POV-Ray : Newsgroups : povray.off-topic : OO theory? Python. Server Time
23 Mar 2026 10:08:01 EDT (-0400)
  OO theory? Python. (Message 10 to 19 of 19)
<<< Previous 9 Messages Goto Initial 10 Messages
Subject: Re: OO theory? Python.
Date: 15 Oct 2012 15:23:49
Message: <507c62c5$1@news.povray.org>
On 15/10/2012 07:56 PM, Aydan wrote:
> Everything in Python is an object. Functions, classes, modules even integers are
> objects.
> So python is very much designed for OO.
Everything in JavaScript is an object. However, JavaScript does not have
the concepts of "classes" or "inheritance" or "encapsulation". Whether
you consider JavaScript to be "object-oriented" or not depends on what
you consider "object-oriented" to actually mean...
Date: 16 Oct 2012 08:06:23
Message: <507d4dbf@news.povray.org>
Aydan <hes### [at] hendrik-sachsenet> wrote:
> > > [begin code]
> > > class vector(object):
> > >   def __init__(self,x,y,z):
> > >     self.__x=x
> > >     self.__y=y
> > >     self.__z=z
> > Is that really how you write OO code in Python? Is it just me, or does it
> > look like Python hasn't actually been specifically designed to be an OO
> > language?
> What do you mean?
Well, for one, methods taking 'self' as a parameter seems highly unusual
because in the vast majority of OO programming languages all methods always
have an implicit pseudo-object (usually named 'self' or 'this'). Python
methods taking it explicitly just feels like a kludge that has been tacked
at a later time onto a non-OO language.
Using __ as a syntax to denote a special meaning of functions and variables
is also quite unusual, and likewise feels like a kludge. Programming
languages seldom give any special syntactic meaning to variables and
function names containing underscores. (Instead, they usually use actual
keywords to express, for example, member variable visibility.)
If these (and I'm sure other) syntactic decisions have been made since the
very beginning of Python, I must say that it's... unusual, to put it in
nice terms.
It's quite ambiguous to say that "X is an object".
In programming theory "object" is a synonym for "first-class citizen",
which in turn means that the entity can be stored in variables and data
structures, passed to and returned from subroutines, constructed at
run-time and has an identity (eg. a unique low-level memory address that
can be compared.)
For example a variable of type 'int' in C is an "object" by this definition
(in other words, it's a first-class citizen.) However, one would hardly
classify it as an "object" in the object-oriented sense of the word. For
example, it's not something that can be inherited from (which pretty much
makes it non-OO.)
"Object-oriented language" requires a bit more than just having "everything
is an object" (especially since it's unclear what's meant by "object" in
this context.)
Date: 16 Oct 2012 10:20:01
Message: <web.507d6c5b7215dcd3771cd8e0@news.povray.org>
> > > > [begin code]
> > > >     self.__x=x
> > > >     self.__y=y
> > > >     self.__z=z
> > > language?
> > What do you mean?
> nice terms.
> can be compared.)
> makes it non-OO.)
> this context.)
I don't know why the pythonians did what they did, but keep in mind that python
is not a compiled language but a dynamic script language. Everything happens at
runtime.
print "\n".join(dir(int)) gives you all member functions of int.
Now you tell me if it's an OO object or not ;o)
As to why self is passed for instance functions? No idea, I see it as something
like main{} for C, it's just done like that and it doesn't disturb me.
I suppose it's a distinction between class functions and instance functions.
Date: 16 Oct 2012 17:30:00
Message: <web.507dd1d17215dcd343b23870@news.povray.org>
> Shay <nomail@nomail> wrote:
> > I'm trying to improve myself in this area. I use objects, but there are some
> > things I think I just haven't wrapped my head around. I don't personally know
> > any programmers, so my though process has evolved, for the most part, in
> > isolation.
> I think that you might get more responses from the numerous programmers
> here if you ask something more concrete in a more concise and clear manner.
> I'm not saying this as any kind of criticism or attack. It's just that
> your post is a bit long and vague, which makes it difficult to discern
> what exactly is it that you have a problem with and what is it that you
> are looking for.
> Btw, where have you got the idea that methods shouldn't return anything?
> I have never heard of such a thing.
Date: 20 Oct 2012 13:32:18
Message: <5082e022@news.povray.org>
A function that takes "self" as the first argument is a method. Otherwise
it's a function.
The constructor is named __init__
The operator+ method is named __add__
And so on. It just avoids special syntax and substitutes special names.
The variable __y is just a plain old variable with the name mangled for
pseudoreadability, exactly like naming a member variable in C++ m_xyz so you
remember it's a member variable when you use it. Personally, I never saw the
point. But since Python doesn't have "private" vs "public" variables, people
have taken to using leading underscores to mean "don't touch this from outside."
 > Programming
Unless it, say, a destructor in C++ ;-)
Honestly, I always thought naming the constructor after the class was a
terrible decision.
> nice terms.
It *is* unusual. It's not especially broken.
   "They're the 1-800-#-GORILA of the telecom business."
Date: 21 Oct 2012 02:39:52
Message: <508398b8@news.povray.org>
> it's a function.
Well, duh. How does that change what I said?
It substitutes special syntax by using special syntax... Sounds
contradictory to me.
Date: 21 Oct 2012 20:28:34
Message: <50849332@news.povray.org>
>> it's a function.
I'm just explaining why people pass "self" as the first parameter. It's
basically a declaration.
Having underlings as part of the name isn't any more "special" than it is in
C or C++.  However, I cannot name my own function "operator'" in C++ because
the "operator" keyword actually is special syntax. I can name my function
__quote__ in Python because that function name has no special meaning to the
interpreter.
When the interpreter sees "a + b" it first looks to see who implements
__add__, and then invokes that. If neither side implements __add__ then it
goes to the default implementation of adding integers or floats or whatever.
However, my main point was to explain to you what was happening. Whether you
think it's reasonable after it is explained is up to you.
Date: 21 Oct 2012 20:58:26
Message: <50849a32$1@news.povray.org>
>> it's a function.
Well, to be more specific, you can call a function two ways:
abc(xyz, pdq)
or
xyz.abc(pdq)
They both do the same thing, except the second syntax says "pass xyz as the
first argument to the function abc() found in the dictionary of the value of
xyz."  So it's not really changing the syntax or declaring that it's a
method in any way. It's just saying "I expect you to invoke this in a way
that looks like a method, because I named the first argument 'self'." If you
wanted to invoke it on some other object, you could just as easily invoke
abc(that, pdq) and "self" would become "that".
It's a naming convention, nothing more. Unlike, say, the names of
constructors and destructors, which things like Java, C++, and C# treat as
special because they match the name of the enclosing class.
Remember, too, that names in Python are merely variables. A class doesn't
have a name, but only the variable(s)/dictionary key(s) to which it is
currently assigned.  So there's no way to identify special properties of a
class, especially since you can modify the classes at run time.
Date: 22 Oct 2012 09:53:59
Message: <50854ff7@news.povray.org>
'operator' is a keyword that's fairly descriptive. '__' in a variable name
as required syntax isn't very descriptive.
> interpreter.
That's contradictory with:
So it does have a special meaning to the interpreter, or it doesn't?
Date: 22 Oct 2012 10:26:30
Message: <50855796$1@news.povray.org>
That's a fair complaint.
>> interpreter.
As I thought I said, __add__ has special meaning, __quote__ does not. It's
not the presence of the __ that makes it magic. It's the entire name.
