POV-Ray : Newsgroups : povray.off-topic : Uh-oh Server Time
16 Oct 2026 10:06:00 EDT (-0400)
  Uh-oh (Message 1 to 35 of 35)
Subject: Uh-oh
Date: 4 Jun 2017 08:36:37
Message: <5933fed5@news.povray.org>
The fan on my computer just became louder, and I thought I detected an
unpleasant smell during my last render.
Looks like I won't be doing any renders until I get the fan replaced.
Subject: Re: Uh-oh
Date: 4 Jun 2017 09:08:59
Message: <5934066b$1@news.povray.org>
Gulp! Good that you caught it early.
Regards
Subject: Re: Uh-oh
Date: 5 Jun 2017 02:49:12
Message: <5934fee8@news.povray.org>
Maybe cleaning away the accumulated dust on the fan will be enough. I
have experienced loud noises before and that was the solution (with
compressed air... carefully).
Subject: Re: Uh-oh
Date: 5 Jun 2017 03:26:53
Message: <593507bd$1@news.povray.org>
I've never thought that using compressed air was a good idea. Unless you
can take the fan out of the machine it just blows it elsewhere. And they
are expensive. I use a clean paintbrush and a vacuum cleaner with an
extension.
About a month ago I noticed a fan on my PC that I had not cleaned for 3
years. It took me over an hour to get access to it and I had to remove
the fan controller. Now one of fans is reporting a speed of zero. The
temperature is okay but I will need to strip the m/c down again to check
it. The fan controller is not very good. (AeroCool Touch-2000)
Regards
Subject: Re: Uh-oh
Date: 5 Jun 2017 05:38:22
Message: <5935268e$1@news.povray.org>
Got it! :-)
The sensor wire was loose in the connector. I didn't notice it until I
was putting it back together.
Regards
Subject: Re: Uh-oh
Date: 5 Jun 2017 07:23:22
Message: <59353f2a$1@news.povray.org>
> extension.
There is that, however it did the trick for me :-) I got rid of the dust
somehow...
Subject: Re: Uh-oh
Date: 5 Jun 2017 07:42:51
Message: <593543bb$1@news.povray.org>
First thing I tried.  Didn't work.
Subject: Re: Uh-oh
Date: 5 Jun 2017 08:22:29
Message: <59354d05$1@news.povray.org>
If it is making a squealing noise. This might be a short term fix.
In the olden days. If you removed the sticky back cover in the centre of
the fan. There was a small hole where you can put a drop of machine oil
on the bearings.
Regards
Subject: Re: Uh-oh
Date: 5 Jun 2017 09:16:54
Message: <593559c6$1@news.povray.org>
> on the bearings.
It's vibrating.  I'm afraid it's going to shake something loose.  I
think it already has.
A replacement can be had for US$12 on Amazon, and I think would be
totally worth it.  The hardest part would be a software guy like me
fiddling with screwdrivers.  I will most likely end up buying from an
off-island supplier who posted a video on how to do the replacement, for
considerably more than $12.  I'd consider it a gratuity for the video.
I'm looking to buy a replacement power cord for them as well.  My
battery won't charge, which is serious, because my backwards third world
country has power outages almost every day.  I've exhausted almost all
local options; the last chance is paying OfficeMax through the nose for
a Genuine Dell power cord, and the remote supplier has 'em cheaper.
(But then there is shipping.)
Subject: Re: Uh-oh
Date: 5 Jun 2017 10:33:24
Message: <59356bb4$1@news.povray.org>
>> on the bearings.
My first guess would be a broken fan blade throwing it off balance. Or
it could be the bearings.
> totally worth it.
Yes, totally, totally. :)
You might consider buying the fan from Amazon and using the video for
instructions. If the Amazon fan is a genuine replacement. That would be
best. If you are not confident doing it yourself. It might be an idea to
ask one of the computer repair shops to do it for the cost of the labour
if you supply the parts.
You mention that your battery not charging, is it a laptop? That might
make a difference to how easy it is to do.
The next bit of advice will have people screaming. I always use a  1/8"
terminal screwdriver instead of a Phillips or crosshead screwdriver.
Because if Dell use propriety screws you will strip/round the head if
you don't have the right type. (Speaking from long experience on this.)
it goes against the grain but it works for me. And buy the cheapest not
the fancy type. They should be about a dollar or 10 bucks for ten.
Something like this:
http://www.ebay.co.uk/itm/Neill-Tools-Terminal-Screwdriver-100mm-Slotted-P18-4-/152480558413
A small shifting spanner (adjustable wrench) on the end acts as a torque
bar to start them off. (It often makes a cracking sound as if the
plastic has broken.)
BTW keep the screwdriver vertical so it does not slip. [Important]
I hope I am not trying to teach you to suck eggs. :)
> a Genuine Dell power cord, and the remote supplier has 'em cheaper. (But
Are you sure it is not the battery? Every one of my laptop batteries has
died the death because I keep my laptop plugged in. They don't like it.
Regards
Subject: Re: Uh-oh
Date: 5 Jun 2017 11:39:08
Message: <59357b1c@news.povray.org>
> extension.
I use compressed air and a vacuum cleaner - hold the hose near where
you're spraying the air, and the dust that's kicked loose gets sucked
into the vacuum.
Jim
"I learned long ago, never to wrestle with a pig. You get dirty, and
besides, the pig likes it." - George Bernard Shaw
Subject: Re: Uh-oh
Date: 5 Jun 2017 12:37:41
Message: <593588d5$1@news.povray.org>
>> extension.
You must be rich. ;)
When I've used compressed air it was from a supply line at about 2 Bar.
Great for drying PCBs after washing them.
> into the vacuum.
Regards
Subject: Re: Uh-oh
Date: 5 Jun 2017 12:53:08
Message: <59358c74$1@news.povray.org>
>>> you can take the fan out of the machine it just blows it elsewhere.
>>> And they are expensive. I use a clean paintbrush and a vacuum cleaner
>>> with an extension.
CostCo, pack of 12 cans for about $40 (just over $3/can).  And I don't
clean my systems often. ;)  I think I've had the current pack (which was
a 6-pack when I got it) for probably 4 years now.
But I also have a powered blower for cleaning computer equipment - it's
kinda noisy, but gets the job done.
Jim
Subject: Re: Uh-oh
Date: 5 Jun 2017 15:42:39
Message: <5935b42f$1@news.povray.org>
> instructions.
That wouldn't be nice.  Besides, it's too late; I ordered one as soon as
they opened for business Monday morning.  (I would have ordered earlier
on-line, but I had questions.  Good thing too, because they had just
gotten an order from Guam, and were still in the process of informing
their computer system that the USA has territories.)  I told them the
video is the reason that I'm paying more for their fan.
But even with shipping, they saved me money on the Genuine Dell power cord.
> best.
The supplier said that with counterfeit parts floating around, I could
never be sure.  But of course she would say that.
I'd do that if they didn't have a 3 week waiting list.
The battery's fine.  It only stopped charging when the computer
complained that it could not recognize the power supply and *told* me it
may refuse to charge the battery.
I've heard that newer computers know when to back off charging the
battery.  After 4 years, mine shows no sign of discharging abnormally.
(The battery in my last laptop crapped out after 5 years, and I could
see the deterioration over the last couple of years.)
Web searches all point to the power cord being the culprit for my symptoms.
Subject: Re: Uh-oh
Date: 5 Jun 2017 17:23:49
Message: <5935cbe5$1@news.povray.org>
>> instructions.
Gosh! An American with a sense of honour. You are a dying breed. ;)
(Sorry, could not resist. :) )
I suppose you must be used to that sort of thing.
> I told them the
Good feedback.
>> best.
Naturally, but it is true.
Did not think of that. :(
Grrr! That really annoys me. Sometimes it seems more cost effective to
buy a new printer than to buy a genuine replacement ink cartridge. But
being the toerag I am. I will go out of my way to cheat them and save
the planet. That behaviour is immoral imo.
Good, I am pleased to hear that. :D
A plug, two wires and a connector, would you believe it? Worse than Apple.
But I am glad you have been sorted out.
Regards
Subject: Re: Uh-oh
Date: 5 Jun 2017 17:38:29
Message: <5935cf55$1@news.povray.org>
You would be hard pushed to get a half pint of beer in a London pub for
$3. :)
> And I don't
> clean my systems often.;)
Shame on you. :)
But then if you leave them long enough. They reach a point where they
don't get any worse. ;)
That must be good for your allergies. ;)
Regards
Subject: Re: Uh-oh
Date: 5 Jun 2017 17:41:13
Message: <5935cff9$1@news.povray.org>
> $3. :)
Well, these days, probably not quite as hard-pushed as a year ago, given
the exchange rate. ;)
>> And I don't clean my systems often.;)
> Shame on you. :)
True.  I'm allergic to dust mites, though, which is why I tend to avoid
doing it.  Also, now that we don't have cats, it's just dust and not hair
+ dust.
>> I think I've had the current pack (which was a 6-pack when I got it)
Indeed, that's why I also use a vacuum.  I have a little kit of
attachments for cleaning electronics as well, though a good vacuum
generally has enough suction that the dust isn't too much of a problem.
It's more about "downtime" - which for personal systems is silly.  I just
don't like shutting things down. :)
Subject: Re: Uh-oh
Date: 7 Jun 2017 20:05:53
Message: <593894e1$1@news.povray.org>
The parts came in yesterday.
The computer does not recognize the Genuine Dell power cord.  I need to
figure out what's going on here.  This third world rock I live on had 5
(not a typo) power outages this morning, and my battery is down to 38%.
One of the screw heads was already stripped, and another screw is in so
tight I'm afraid I'd strip it if I try to loosen it.  And most of the
advice on the Web for dislodging stuck Phillips head screws looks like
it would destroy my computer.
What exactly is a terminal screwdriver?  I see them for sale on the Web,
but I can't find a definition.
I find myself late at night poring over renders from years past.  I miss
POV-Ray!
Subject: Re: Uh-oh
Date: 8 Jun 2017 01:57:55
Message: <5938e763$1@news.povray.org>
My best advice now would be to contact Dell.
Good luck with that from what I've heard about them. (Mostly from Andrew
when he was his companies IT rep.)
I believe you about the outages. :(
As for "third world rocks". I tried to access this site:
https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&cad=rja&uact=8&ved=0ahUKEwiT0qSjsq3UAhXiAsAKHdaVDvMQFghJMAU&url=https%3A%2F%2Fwww.wihatools.com%2Finsulated-tools%2Fscrewdrivers%2Fterminal-block&usg=AFQjCNGsHec43_6uI7IVZDvta5zq4XMJWA&sig2=0wn5oN6InKirjBccKRgdKQ
And got this message:
We have redirected you
Based on the IP address that visited www.wihatools.com
We only ship to the Continental United States and Hawaii
Would this apply to you?
Just had a thought. Could your line voltage be low. (A shot in the dark.)
Could you plug it into another outlet in a different building?
A lot of companies secure their screws with something like loctite.
Supposedly to stop them vibrating loose. But since they are self tappers
it must be for anti tamper reasons. You need to break the bond. So apply
a strong downward pressure as you rotate the screwdriver. Making sure
that the screwdriver does not deviate from the vertical. It loosens with
a loud crack.
But see what Dell says first.
Nor can I, it must be obvious. I guess that it is a screwdriver for
working on industrial terminal blocks. That is when I first came across
the term.
> POV-Ray!
I think we all sympathise. It is a major addiction.
Regards
Subject: Re: Uh-oh
Date: 8 Jun 2017 11:28:57
Message: <59396d39$1@news.povray.org>
On Thu, 08 Jun 2017 06:57:50 +0100, Stephen wrote:
> (Mostly from Andrew when he was his companies IT rep.)
Speaking of, has anyone heard from him recently?  I don't recall seeing
any posts from him here recently.
Subject: Re: Uh-oh
Date: 8 Jun 2017 12:50:20
Message: <5939804c$1@news.povray.org>
Not me. He must have gotten a life. :)
Regards
Subject: Re: Uh-oh
Date: 8 Jun 2017 13:21:51
Message: <593987af$1@news.povray.org>
If so, that's good for him. :)
Subject: Re: Uh-oh
Date: 8 Jun 2017 13:30:45
Message: <593989c5@news.povray.org>
Yes. :)
Regards
Subject: Re: Uh-oh
Date: 8 Jun 2017 17:24:20
Message: <5939c084$1@news.povray.org>
>>>> seeing any posts from him here recently.
> Yes. :)
We'll just need a new mascot, and someone to bring up Haskell-related
topics.
Jim
Subject: Re: Uh-oh
Date: 9 Jun 2017 03:02:48
Message: <593a4818$1@news.povray.org>
>> Yes. :)
> topics.
That rules me out. ;)
Regards
Subject: Re: Uh-oh
Date: 9 Jun 2017 11:30:07
Message: <593abeff$1@news.povray.org>
>>> Yes. :)
>> topics.
LOL
Subject: Re: Uh-oh
Date: 13 Jun 2017 12:52:47
Message: <5940185f$1@news.povray.org>
News via Facebook from Cousin Ricky:
Ouch. My computer fan is now fully busted, so no rendering, and the
newsgroup software won't log me in on my phone (most of the time it
wouldn't work on my computer either), so I have no way of communicating
directly with the POV-Ray community.
the suggested tool to fix the fan is unavailable on my island, and
neither of the on-line stores posted will ship here, so it's gonna be a
while before you hear from me.
=== end of message (edited for transmission)
Subject: Re: Uh-oh
Date: 13 Jun 2017 13:20:00
Message: <web.59401de2b6e1f84dc437ac910@news.povray.org>
Sounds like the magic smoke is gone that makes the fan work.
I doubt it would be "affordable", but maybe if I got details on the model /
specs of his fan, I could dig up one or 6 of them over here and see how much
shipping is to ... whatever island paradise he's sipping drinks on.
Maybe he can temporarily just sort of duct an exterior fan into the case for
short periods...
Subject: Re: Uh-oh
Date: 13 Jun 2017 14:32:52
Message: <59402fd4@news.povray.org>
It is the American Virgin Islands not Jamaica. ;)
> short periods...
His battery was not charging either. And he seems to have forgotten that
you can use the Web view on your phone.
But then he is probably feeling as sick as a pig and not thinking straight.
Regards
Subject: Re: Uh-oh
Date: 13 Jun 2017 15:20:00
Message: <web.59403a0eb6e1f84dc437ac910@news.povray.org>
Somehow, I'm not going to cry for him.
The last island I got to go to was Loon Island.
Not a word.
Not a single word, Frog-Licker.
( ͡ᵔ ͜ʖ ͡ᵔ )
Hmm.
Batteries are definitely known to go bad.
We have boxes upon boxes of dead laptop batteries that are destined for sale to
someone doing lithium reclamation.
We had a power outage / one leg of the 3-phase power, and when the transformer
got repaired, my work laptop wasn't charging - so it must have fried the
battery.
https://www.myus.com/vir/
looks like it's about $15/lb to ship to there.
Subject: Re: Uh-oh
Date: 13 Jun 2017 15:35:00
Message: <web.59403e58b6e1f84dc437ac910@news.povray.org>
I unhooked myself from FZuckerberg's creepy site years ago.
http://www.bbc.com/news/business-39947942
http://jimlynch.com/internet/facebook-users-work-for-zuckerberg-for-free/
Subject: Re: Uh-oh
Date: 13 Jun 2017 16:40:14
Message: <59404dae$1@news.povray.org>
Well I live on a large Island myself. An archipelago if you want to be
pedantic. They have problems different from living on continents.
> Not a word.
I prefer pharmaceuticals or herb.
And in Doric (NE of Scotland dialect) a loon is a young man. As in Fit
like m' loon/quine? (How are you my young man/girl?)
> ( ͡ᵔ ͜ʖ ͡ᵔ )
Ooo! Get you with your ricky ticky Dongers. ;)
> Hmm.
They do indeed. But his laptop did not recognise his new power cable as
being a genuine Dell part. Which smells of a propriety circuit somewhere
in his machine that is goosed.
> battery.
Or the charging circuit.
But then he would have to strip his laptop and fit it. He did say that
he was a programmer. With all that implies. ;)
Regards
Subject: Re: Uh-oh
Date: 13 Jun 2017 16:51:52
Message: <59405068$1@news.povray.org>
[Smug face] I never joined in, in the first place. :D
I could never understand why you would want to tell everyone when you
went to the shops or the toilet. No that is twatter. ;)
OMG There is an actual site called twatter. How rude. :)
Regards
Subject: Re: Uh-oh
Date: 13 Jun 2017 17:00:01
Message: <web.594051bab6e1f84dc437ac910@news.povray.org>
https://en.wikipedia.org/wiki/Loon
> > ( ͡ᵔ ͜ʖ ͡ᵔ )
:O  Stephen!  That sounded _naughty_.
And on the Interwebs, no less.
Yeah, those suck.
Nope.  Popped in a different battery, and it was good as used.
Well, yeah.  But maybe he has helpers who could do that part for him.
Subject: Re: Uh-oh
Date: 13 Jun 2017 17:31:06
Message: <5940599a$1@news.povray.org>
http://www.bbc.co.uk/programmes/b03mzv9d
>>> ( ͡ᵔ ͜ʖ ͡ᵔ )
:) It does indeed, if you have that sort of mind. :P
But no more bonny lad (NE England dialect).
> Yeah, those suck.
It does and should be made illegal.
Come the day that I rule the world...
Even if he had to pay for it. Gasp! :)
Regards
