POV-Ray : Newsgroups : povray.off-topic : Parametric surfaces with three parameters? Server Time
19 May 2024 02:58:21 EDT (-0400)
  Parametric surfaces with three parameters? (Message 1 to 9 of 9)
Subject: Parametric surfaces with three parameters?
Date: 13 Aug 2018 22:41:39
Message: <5b724163$1@news.povray.org>
Is there a list somewhere of parametric surfaces that take three
parameters? I haven't put a lot of thought into it, but spheres,
cylinders and cones work. Thanks.
Mike
Subject: Re: Parametric surfaces with three parameters?
Date: 13 Aug 2018 22:42:26
Message: <5b724192$1@news.povray.org>
> Mike
Er, I mean solids, not surfaces.
Mike
Date: 13 Aug 2018 23:03:27
Message: <5b72467f$1@news.povray.org>
On 08/13/2018 10:41 PM, Mike Horvath wrote:
> Is there a list somewhere of parametric surfaces, er solids,
It seems to me that a math question would have a more appropriate place
than p.off-topic.
dik
Rendered 344576 of 345600 pixels (99%)
Date: 14 Aug 2018 03:23:31
Message: <5b728373$1@news.povray.org>
> than p.off-topic.
If I could go back in time I would choose a different group.
Mike
Date: 14 Aug 2018 03:23:57
Message: <5b72838d$1@news.povray.org>
>> than p.off-topic.
> Mike
Forgot to add a smiley.
Date: 14 Aug 2018 04:20:33
Message: <5b7290d1$1@news.povray.org>
>> than p.off-topic.
> Mike
Since it is OT
If I could go back in time I would choose a different life.  ;)
Regards
Date: 14 Aug 2018 04:45:02
Message: <5b72968e$1@news.povray.org>
>>> than p.off-topic.
>> Mike
> Since it is OT
I would choose to avoid the million dollar divorce (which was more money
than I had).
dik
Date: 14 Aug 2018 08:25:01
Message: <web.5b72c95d5535509dc437ac910@news.povray.org>
> > parameters?
I toyed with this a while back:
http://news.povray.org/povray.advanced-users/thread/%3Cweb.579fc21ee9f788f45e7df57c0@news.povray.org%3E/
Any parametric surface would become a parametric solid, given a variable third
parameter, since - using the sphere for example, you'd have the r value of the
radius.
Varying the radius from 0 to unity would give you a solid sphere.
But "solids" in POV-Ray are really only surfaces with insides and outsides,
aren't they...?
Date: 14 Aug 2018 17:22:22
Message: <5b73480e$1@news.povray.org>
Am 14.08.2018 um 14:21 schrieb Bald Eagle:
>>> parameters?
> radius.
> aren't they...?
Technically, "solids" in POV-Ray are objects with...
(1a) a well-defined surface,
(1b) an algorithm to compute the intersection points between a ray and
said surface, as well as the surface normals at those points
(2a) a well-defined volume,
(2b) an algorithm to compute whether a given point in 3D space is inside
said volume
3-parametric solids would generally satisfy (1a) and (2a) (except in
pathological cases), but for the general case I guess (1b) and (2b)
would effectively boil down to generating an approximate mesh representaion.
If the 3-parametric equation does not "fold back" into itself, the
surface of the solid can also be modeled using six 2-parametric surfaces.
