POV-Ray : Newsgroups : povray.off-topic : rgb value of "red" in red-cyan anaglyph glasses? Server Time
6 Mar 2026 04:14:12 EST (-0500)
  rgb value of "red" in red-cyan anaglyph glasses? (Message 1 to 10 of 11)
Subject: rgb value of "red" in red-cyan anaglyph glasses?
Date: 7 Jan 2010 18:25:00
Message: <web.4b466cdffbbedb0634d207310@news.povray.org>
I was playing around with some red-cyan anaglyphs and my son pointed out that
the "red" portion of the screen wasn't perfectly blocked by the "red" lens.  Is
there a technological limitation here (see thread about "yellow" lens), or is
there just a more perfect rgb value I might be able to find?
Subject: Re: rgb value of "red" in red-cyan anaglyph glasses?
Date: 8 Jan 2010 05:14:52
Message: <4b47059c$1@news.povray.org>
Uh, no, the *cyan* lense is supposed to block red. The *red* lense is
supposed to let it through. It shouldn't be blocking it at all.
Date: 8 Jan 2010 06:43:24
Message: <4b471a5c$1@news.povray.org>
Invisible wrote:
>> out that
>> lens.  Is
>> lens), or is
It should make it not visible at all which I think is what Greg meant.
Through the red lens, light coming from the cyan parts is filtered out,
  therefore the cyan parts are visible in black. Light coming from the
red parts and light coming from the white parts should in theory end up
at exactly the same color, thus you can't distinguish the red parts when
you look through the red lens.
Maybe the red used on the screen is a bit too dark, which makes the red
areas appear as  slight shadows. Using light gray instead of white for
the background might solve the issue...
Vincent
Date: 8 Jan 2010 07:39:47
Message: <4b472793$1@news.povray.org>
Or rather, with the red lense, black appears as black, red appears as
red, and any other colour appears as black. (At least, ideally.)
Date: 8 Jan 2010 11:30:06
Message: <4b475d8e@news.povray.org>
  The cyan lens blocks red light... making it look black. The red lens
blocks everything else other than red.
  Thus it depends on whether the *background* is black or white which lens
allows you to see the red lines. When looked through the red lens, a red
line against a white background will not be visible because everything
looks red. However, a red line against a black background will be visible
because the red line is the only thing which reflects light (and passes
through the lens).
Date: 9 Jan 2010 17:35:00
Message: <web.4b4903abccc8c4e65f302820@news.povray.org>
I remember old 3-D comic books and such having the same problem. I think the
main limitation is the rather broad-spectrum 'red' color that is used in those
inexpensive cellophane glasses. They let pass too many light frequencies
'around' the red (or block too few??) I suppose an *ideal* red filter would need
to be almost monochromatic--and matched exactly to the printed color of the
anaglyph (or the projected color of a film/transparency.)
Ken
Date: 9 Jan 2010 18:40:54
Message: <4b491406$1@news.povray.org>
You'd need a very saturated printed color, too, or your ambient light would
affect the results too much. At which point I'm not sure you wouldn't be
messing up the cyan side of it.
On a slightly different topic, I saw one of the Sony 3D TVs today.
Interesting, but not ready for prime time, IMO.
   Forget "focus follows mouse." When do
   I get "focus follows gaze"?
Date: 9 Jan 2010 19:30:01
Message: <web.4b491e9eccc8c4e34d207310@news.povray.org>
Update:
For the same image, on SCREEN, the RED red lens doesn't do what it's supposed to
do-- shows ghost images of stuff not appropriately blocked.
When PRINTED, the CYAN lens doesn't do what it's supposed to do.
Date: 10 Jan 2010 07:02:19
Message: <4b49c1cb@news.povray.org>
gregjohn wrote:
> Update:
Sounds to me like either the glasses or the screen/printer are not
perfectly calibrated. There probably isn't a lot you can do about that...
http://blog.orphi.me.uk/
Date: 10 Jan 2010 07:04:04
Message: <4b49c234$1@news.povray.org>
I don't know what technology they use, but there's some "3D TVs" at my
local shopping center. As you walk past them, they have a vaguely
hologram-like quality to them. But it doesn't look particularly 3D; more
like as you walk past, the image changes in discrete steps. Novel, but
not very realistic.
