Jim Henderson <nos### [at] nospam com> wrote:
> On Sat, 24 Jan 2026 12:25:51 EST, Bill Pragnell wrote:
> > Yes, this was my first thought - you need to commit your changes to the
> > current branch or nothing gets tracked. Use 'git add <...>' to stage the
> > changes, 'git commit' to commit them.
> IIRC, 'git status' will show if that's the case, as it shows untracked
> files.
Yep, 'git status' with no other args will list staged files, changed tracked
files and untracked files in separate sections.
This scenario sounds like there would just be items in the 'changes' section,
since these are changes to tracked files. A newly added file would appear in
untracked files.
Bill
Subject: Re: Nope, I STILL don't understand git branches
Date: 24 Jan 2026 20:13:06
Message: <69756e22$1@news.povray.org>
On 2026-01-23 10:46 (-4), Jim Henderson wrote:
> I might be mistaken (it's WAY to early in the morning for me to be
> thinking about this), but if the file isn't added to the repo and just
> lives within the directory, then I don't think any changes get tracked,
> and this is the behavior you would probably see.
> Make sure you use `git add <filename>` for anything you want change
> tracking enabled.
No, the files are definitely part of the repo.
Date: 24 Jan 2026 20:21:02
Message: <69756ffe$1@news.povray.org>
>> tracking enabled.
> Also I don't know how bad you feel about using GUI, but I love Git-Cola for
> spotting that kind of issue.
Git-Cola has been wonderful, and it works seemlessly with the CLI. But
the files in question *are* being tracked.
Date: 24 Jan 2026 20:29:19
Message: <697571ef$1@news.povray.org>
On 2026-01-24 13:25 (-4), Bill Pragnell wrote:
> Yes, this was my first thought - you need to commit your changes to the current
> branch or nothing gets tracked. Use 'git add <...>' to stage the changes, 'git
Are you saying that changes will show up in *all* branches until they're
committed to *one* of the branches?
Date: 24 Jan 2026 20:53:12
Message: <69757788$1@news.povray.org>
>> the changes, 'git commit' to commit them.
Technically, they don't show up in any branch because the file isn't
tracked. If a file isn't tracked, it exists outside git's "system", and
the file will appear the same in all branches (but it's not in any of
them. If you wipe the directory and then do a git pull, the file won't be
there at all).
"I learned long ago, never to wrestle with a pig. You get dirty, and
besides, the pig likes it." - George Bernard Shaw
Date: 24 Jan 2026 20:56:23
Message: <69757847$1@news.povray.org>
>> tracking enabled.
Do you see them in `git status`?
If you see something like this:
$ git status
On branch electron
Your branch is up to date with 'origin/electron'.
Untracked files:
(use "git add <file>..." to include in what will be committed)
package-lock.json
nothing added to commit but untracked files present (use "git add" to
track)
Then the file isn't part of the repo (in this case, package-lock.json
isn't part of the repo I was checking). That would be consistent with what
you're seeing.
Jim
Date: 24 Jan 2026 22:56:33
Message: <69759471$1@news.povray.org>
>>> tracking enabled.
> $ git status
> On branch electron
> Untracked files:
> package-lock.json
> track)
> you're seeing.
------------------------[BEGIN TERMINAL SESSION]------------------------
$ git checkout restored_oc
M README.md
M gemcuts.pov
M gemcuts_description.txt
Switched to branch 'restored_oc'
$ git status
On branch restored_oc
Changes not staged for commit:
(use "git add <file>..." to update what will be committed)
(use "git restore <file>..." to discard changes in working directory)
modified: README.md
modified: gemcuts.pov
modified: gemcuts_description.txt
Untracked files:
gem_ring-CSG.inc
no changes added to commit (use "git add" and/or "git commit -a")
$ git checkout main
M README.md
M gemcuts.pov
Switched to branch 'main'
$ git status
On branch main
modified: README.md
Untracked files:
gem_ring-CSG.inc
-------------------------[END TERMINAL SESSION]-------------------------
The files README.md, gemcuts.pov, and gemcuts_description.txt were
modified while one branch was checked out, and the changes show in the
other branch as well.
N.B. Pay no attention to file gem_ring-CSG.inc; it's untracked on
purpose. It's just a file that I haven't added to .gitignore, and I'm
still trying to decide what to do with it.
>> tracking enabled.
And have a look at the ".gitignore" file documentation.
I use this short-circuit:
$ vim groundbase.inc
... do some changes, exit vim
... run the tracing, look at the result
... if the result look correct, then
$ git commit -m "increase holes diameter" groudbase.inc
And now, I can run the big batch who make my current
projet: http://maison.tth.netlib.re/v/hc/full.mp4 :)
* tTh des Bourtoulots *
* http://maison.tth.netlib.re/ *
hi,
v nice, "sweet"..
regards, jr.
Date: 25 Jan 2026 11:46:51
Message: <697648fb$1@news.povray.org>
Hmm. I guess then we'd need to see what the status looks like from each
branch. What you're seeing isn't consistent with my experience, at least.
