>> I'll get excited when they release a holographic camera. (Which, I
>> would like to point out, is *totally* plausible.)
> yes, holography is exactly what I thought of (the "light from all
> directions" concept).
> Of course, holography and this focal-changing one demands a proper
> viewer too, possibly even more expensive, limited and cumbersome than
> the simple 2-frames stereographic ones they're trying and failing so
> hard to sell today.
I was surprised to discover that making a hologram is actually way, way
easier than you might imagine.
You can make a hologram using ordinary photographic paper. To make a
hologram rather than a normal photograph, you just need to do two
special things:
1. Illuminate the subject with laser light.
2. Let the light reflected by the subject fall directly on the
photographic paper. (I.e., do *not* use lenses to focus it into an image.)
When you develop the paper, if it has sufficiently fine grain to it, you
will get a hologram. Ta-da!
So, to make a holographic camera, "all" you need to do is make a light
sensor with very, very high spatial resolution. And similarly, a
holographic display "just" needs to have very high spatial resolution.
You don't need glasses or anything, it works like a normal hologram would.
(And yes, you can use a computer to render the hologram. It will take a
stupidly long time though, I should imagine...)
I actually find myself wondering whether a LightScribe(tm) system would
have sufficient resolution to print a hologram. It's plausible...
http://www.youtube.com/watch?v=XUy8lELWhJg
Search for "Scratch hologram". You can do it with a nail and a piece of plastic.
"Coding without comments is like
driving without turn signals."
> plastic.
Heh. That's trippy.
...although not particularly high in detail content, and I'm guessing it
takes a hell of a long time to do these.
http://blog.orphi.me.uk/
Depends what you consider a long time. Probbly an hour or so, once you have
it planned out.
