POV-Ray : Newsgroups : povray.off-topic : There comes a time... Server Time
19 Apr 2026 22:27:22 EDT (-0400)
  There comes a time... (Message 1 to 10 of 67)
Subject: There comes a time...
Date: 1 Feb 2008 10:09:11
Message: <op.t5upqgbcc3xi7v@news.povray.org>
.. in every young geeks life where he resolves to locate the designer of
the motherboard they've just been installing and string them up from the
nearest tall object.
Thank you unnamed designer for the entire 5mm clearance between the CPU
heatsink clamps and Northbrige+heatsink on one side and the other 5mm
clearance between the clamps and a set of capacitors. Also taking into
account standard case designs putting the screw hole between the serial
port block and where the PSU normally sits was just as much fun.
Nah it wasn't too bad I just wonder if they ever have to actually install
one of their creations.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Subject: Re: There comes a time...
Date: 1 Feb 2008 13:40:00
Message: <web.47a366d68f23b2112b78a1fe0@news.povray.org>
> Phil Cook
LOL
No. They are completely satisfied with building it. ;-)
Regards
         bluetree
Date: 4 Feb 2008 04:15:01
Message: <op.t5ztbu0ic3xi7v@news.povray.org>
And lo on Fri, 01 Feb 2008 18:37:10 -0000, bluetree <nomail@nomail> did
spake, saying:
>> install
>> Phil Cook
> LOL
Yeah, I wouldn't have minded too much but if you think of it as being
orientated NS then ES was a vast unsullied plain of nothing-ness.
Phil Cook
Date: 4 Feb 2008 06:10:01
Message: <web.47a6f1778f23b211fc5f9fa80@news.povray.org>
I know, why I am not a geek and actually not able to build a computer from piece
parts all on my own. :-D
You should see the wire-clutter, my computer has inside... (would probably be
better, if things would have a different orientation or I would have another
tower.) ;-)
But I don't complain, because I'm soooo happy, it works and I can do quite
enough with that old thing. :-)
Regards
          bluetree
Date: 4 Feb 2008 09:33:07
Message: <op.t5z7zaf6c3xi7v@news.povray.org>
And lo on Mon, 04 Feb 2008 11:05:27 -0000, bluetree <nomail@nomail> did
spake, saying:
> from piece parts all on my own. :-D
> probably be
> another tower.) ;-)
> quite enough with that old thing. :-)
In a older thread I pointed out how installing things in terms of hardware
has barely changed compared to software. Depending on what you're doing
you're still expected to pop the case, screw/unscrew things, fiddle with
wires and jumper settings while ensuring you're not statically charged and
shorting anything out.
Can you imagine if the only way to install anying in Windows was to locate
the correct installation file, move some of the files over manually, and
then set the right commands in the registry while at the same time
ensuring it doesn't mess with any of your other programmes?
I mean sure things have got better superficially. I opened the case by
hand rather then by screwdriver, and... um yeah that's about the only
difference I noted.
Phil Cook
Date: 4 Feb 2008 09:53:10
Message: <47a726d6@news.povray.org>
> hardware has barely changed compared to software. Depending on what
> you're doing you're still expected to pop the case, screw/unscrew
> things, fiddle with wires and jumper settings while ensuring you're not
> statically charged and shorting anything out.
> locate the correct installation file, move some of the files over
> manually, and then set the right commands in the registry while at the
> same time ensuring it doesn't mess with any of your other programmes?
> difference I noted.
Dude. Jumpers.
Seriously. Jumpers.
It used to be the case that getting any new bit of hardware to work
involved advanced jumper settings, twiddling dip switches and chanting
over voodoo dolls. Today you can pretty much just plug in a PCI card and
*expect* it to work immediately - or at least as soon as you put the CD
in. No IRQ conflicts, no driver mismatches, IT JUST WORKS!!
Anybody who remembers the old skool ways will tell you just how much of
an improvement that is.
And let's not even get started on all those USB goodies that YOU JUST
PLUG IN AND THEY GO! It wasn't like that before. Had to turn off the
whole PC to connect or disconnect anything...
http://blog.orphi.me.uk/
Date: 4 Feb 2008 10:29:20
Message: <op.t50akiokc3xi7v@news.povray.org>
And lo on Mon, 04 Feb 2008 14:53:06 -0000, Invisible <voi### [at] devnull> did
spake, saying:
>> difference I noted.
> Dude. Jumpers.
> Seriously. Jumpers.
Which I had to change to set the FSB speed; not counting the ones on the
HDs for master/slave which I didn't need to look at. You're right though I
recall racks of jumpers which had to be set to arcane precsion to get
things working, but it's still a testament that's the only advance you can
spot. Unless you want to go off on SCSI, but that's always been dark juju.
> or at least as soon as you put the CD in.
So the CD counts as part of the hardware then?
Describe the process for installing a CPU five/ten years ago compared to
doing so today. Repeat with a video card leaving out bits you're doing in
software.
But how much is that down to an improvement in software. Windows 95
automatically added new hardware and sought out the drivers for it.
Again though why did the older computers need to reboot - the software
unable to dynamically load/unload drivers or a physical hardware aspect?
Phil Cook
Date: 4 Feb 2008 10:36:30
Message: <47a730fe$1@news.povray.org>
Phil Cook wrote:
>> Dude. Jumpers.
>> Seriously. Jumpers.
Really??
On my motherboard, I just plugged everything in, turned it on, and it
automatically configured itself and worked. Not one single jumper to set.
SATA HDs don't have these either.
> You're right though
> I recall racks of jumpers which had to be set to arcane precsion to get
> can spot.
Can you think of anything else that *requires* improvement then?
>> and *expect* it to work immediately -
Depends on your definition of "works".
If you want to be able to control it, you'll need some software to do
that. But sure, a couple of things that can be operated without software
will work straight off...
> doing so today.
What, you'd like the CPU to teleport itself into the socket instead? :-D
> in software.
Remember when we all had 2 video cards and a pass-through cable to allow
you to switch between 2D and 3D modes? ;-)
>> of an improvement that is.
In the old days, things like IRQ numbers could *only* be adjusted by
physically moving DIP switches on the circuit board. The point is that
they CHANGED THE HARDWARE so you could change the IRQ number in
software. THAT is what has allowed "the software to get better".
In the Old Days, if you suddenly plugged or unplugged a device, you
would likely fry the interface circuitry. Today we use interfaces that
are expressedly designed to support such actions. That one is purely a
hardware thing. (Although obviously the software needs to support it too.)
Date: 4 Feb 2008 10:45:56
Message: <op.t50bb01yc3xi7v@news.povray.org>
And lo on Mon, 04 Feb 2008 15:36:29 -0000, Invisible <voi### [at] devnull> did
spake, saying:
> Phil Cook wrote:
>>> Dude. Jumpers.
>>> Seriously. Jumpers.
> Really??
<major snip> I'm not saying things haven't gotten better, just a) cmparing
the pace compared to software and b) would you expect someone who had no
problem installing Acme Racing Game II to fit a new CPU/Motherboard/Video
Card/Memory? 'Open up the case and look at all those wires, now just
remember don't touch any of them else sharks will eat your granny'. You're
still opening the case being confronted with a PCB and a bunch of wires
and cables hanging about it's still more a preserve of your geek.
Phil Cook
Date: 4 Feb 2008 10:52:02
Message: <47a734a2$1@news.povray.org>
> cmparing the pace compared to software and b) would you expect someone
> who had no problem installing Acme Racing Game II to fit a new
> CPU/Motherboard/Video Card/Memory? 'Open up the case and look at all
> those wires, now just remember don't touch any of them else sharks will
> eat your granny'. You're still opening the case being confronted with a
> PCB and a bunch of wires and cables hanging about it's still more a
Well... have you opened the bonnet of your car recently? I notice newer
cars have a big sheet of plastic under there, but beyond that it's still
pretty much a case of "if you don't know what a distributor is, you
probably shouldn't touch this - otherwise you might die". At least
computers don't physically kill you if you make a mistake. ;-)
I don't really see how the situation can realistically be improved much.
You could make all the components less fragile by using some sort of
casing, and make it to things slot together more easily, but that's
about it.
