POV-Ray : Newsgroups : povray.off-topic : Technical Support Server Time
17 Apr 2026 06:57:11 EDT (-0400)
  Technical Support (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: Technical Support
Date: 10 Sep 2015 23:57:58
Message: <55f25146$1@news.povray.org>
On 9/9/2015 6:03 PM, Anthony D. Baye wrote:
> So I told my sister that I'd fix her laptop for her before she moves to take up
> a new job.  It's a fairly simple problem: Her hard drive is corrupted and
> Windows hasn't been able to finish an update for about a year, maybe a bit more.
> That doesn't stop it from trying every time you turn the machine on.  And then
> it needs to revert the changes on the next startup, because it can't finish the
> update...
> Well, obviously, the solution is to replace the hard drive, but then the laptop
> is a brick until I install an OS.  She's not savvy enough to use linux, more's
> the pity, and a new copy of windows costs an arm and a leg.  But hey, I should
> be able to call Fujitsu and have them send me a recovery disk (Why this isn't
> included with the laptop in the first place is absolutely incomprehensible).
> Fujitsu wants $15 per disk (there are two, apparently) and $13 S&H which brings
> the total to $44 for two recovery disks...
> Naturally, I can only order them over the phone, which means divulging credit
> card numbers over the phone.  Not a good idea.  Never has been.  Never will be.
> So I figure I'll do the Smart Thing, and I get a burn card (pre-paid VISA gift
> card).  I use these all the time for shopping online, they work everywhere.  Or
> so I thought.  Fujitsu won't take my perfectly valid VISA gift card because it
> doesn't have a name on it.  They think that makes it "not a valid credit
> card"...?
> TL/DR
> Unless I can find a way to get Fujitsu to send me a system restore disk, I'm up
> Sh(# Creek without a paddle.  I suppose I could try making the laptop a
> Hackintosh, but my last attempt at that was stellarly unsuccessful.
> Regards,
> A.D.B.
There should be a sticker on the laptop case with your product key. You
should be able to use any Windows installation disk (for your version of
Windows), and then just plug in your product key when you're done
installing.
There's also a good chance the laptop has a recovery partition on the
hard drive. You should be able to boot into it and start the recovery
process.
I've only done this once or twice, so things may be different between
versions of Windows, so watch out.
Michael
Date: 11 Sep 2015 11:41:10
Message: <55f2f616$1@news.povray.org>
> installing.
That depends - sometimes the key only works with an OEM version of
Windows.  IIRC, there also are keys that only work with volume license
versions of Windows.
Jim
"I learned long ago, never to wrestle with a pig. You get dirty, and
besides, the pig likes it." - George Bernard Shaw
Date: 15 Sep 2015 02:15:30
Message: <55f7b782$1@news.povray.org>
>> installing.
> Jim
There is no OEM "version" of Windows. There are OEM licenses and retail
licenses, but the version of Windows remains the same, and installation
media should not matter.
Mike
Date: 15 Sep 2015 02:39:33
Message: <55f7bd25$1@news.povray.org>
> Mike
Over the years that I have owned a computer store I have sold 1000's upon
1000's of OEM versions of Windows.
So, yes, there are OEM versions. Are they different? Not at the core, the
base is the same, but the added gadgetry varies enormously.
Ger
Date: 15 Sep 2015 12:40:40
Message: <55f84a08$1@news.povray.org>
>>> You should be able to use any Windows installation disk (for your
>>> version of Windows), and then just plug in your product key when
>>> you're done installing.
>> Jim
And yet, it does (or at least, it used to).
I personally ran into problems using retail keys with MS Select VLA
subscription media, and OEM licenses with boxed media.
It's possible that MS has changed this since I last tried it (it's been a
while), but this absolutely used to be the case.
Jim
Date: 15 Sep 2015 12:44:42
Message: <55f84afa@news.povray.org>
>>> Jim
> a while), but this absolutely used to be the case.
As I said, it's been a while, looks like since Vista, this hasn't been an
issue.
Shows how much I use Windows. :)
Jim
Date: 16 Sep 2015 02:54:20
Message: <55f9121c$1@news.povray.org>
> issue.
I vaguely remember something similar from back in the Win95/98 days,
stuck at the "enter product code" page and it not accepting my code
because I had a volume key or something.
Date: 16 Sep 2015 11:58:33
Message: <55f991a9$1@news.povray.org>
>>>> retail licenses, but the version of Windows remains the same, and
>>>> installation media should not matter.
>>> been a while), but this absolutely used to be the case.
>> an issue.
I remember it with XP as well.
Which tracks with what I found S-ing TFW. ;)
Jim
Date: 16 Sep 2015 12:28:19
Message: <55f998a3$1@news.povray.org>
>> Mike
My mistake. Sorry.
Date: 16 Sep 2015 18:05:01
Message: <web.55f9e722ba1762402aaea5cb0@news.povray.org>
> >> Mike
> My mistake. Sorry.
So, supposedly, a person can use an OEM key with any retail disk... You just
can't, for some strange reason, download the ISO's from M$ with your OEM key.
http://lifehacker.com/microsoft-now-lets-you-download-windows-7-isos-with-a-v-1688039211
A.D.B.
