly you want to achieve this maneuver. If
you're in low earth orbit, have plenty of time on your hand, and/or have
a large distance to catch up, you may indeed want to decelerate in the
current direction of travel, wait for the peculiarities of orbital
mechanics to carry you the desired distance ahead, and then re-inject
into the original orbit, as it's probably the most fuel-efficient maneuver.
However, such a maneuver requires at least one full orbital revolution
to complete. Even in low earth orbit, that's about 1.5 hours.
Also, I guess the precision for such a maneuver may be comparatively low.
If you want to achieve the maneuver faster, you need to accelerate more
downward or even forward. For instance, in the final phase of docking
two spacecraft, orbital maneuvering is actually pretty intuitive.
