POV-Ray : Newsgroups : povray.off-topic : update, updates, updates Server Time
23 Mar 2026 17:01:58 EDT (-0400)
  update, updates, updates (Message 11 to 20 of 23)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Re: update, updates, updates
Date: 18 Jan 2013 09:38:11
Message: <50f95e53$1@news.povray.org>
> On 16/01/2013 11:59 AM, Kenneth wrote:
>> Wow, it seems that security updates for various pieces of 'standard'
>> Windows-related software are coming down fast and furious these days:
>> Firefox,
>> Java, Flash Player, Windows itself (well, my old XP version.) I'm
>> getting one or
>> the other of these on almost a daily basis. Cyber-criminals and
>> spammers must be
>> working overtime!
> Just because a security flaw has been discovered, does not necessarily
> imply that anybody has actually *exploited* it yet.
> It could well just be the QA people doing code reviews and finding bugs
> that way.
QA people?  You mean the one guy in India who quit last month and can't
be replaced because there's a hiring freeze because the 3rd quarter
results weren't good enough?
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 18 Jan 2013 10:54:48
Message: <50f97048@news.povray.org>
Francois Labreque <fla### [at] videotronca> wrote:
> > Orchid Win7 v1 <voi### [at] devnull> wrote:
> >> There appears to be plenty of software that incorrectly treats various
> >> size values as signed integers. (E.g., programs that malfunction on
> >> files larger than 2GB because they think the file size has become
> >> "negative".)
> > Can you give me a scenario where that produces a buffer overflow?
> http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2008-0894
That didn't really answer my question.
Date: 18 Jan 2013 10:58:51
Message: <50f9713b@news.povray.org>
> In the case of the BMP flaw, the leaked Windows 2000 source code showed
> that the DLL was using a signed int to read an offset value that was
> unsigned in the file format, so by crafting a special BMP file you would
> have the DLL jump to a negative offset, and outside of the actual data
> structure it was supposed to read.
In 2's complement representation MAX_INT+1 has the exact same bits in
both signed and unsigned forms. How do you get outside the array with
that value?
(I suppose that if you use a signed *long* in a 64-bit system where longs
are 64-bit, then expanding a signed 32-bit int to such a signed 64-bit long
will result in the wrong value. But was that the case here?)
Date: 18 Jan 2013 12:07:27
Message: <50f9814f@news.povray.org>
Am 18.01.2013 16:58, schrieb Warp:
> that value?
That's wrong. In 2's complement representation, MAX_INT+1 has NO bit
representation at all. What you get instead if you interpret the
respective unsigned representation as signed is MIN_INT.
So take an array with a limited size, an "int" as an index into that
array, a check whether that index into that array is smaller than the
array's size - and you have the recipe for a stack overflow or similar
(unless you also remember to check whether the index is non-negative).
Date: 18 Jan 2013 12:47:00
Message: <50f98a94$1@news.povray.org>
>> that value?
Erm... don't you mean -1?
Date: 18 Jan 2013 13:22:58
Message: <50f99301@news.povray.org>
> >> that value?
No. int(-1) has the same bit representation as MAX_UINT.
Date: 18 Jan 2013 13:25:13
Message: <50f99389@news.povray.org>
Am 18.01.2013 18:47, schrieb Orchid Win7 v1:
>>> that value?
No. That would be MAX_UINT.
Date: 18 Jan 2013 13:30:05
Message: <50f994ad@news.povray.org>
There's no index value that *could* be smaller than MIN_INT, so you would
have a bug certainly (the program wrongly thinks that all indices are
outside the array), but still no out-of-bounds access.
Even if the array size is (interpreted as) something larger than MIN_INT,
thus allowing for indices that are smaller than it, it would still bug
but not access out of the array (because negative indices "wrap around"
when they are converted to memory offsets, ending up at the same place
as the unsigned index with the same bit pattern.)
The only situation that I can think of where an out-of-bounds access will
probably happen is if pointers (and thus array indices) are 64-bit but
the array size is wrongly a signed (32-bit) int. It then gets expanded
to 64-bit when indexing the array, and ends up truly at negative addresses
(from the array's start.)
Date: 18 Jan 2013 13:44:27
Message: <50f9980b$1@news.povray.org>
Am 18.01.2013 19:30, schrieb Warp:
Okay, let's do it a bit more specific:
   void fubar(int idx)
     char c[1024];
     if (idx < 1024)
       fnord(c[idx]);
     else
       FAIL_SAFE();
   void main()
     fubar(INT_MAX+1);
No out-of-bounds access? Look at the code again.
Date: 18 Jan 2013 13:55:36
Message: <50f99aa8@news.povray.org>
>    void fubar(int idx)
>      char c[1024];
>      if (idx < 1024)
>        fnord(c[idx]);
>      else
>        FAIL_SAFE();
>    void main()
>      fubar(INT_MAX+1);
But in the original post it was suggested that an array size of INT_MAX+1
in the image file could cause this. Here the array size is just 1024 (which
in this particular contest would have ostensibly been read from the image
file.)
Unless there's an image file where there are actual index values specified.
