I dutifully created a GPG key last October, and that was how I got my
Object Collection uploaded to GitHub. I have been unable to do a single
damn thing with GitHub ever since, but I never posted my new
frustrations here before that initial key expired.
Now, the Git push will not accept my new key, which I created under
instruction from GitHub. It keeps asking for my old expired key. I
can't figure out how to get it to accept the new key. I'm effectively
locked out of my GitHub account.
The security seems to be handled by kwallet on my GNU/Linux/KDE system.
I have never been able to figure out how kwallet works.
I DON'T UNDERSTAND HOW ANY OF THIS SHIT WORKS!
Is my life getting easier yet?
hi,
Cousin Ricky <ric### [at] yahoo com> wrote:
> I dutifully created a GPG key last October, ...
on my machines GPG keys are stored in '~/.gnupg/', but I do not use KDE.
regards, jr.
I found that directory. What do I do with it?
I see a couple of files that are time-stamped with the dates from my
first key last October, plus a bunch of other stuff that I don't know
what to do with.
hi,
> what to do with.
I guess you'll also have found the 'gpg' program? you can list keys + could
export the one you need. how you then use that with GitHub, no idea.
regards, jr.
I did not realize such a program existed, but I just checked, and the
program is on my system. I did a gpg -k, and other than my email
address, I have no idea what I'm looking at.
What operating system are you using ?
Are you able to log into to your account via the GitHub web interface ? Here:
https://github.com/your-account-name
If so, then you can go to this page to administrate the SSH and GPG keys
associated with your GitHub account:
https://github.com/settings/keys
You can try to add another key. If you are using Linux or Windows 10/11 or
MacOS, then I suggest that you add a new SSH key to your GitHub account.
A private and a public ssh key can be created e.g. like this both in Linux,
MacOS and a recent Windows 10 (and perhaps in Windows 11):
ssh-keygen -t rsa -b 4096
You need to upload the contents of "id_rsa.pub".
It will be here in Linux:
~/.ssh/id_rsa.pub
- and perhaps here in Windows 10/11:
%USERPROFILE%\.ssh\id_rsa.pub
There's some more information here:
"SSH keypair setup for GitHub (or GitHub/GitLab/BitBucket, etc, etc)"
https://gist.github.com/xirixiz/b6b0c6f4917ce17a90e00f9b60566278
If you have a not-so-recent Windows 10 installation, you may have to enable the
optional OpenSSH client.
Tor Olav
http://subcube.com
https://github.com/t-o-k
hi,
(ah, there you have me. I cannot look at your screen. :-))
I trust you've solved your problem by now, if not:
$ gpg --list-keys
you should see which key you're after by looking at the 3rd (space-separated)
field, the date of creation. its first field should read 'pub'(lic). the
second field is a slash separated compound, use the number after the slash to:
$ gpg --export theNumber > the_file_to_use_on_github
never needed to do this, so check out the export comments re '-armor' option and
sending keys.
<https://www.gnupg.org/gph/en/manual.html>
fwiw, TOK's ""SSH keypair setup for GitHub" link looks v good. had not known
you can use ssh keys too, recommend you switch from 'gpg' to 'ssh' at some point
(easier to use + manage).
regards, jr.
openSUSE Leap 15.5 GNU/Linux
Yes.
Yes. Strangely, is says there are no keys associated with my account.
So where are all those keys I had been setting up through the link that
GitHub emailed to me every month?
I was using GPG because that's what was in the instructions I got from
GitHub after they discontinued password pushing. Are there advantages
or disadvantages to one system over the other?
Thanks for your attention.
Of course not! Whatever gave you that idea? I was just taking a break
from the frustration.
> if not:
> $ gpg --list-keys
----------[BEGIN SCREEN OUTPUT]----------
/home/ricky/.gnupg/pubring.kbx
pub rsa2048 2021-10-06 [SCEA]
SomeBigNumberIDontThinkIShouldPostHere
uid [ultimate] Ricky <my### [at] email address>
sub rsa2048 2021-10-06 [SEA]
-----------[END SCREEN OUTPUT]-----------
The date I'm seeing is for the long-expired key from last October. I
see no sign of the keys that GitHub had me set up since.
I see no slash anywhere in the output.
I guess I'll look into it... I guess. If I switch over, will it confuse
GitHub?
Thanks for trying to help out.
hi,
I have no use for 'gpg' apart from s/ware downloads/installs. but this is what
I see, for the distribution's key:
root@crow:~# gpg --version
gpg (GnuPG) 1.4.21
root@crow:~# gpg --list-keys
/root/.gnupg/pubring.gpg
pub 1024D/40102233 2003-02-26 [expires: 2038-01-19]
uid Slackware Linux Project <sec### [at] slackware com>
sub 1024g/4E523569 2003-02-26 [expires: 2038-01-19]
not sure why the format of the second field differs. sorry.
regards, jr.
> gpg (GnuPG) 1.4.21
> [snip]
My version of gpg is 2.2.27.
Do you normally work as root?
hi,
> > gpg (GnuPG) 1.4.21
still, I'd have expected a comparable output.
no. I had to log in because root is the only account with a '~/.gnupg/' (for OS
updates), it's 'ssh' for everything (and everyone) else.
regards, jr.
hi,
(sorry, just occurred to me)
have you checked whether there are other 'pubring.{kbx,gpg}' files anywhere?
thinking KDE might store stuff in places other than just your user's home. I'd
use 'locate(1)' though 'find(1)' will do.
regards, jr.
> [snip]
OK, I created an SSH key and followed GitHub's instructions for adding
it to my ssh-agent, re-created the remote origin reference on my local
repo, and tried to push again. Git-Cola *still* asked for the damn
expired GPG key.
I guess I'll have to dig out the instructions on how to push from the
CLI, and see if that works. But like I said before, I cannot remember
these commands from one moment to the next; but I do remember that if I
forget a step, or if I omit or get one of the myriad command line
switches wrong, none of it will work.
Is my workflow getting easier yet?
> expired GPG key.
> CLI, and see if that works. [snip]
The push worked from the CLI. Next is to find out why Git-Cola is still stuck
in the past.
> > expired GPG key.
> in the past.
Good.
Do you know what key (GPG or SSH) was being used when it worked from the command
line ?
If it was not the SSH key; did you paste the contents of the id_rsa.pub file
into the key field at this page:
https://github.com/settings/ssh/new
Btw.: I had to google Git-Cola to find out what it is. I wasn't aware that you
use it. I haven't used such GUI tools myself, just the git tools on the command
line and the web interface at github.com.
Tor Olav
http://subcube.com
>>> expired GPG key.
>> in the past.
> Good.
> line ?
It was SSH.
Fortunately, Git-Cola and the CLI work well together. I can switch back
and forth at any time, and the Git repos maintain their integrity.
