POV-Ray : Newsgroups : povray.off-topic : I cannot set up Github 2FA! Server Time
11 Oct 2026 08:37:18 EDT (-0400)
  I cannot set up Github 2FA! (Message 1 to 10 of 10)
Subject: I cannot set up Github 2FA!
Date: 7 Oct 2023 21:29:58
Message: <65220616$1@news.povray.org>
GitHub is requiring me to set up 2-factor authorization by October 11,
or they will lock me out of my account.  I've followed their setup
instructions using Aegis for Android, but I always get the message,
"Two-factor code verification failed.  Please try again."  I cannot
complete the setup.
There doesn't seem to be a help link anywhere, and this problem doesn't
show up in any FAQ, so I tried Googling, Binging, and DuckDuckGoing the
problem.  The only suggestion I've seen is that the clocks of the phone
and computer are out of sync.  It turned out mine were off by 2 seconds,
but re-synchronizing them did not help.  I've rebooted both the phone
and the computer.  No luck.
The deadline is approaching, and I'm faced with a problem that is not
acknowledged to exist by either GitHub or the authenticator.  Have any
GitHub users here set up 2FA successfully?  Did you have this problem?
My OS is openSUSE Leap 15.3.
Subject: Re: I cannot set up Github 2FA!
Date: 8 Oct 2023 07:14:08
Message: <65228f00@news.povray.org>
I'm pretty familiar with TOTP (which is what you're using), having implemented it in
code for my day job. Generally speaking the codes are valid in 30 or 60-second blocks,
and implementers are encouraged to allow codes for the previous block as well as the
current to be valid to avoid cases where someone gets a totally valid code and types
it in then submits it, but in the interim the issuer changes to a new block. That's a
bad user experience so most sites don't do that.
So basically a difference of two seconds is totally unimportant and not the cause of
your problem.
Yes, I have and no I didn't.
How are you importing the master code? Via QR + camera or are you using the
manually-entered key? If only one, have you tried the other? Have you tried a
different authenticator program?
If you think the issue is with Github, try using one of the sites that allows you to
test TOTP, such as https://www.verifyr.com/en/otp/check (just enter junk in the label
and issuer fields). Import the generated key then test it using the same page. It
should work. If it does and you still can't get Github to work then that would be
puzzling.
-- Chris
Date: 8 Oct 2023 10:31:02
Message: <6522bd26$1@news.povray.org>
> complete the setup.
I went with the SMS verification code.
(I do not trust applications)
It went fine (and once setup, they give you recovery data to download in
case the phone number get trashed)
Date: 8 Oct 2023 12:27:02
Message: <6522d856$1@news.povray.org>
You might want to check out how TOTP works. It is almost trivial (and
yet so effective) and can actually run almost anywhere, so you don't
have to depend on those "funny" applications available on phones if you
don't want to. There are several free libraries handling it to compile
even on your desktop.
Oh, and at least on an iPhone, you can actually use the native password
manager to generate the codes, too, however, you always have to go to
the password for the site to get the code displayed, so it isn't the
most convenient. Still. I would be surprised if this wasn't possible on
Android phone with Google native applications as well.
Thorsten
Date: 8 Oct 2023 12:44:31
Message: <6522dc6f$1@news.povray.org>
> the manually-entered key? If only one, have you tried the other? Have
> you tried a different authenticator program?
I used QR + camera.  Aegis appeared to load GitHub's info correctly.  I
have not tried a different authenticator program.
Date: 9 Oct 2023 17:13:10
Message: <pan$eb77f$3ab7e849$d2a2c206$e7043794@nospam.com>
FWIW, SMS is far less secure than an app.  IMEI cloning renders SMS
verification one of the least secure options out there.
TOTP application codes are among the most secure, because the algorithms
used are open.  You can use something like FreeOTP if you want something
that you can audit the code for.
"I learned long ago, never to wrestle with a pig. You get dirty, and
besides, the pig likes it." - George Bernard Shaw
Date: 9 Oct 2023 17:13:42
Message: <pan$7d3da$1dfec87$8aa90c63$9c84d5b4@nospam.com>
On Sun, 8 Oct 2023 18:27:01 +0200, Thorsten wrote:
>  I would be surprised if this wasn't possible on Android
Google Authenticator is the tool I use.
Date: 9 Oct 2023 17:22:28
Message: <pan$7af3$4fb38f39$f3a33cb9$608ba29a@nospam.com>
Actually, this isn't the correct reason, but it still is pretty insecure.
https://www.okta.com/blog/2020/10/sms-authentication/ (I worked for an
Okta competitor, but this article spells it out pretty well.)
It's better than nothing, but not better than TOTP.
Date: 11 Oct 2023 00:15:30
Message: <65262162$1@news.povray.org>
> allows you to test TOTP, such as https://www.verifyr.com/en/otp/check
> (just enter junk in the label and issuer fields). Import the generated
> key then test it using the same page. It should work. If it does and you
> still can't get Github to work then that would be puzzling.
I tried verifyr.com, and it worked.  But GitHub still doesn't.
Date: 11 Oct 2023 00:25:55
Message: <652623d3$1@news.povray.org>
Wait...!  On my last attempt, I got a different error message, with a
link to try again.  I scanned the QR code, which set up an entirely new
entry, and that one worked.  This must have been a one-time glitch.
