POV-Ray : Newsgroups : povray.off-topic : Nope, I STILL don't understand git branches Server Time
31 Jan 2026 04:30:33 EST (-0500)
  Nope, I STILL don't understand git branches (Message 18 to 27 of 27)
Subject: Re: Nope, I STILL don't understand git branches
Date: 26 Jan 2026 03:35:00
Message: <web.6977268d461f9d4e16086ed06830a892@news.povray.org>
> On 1/24/26 18:25, Bill Pragnell wrote:
>     And have a look at the ".gitignore" file documentation.
Indeed, in that case I would tend to highly suspect the gitignore, which can
feature very wide filters preventing files of some type of some naming patterns
to be normally flagged as untracked... OR you may also have git stash->pop
....ped over several branches. because stash can act as a bucket to port things
from one branch to another.
If you want to have other graphic views of your repos and stash black box, you
can also try :
* Gitlens with VScode/VSCodium or
* Git kraken, which looks awesome but somewhat limits its longterm featureset in
the long run.
-So Git-Cola rules for its cross platform, and free as in freesdom policies...
But mostly, don't forget its "DAG" visualisation for all your branches.
Date: 26 Jan 2026 17:45:00
Message: <web.6977ee4b461f9d4e95258fa76f35e431@news.povray.org>
Jim Henderson <nos### [at] nospamcom> wrote:
> On Sat, 24 Jan 2026 23:56:33 -0400, Cousin Ricky wrote:
> > The files README.md, gemcuts.pov, and gemcuts_description.txt were
> > modified while one branch was checked out, and the changes show in the
> > other branch as well.
> Hmm.  I guess then we'd need to see what the status looks like from each
> branch.  What you're seeing isn't consistent with my experience, at least.
I think that's what I would expect. If the changes don't have conflicts with any
of the other branches then switching branches makes no difference, the changes
will be left alone (unless there is a conflict, then git will warn you to commit
your changes or lose them when switching branch). If you commit the changes to a
branch, then you'll only see those changes on that branch - and now they won't
be listed as changes by 'git status' any more.
An untracked file is just a big change after all.
Bill
Date: 27 Jan 2026 01:00:46
Message: <6978548e@news.povray.org>
>> > the other branch as well.
>> each branch.  What you're seeing isn't consistent with my experience,
>> at least.
> with any of the other branches then switching branches makes no
> difference, the changes will be left alone (unless there is a conflict,
> then git will warn you to commit your changes or lose them when
> switching branch). If you commit the changes to a branch, then you'll
> only see those changes on that branch - and now they won't be listed as
But it looks like the file is tracked, so any changes to it made in one
branch shouldn't affect other branches, unless they're either not tracked
(which isn't the case) or in .gitignore (which would *probably* require it
to have been explicitly added in some way, and I expect CR would know if
he'd done that).
"I learned long ago, never to wrestle with a pig. You get dirty, and
besides, the pig likes it." - George Bernard Shaw
Date: 27 Jan 2026 08:53:40
Message: <6978c364$1@news.povray.org>
This is exactly what I've seen since Sunday.
Date: 27 Jan 2026 09:02:15
Message: <6978c567$1@news.povray.org>
> he'd done that).
I'm sensing disagreement in what "tracked" means.  Jim is using
"tracked" the way I've understood it, but Bill is describing the
behavior I'm seeing from git.
But .gitignore is one aspect of git that has never given me any surprises.
Date: 27 Jan 2026 17:58:07
Message: <697942ff$1@news.povray.org>
>> tracked (which isn't the case) or in .gitignore (which would *probably*
>> require it to have been explicitly added in some way, and I expect CR
>> would know if he'd done that).
> surprises.
Can you describe the workflow you're using, step by step - commands
executed, and so on - in order to try to reproduce what you're seeing?
Date: 30 Jan 2026 21:45:00
Message: <web.697d6c01461f9d4e95258fa76f35e431@news.povray.org>
Are we confusing our usage of 'change' perhaps? A 'change' to a file (in
git-speak) refers to an edit, without any git interaction, which is what I've
been assuming. A change to a branch is usually called a 'commit', and that will
indeed be unique to the branch.
I think git itself may also be confusing the issue here. 'Tracked' just means
the file has been added to the repo. If I add a new file to a project (without
git interaction - just make a new file within a repo), it is listed as
'untracked' because it does not yet have an entry in the repo - its entire
contents are a 'change'. If I 'git add' and then 'git commit' that file, it is
then 'tracked' as part of that branch from that point on. But you could say that
even an 'untracked' file is tracked in the sense of git being aware of it,
because it appears in the status. Only files/directories in .gitignore are truly
untracked because edits to them will be ignored.
Uncommitted changes (i.e. edits to a file) will not be affected by switching
branches, unless there is a conflict - i.e. if the edits apply to a section of a
file that is different in the two branches. In that case, git will not switch
branches, but instead tell you to commit or 'stash' your changes before
switching (stashing is saving your changes on a temp stack rather than
committing them).
Sorry if I'm muddying the water here! I remember being quite confused about how
git worked when I first started using it.
Bill
Date: 31 Jan 2026 00:52:22
Message: <697d9896$1@news.povray.org>
>> >> one branch shouldn't affect other branches,
> I've been assuming. A change to a branch is usually called a 'commit',
> and that will indeed be unique to the branch.
No, that's what I'm calling a change - an edit to the file.
> means the file has been added to the repo. If I add a new file to a
> project (without git interaction - just make a new file within a repo),
> it is listed as 'untracked' because it does not yet have an entry in the
> repo - its entire contents are a 'change'. If I 'git add' and then 'git
> commit' that file, it is then 'tracked' as part of that branch from that
> point on. But you could say that even an 'untracked' file is tracked in
> the sense of git being aware of it, because it appears in the status.
> Only files/directories in .gitignore are truly untracked because edits
Hmmm.  I just created a quick test repo, and it's not working the way I
remembered it, but it is working the way you're describing and CR is
saying is happening for his setup, too.
> switching branches, unless there is a conflict - i.e. if the edits apply
> to a section of a file that is different in the two branches. In that
> case, git will not switch branches, but instead tell you to commit or
> 'stash' your changes before switching (stashing is saving your changes
> on a temp stack rather than committing them).
This is what I'm used to seeing.  But my usage generally had me making
changes within a branch, not creating the branch myself, and then the
developer who created the branch would merge things back (my main use case
for this was years ago creating in-product text strings for documentation
purposes - tooltips and the like).
I've used it a fair bit on my own since then, but generally haven't needed
to branch since the stuff I'm using it for is all for my own amusement.
> about how git worked when I first started using it.
> Bill
No worries, you got me to actually try it and see, and it wasn't matching
my memory.  Show now I need to figure out why my memory is different than
what I actually saw in my simple test.
Date: 31 Jan 2026 00:55:13
Message: <697d9941@news.povray.org>
> case for this was years ago creating in-product text strings for
> documentation purposes - tooltips and the like).
I think I understand better now - once I committed the changes to master,
then the branch I created (test1) "reverted" to what was originally in the
file when I branched it (ie, it was empty).
Date: 31 Jan 2026 01:07:54
Message: <697d9c3a$1@news.povray.org>
> master, then the branch I created (test1) "reverted" to what was
> originally in the file when I branched it (ie, it was empty).
So it seems to be that once a file is modified and then committed to a
branch, then changes to it will require a stash or commit before changing
branches again.
I probably never ran into this since the files I was modifying had already
been through many iterations by the time I saw them.  But it makes logical
sense to me that each branch isn't a full copy of everything in the state
at which it was first added, and that it would be consistent across
branches until it was changed in one of them.
I'd guess that if a change were committed in 'branch1' and you switched
back to 'master' where it wasn't committed, and created a new branch
'branch2', that the behavior would be consistent as well, at least until
'branch1' was merged back into 'master'.
