POV-Ray : Newsgroups : povray.off-topic : RegEx help Server Time
12 Apr 2026 06:29:50 EDT (-0400)
  RegEx help (Message 1 to 7 of 7)
Subject: RegEx help
Date: 9 May 2010 13:40:00
Message: <web.4be6f30c8bf12a8ce79f0df40@news.povray.org>
Hey all, I know it's been a while since I've posted here, but I also know there
are some regex wizards who read these groups...
I never bothered learning regular expressions, but we're going over them for one
of my classes, and I'm having trouble searching for strings at the end of a line
with $.
As I understand it, $ matches for the end of the line.  Fine.  When I search
just for $, I get every line (as I should).
However, when I try to append $ onto any other expression, I don't get a single
match - not one - when I know there should be some.  For instance, the
following:
ing[.]$
Should search for any line ending in "ing."  Searching just for "ing[.]" returns
the hits I want (plus a few more), but "ing[.]$" doesn't return a single hit.
Any tips as to what I'm doing wrong?
Subject: Re: RegEx help
Date: 9 May 2010 14:43:30
Message: <4be70252$1@news.povray.org>
Firstly, which regexp engine are you using? They're all slightly different.
Second, if you want to search for a literal period, probably \. is better
than [.].
Depending on your engine, you might need to escape the $ also.
In other words, the problem is not so much with your regular expression as
it is with expression the right regular expression to the RE interpreter
you're using. What you're searching for ought to work, so the problem is
either (1) you have spaces between the period and end of line, or (2) you
are not passing the string to the RE engine that ends with "end of line"
match marker.
Try searching for
   ing[. ]+$
and see if you get matches with one or more spaces between the ing. and the EOL.
    Ada - the programming language trying to avoid
    you literally shooting yourself in the foot.
Date: 9 May 2010 15:12:02
Message: <4be70902$1@news.povray.org>
> with $.
> following:
> ing[.]$
Pattern "ing[.]$" matches exactly as you expected,
when applied to the text with Unix-style line endings (\n),
but for Win-style line endings (\r\n) it
doesn't match your input.
Date: 9 May 2010 23:45:00
Message: <web.4be780c014fb0cf2e79f0df40@news.povray.org>
I'm using grep, but I don't know what version.  It's a virtual linux machine
that I access via a web browser for labs for class... I could do a local
install, but it wouldn't have the files we're supposed to work with.
> than [.].
That's what I would have thought, but I found that \. didn't return any matches,
whereas [.] did.  Probably a quirk of the version I was using.
> match marker.
Thanks, I turned in my lab report with what I thought should work, and noting
that it didn't.  That was the only problem with it, so I doubt I'll lose too
many points.
....Chambers
Date: 10 May 2010 01:06:27
Message: <4be79453@news.povray.org>
Probably because you're using the shell, so it's eating the first \
Try \\. where you need a ., since the shell will take away one \ and grep
will take away the other.
> many points.
Good luck. Let us know what the answer is? :-)
You know, I bet if you're invoking it from the command line, the shell might
be swallowing the $ also.  That's one of the things I hate about this sort
of thing - quoting hell.
Date: 10 May 2010 07:07:53
Message: <4be7e909@news.povray.org>
  How are you running grep? And from where?
  If you give a regexp to grep as a command-line parameter, remember to
always escape the entire regexp so that the shell won't mess it up. In
other words:
   grep 'ing\.'
not:
   grep ing\.
which will end up completely different when grep sees it.
Date: 10 May 2010 07:08:51
Message: <4be7e943@news.povray.org>
  A lot easier and more intuitive to simply use quotes:
    grep 'ing\.'
  It probably explains the $ not working as well (because the shell might
be eating it).
