POV-Ray : Newsgroups : povray.off-topic : update, updates, updates Server Time
30 Mar 2026 01:32:47 EDT (-0400)
  update, updates, updates (Message 21 to 23 of 23)
Subject: Re: update, updates, updates
Date: 18 Jan 2013 14:34:38
Message: <50f9a3ce$1@news.povray.org>
> (I suppose that if you use a signed *long* in a 64-bit system where longs
> are 64-bit, then expanding a signed 32-bit int to such a signed 64-bit long
> will result in the wrong value. But was that the case here?)
While this one
(http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2008-0894) didn't use
negative offsets, only out of bounds indexes that weren't checked by the
programmer.
This one, did use negative indexes:
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2008-0986
More details: http://cxsecurity.com/issue/WLB-2008030020
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 18 Jan 2013 14:48:06
Message: <50f9a6f6$1@news.povray.org>
> clipka <ano### [at] anonymousorg> wrote:
>> Okay, let's do it a bit more specific:
>>     void fubar(int idx)
>>       char c[1024];
>>       if (idx < 1024)
>>         fnord(c[idx]);
>>       else
>>         FAIL_SAFE();
>>     void main()
>>       fubar(INT_MAX+1);
>> No out-of-bounds access? Look at the code again.
> But in the original post it was suggested that an array size of INT_MAX+1
> in the image file could cause this. Here the array size is just 1024 (which
> in this particular contest would have ostensibly been read from the image
> file.)
I was going from memory.  Sorry about that.  It's not the array size
that's too big.  Just accessing elements outside of it.
> Unless there's an image file where there are actual index values specified.
Bingo.
FWIW, there's a group at the University of Oulu
(https://www.ee.oulu.fi/research/ouspg/), next door to you, who do this
all day long.  Try to break devices by sending specially crafted packets
that don't respect the protocol specs.  They were really famous for a
while in 2002, when they found out that every single device from every
single network equipment vendor was vulnerable to denial-of-service
attacks using SNMP.
Date: 21 Jan 2013 03:23:24
Message: <50fcfafc$1@news.povray.org>
> The only situation that I can think of where an out-of-bounds access will
> probably happen is if pointers (and thus array indices) are 64-bit but
> the array size is wrongly a signed (32-bit) int. It then gets expanded
> to 64-bit when indexing the array, and ends up truly at negative addresses
> (from the array's start.)
You could also have the situation where the code is inconsistent
regarding signed and unsigned (32-bit) values. Couldn't something like
this break with a negative value of imageSize stored in the image file?
void LoadImageFromFile(unsigned int size);
void ReserveMemory(int size);
int headerSize = 1024;
int imageSize = readIntFromFile();
ReserveMemory(headerSize + imageSize);
LoadHeaderFromFile(headerSize);
LoadImageFromFile(imageSize);
