POV-Ray : Newsgroups : povray.off-topic : Nope, I STILL don't understand git branches Server Time
30 Jan 2026 18:44:07 EST (-0500)
  Nope, I STILL don't understand git branches (Message 21 to 23 of 23)
Subject: Re: Nope, I STILL don't understand git branches
Date: 27 Jan 2026 08:53:40
Message: <6978c364$1@news.povray.org>
On 2026-01-26 18:44 (-4), Bill Pragnell wrote:
> Jim Henderson <nos### [at] nospamcom> wrote:
>> On Sat, 24 Jan 2026 23:56:33 -0400, Cousin Ricky wrote:
>>> The files README.md, gemcuts.pov, and gemcuts_description.txt were
>>> modified while one branch was checked out, and the changes show in the
>>> other branch as well.
>> Hmm.  I guess then we'd need to see what the status looks like from each
>> branch.  What you're seeing isn't consistent with my experience, at least.
> I think that's what I would expect. If the changes don't have conflicts with any
> of the other branches then switching branches makes no difference, the changes
> will be left alone (unless there is a conflict, then git will warn you to commit
> your changes or lose them when switching branch). If you commit the changes to a
> branch, then you'll only see those changes on that branch - and now they won't
> be listed as changes by 'git status' any more.
This is exactly what I've seen since Sunday.
> An untracked file is just a big change after all.
Date: 27 Jan 2026 09:02:15
Message: <6978c567$1@news.povray.org>
On 2026-01-26 02:00 (-4), Jim Henderson wrote:
> But it looks like the file is tracked, so any changes to it made in one
> branch shouldn't affect other branches, unless they're either not tracked
> (which isn't the case) or in .gitignore (which would *probably* require it
> to have been explicitly added in some way, and I expect CR would know if
> he'd done that).
I'm sensing disagreement in what "tracked" means.  Jim is using
"tracked" the way I've understood it, but Bill is describing the
behavior I'm seeing from git.
But .gitignore is one aspect of git that has never given me any surprises.
Date: 27 Jan 2026 17:58:07
Message: <697942ff$1@news.povray.org>
>> tracked (which isn't the case) or in .gitignore (which would *probably*
>> require it to have been explicitly added in some way, and I expect CR
>> would know if he'd done that).
> surprises.
Can you describe the workflow you're using, step by step - commands
executed, and so on - in order to try to reproduce what you're seeing?
"I learned long ago, never to wrestle with a pig. You get dirty, and
besides, the pig likes it." - George Bernard Shaw
