POV-Ray : Newsgroups : povray.off-topic : Spectral locus Server Time
15 Jun 2026 08:36:01 EDT (-0400)
  Spectral locus (Message 16 to 25 of 25)
Subject: Re: Spectral locus
Date: 13 Mar 2017 20:00:02
Message: <58c73282$1@news.povray.org>
On 3/13/2017 5:19 PM, clipka wrote:
> Am 13.03.2017 um 20:12 schrieb Mike Horvath:
>>> "This data set gives wavelengths every 1.0 nm, along with the associated
>>> CIE xyz values for the spectral locus of the 1931 CIE chromaticity
>>> diagram. They are called xyz values here as they are called that in the
>>> original source, but they are also known as xyY or XYZ values."
>> I'm also assuming the data set will produce a 3D shape. Is that right?
> Not really.
> What the data set will give you (if you connect the dots) is a line in
> 2D space, namely the famous CIE "horseshoe".
> To get a 3D shape from that, you'll first have to identify what you
> really want to plot.
> For example, the entire CIExyY colour space would be just an extrusion
> of that horseshoe along the Y axis, stretching to positive infinity, as
> there is no theoretical limit on brightness (for practical purposes at
> any rate): The extruded horseshoe itself would represent the locus of
> all theoretically possible monochromatic colours (i.e. colours comprised
> of only a single wavelength of light), while the volume it encompasses
> would represent the locus of all theoretically possible polychromatic
> colours.
> On the other hand, the locus of all theoretially possible pigment
> colours as illuminated by a particular light source is a much more
> complex construct, and creating its shape requires some smart ideas, as
> the volume of that shape is effectively a projection from
> infinite-dimensional space (each dimension corresponding to the
> pigment's reflectivity at a particular wavelength) to 3-dimensional
> CIExyY space.
> That locus may even differ between light sources with identical CIExyY
> whitepoint coordinates, as it depends on the spectrum of the light
> source, and different spectra may still result in identical CIExyY
> coordinates (see "metamerism").
> This is precisely the project for which I did a series of animations a
> while ago.
Are things as simple as using these formulas?
http://www.brucelindbloom.com/index.html?Eqn_Spect_to_XYZ.html
I forgot how to do calculus integrals and sums, but if I'm on the right
track I can try to re-learn.
Mike
Date: 13 Mar 2017 23:06:53
Message: <58c75e4d$1@news.povray.org>
Am 2017-03-13 12:30, also sprach clipka:
> Am 13.03.2017 um 11:17 schrieb Mr:
>>> But remember that I have to take my socks off to count past 10. :)
>> :-D !
>> I thought POVers used only binary ?
> Why, no, of course they don't. POV-Ray only deals in floating-point
> numbers, not binary integers ;)
That's right. Even boolean is 64 bits and has a mantissa!
true == 3ff0 0000 0000 0000
dik
Date: 14 Mar 2017 04:23:40
Message: <58c7a88c$1@news.povray.org>
Am 14.03.2017 um 01:00 schrieb Mike Horvath:
>> CIExyY space.
>> while ago.
As the page already mentions, in practice you'll be doing sums rather
than integrals.
For an equal-energy(*) light source (emitting all wavelengths at the
same intensity), the "compute CIE XYZ coordinates for this particular
spectrum" is indeed that simple.
(* Actually, "equal-power" would be a more fitting term, but
"equal-energy" has stuck.)
For any other light source, the terms in the sum get just a little more
complicated, as you have to multiply them with a factor representing the
light source's emissive power at that corresponding wavelength.
Remember to convert from XYZ to xyY afterwards, using x=X/(X+Y+Z),
y=Y/(X+Y+Z).
The tricky part, at least for me, was to figure out what spectra would
end up on the surface of the resulting shape, and how to connect them
into a mesh.
Date: 14 Mar 2017 16:18:24
Message: <58c85010$1@news.povray.org>
On 3/13/2017 4:23 PM, clipka wrote:
> Am 13.03.2017 um 20:09 schrieb Mike Horvath:
>> Translator needed:
>> https://en.wikipedia.org/wiki/Talk:Lab_color_space#CIELAB_images_in_article
>> The guy I'm talking to here is German, and I don't understand what he's
>> talking about. Would someone care to translate for me? Thanks.
> Unfortunately he's trying to write English, so I'd have to guess as well
> -- even though I'm also German.
> BTW, his use of the word "remission" actually seems to be closer to the
> English use than to the German one:
> https://en.wikipedia.org/wiki/Remission_(spectroscopy)
> Whereas (according to Wikipedia) the English spectroscopy term
> encompasses both diffuse /and/ specular reflection, the corresponding
> German term ("Remission") seems to refer only to the diffuse component.
Do you have an idea what those images are supposed to show? Is it the
spectral locus? I've only plotted the sRGB gamut so far (which is shaped
like a skewed cube), not the spectral locus.
Mike
Date: 15 Mar 2017 07:27:06
Message: <58c9250a$1@news.povray.org>
Am 14.03.2017 um 21:18 schrieb Mike Horvath:
Before I can answer that question, we may have to first agree on a
definition of "spectral locus".
According to my understanding of the Wikipedia article on "spectral
color", the "spectral locus" would be the locus of all monochromatic
colours, i.e. colours comprised of only a single wavelength.
In a 2D chromaticity space (a "colour" space that does not care about
absolute brightness) such as CIE xy, that would be the famous "horseshoe".
In a 3D colour space, it would be an extrusion of that horseshoe, traced
on an arbitrary locus of equal brightness in that colour space, extruded
along paths of constant chromaticity, up to the locus of zero brightness
in one direction and up to the locus of infinite brightness, in the other.
For example, in CIE xyY colour space it would be a "cylinder-ish" shape
(having a cross-section identical with the familiar CIE horseshoe
shape), oriented along the L axis, starting at L=0 and extending to
infinity.
On the other hand, in an RGB colour space it would instead be a
"cone-ish" shape (with a cross-section also reminiscient of the CIE
horseshoe, albeit possibly distorted depending on the angle at which you
cut), encompassing the positive legs of all colour axes, with its apex
at R=G=B=0 and extending to infinity.
According to that definition, the images are clearly /not/ supposed to
show the spectral locus.
Instead, from what the other guy is writing, it is my understanding that
the images are /supposed/ to show the locus (or rather, selected points
from that locus' boundary) of all possible /pigment colours/, under a
poorly defined illuminant (from the description my guesses would be E,
the equal-energy illuminant), in CIE L*a*b colour space whith a poorly
defined whitepoint (my guess would be D65 or D50).
The side view looks reasonably convincing (I don't recall ever having
plotted this shape in CIE L*a*b space). Note that towards L=0 the locus
appears to converge to (*a,*b)=(0,0), which seems to agree with the
mathematical definition of the colour space.
The top view, on the other hand, has some features that make me
suspicious; but they might just be artefacts resulting from a different
scaling along the L axis than used for the side view, or I might be
seeing ghosts.
Date: 17 Mar 2017 12:16:14
Message: <58cc0bce$1@news.povray.org>
Is it appropriate to use the word "gamut" to describe the visible
spectrum? Or should it be restricted to things like sRGB or CMYK?
Mike
Date: 17 Mar 2017 13:07:56
Message: <58cc17ec@news.povray.org>
Am 17.03.2017 um 17:16 schrieb Mike Horvath:
Typically the term "gamut" is used to denote the subset of colours that
can be reproduced by a given /device/ or /process/ (or, by extension, a
certain standard for such devices or processes).
You could argue that the shape you're currently trying to depict is the
gamut of all theoretically possible pigments or colour filters under a
given illuminant; I guess you might also call this the gamut of the
given illuminant itself.
As for whether the word "gamut" would be appropriate to describe "the
visible spectrum", I have a hunch that you may not actually mean "the
visible spectrum" but a related yet different concept.
"The visible spectrum" is not a set of colours, but rather a range of
wavelengths of electromagnetic radiation.
Even "a spectrum" (in the sense of power as a /function/ of wavelength)
is not a colour (in the sense used in conjunction with the term "gamut",
i.e. a particular visual stimulus), but rather /corresponds to/ a
colour, with multiple spectra corresponding to the same colour (metamerism).
Date: 17 Mar 2017 16:45:13
Message: <58cc4ad9$1@news.povray.org>
This makes sense, thanks.
Good to know, thanks.
Mike
Date: 23 Mar 2017 18:31:14
Message: <58d44cb2@news.povray.org>
On Wikipedia I described one of my images like this: "Visible gamut
under D65 illumination plotted within the CIELUV color space. u and v
are the horizontal axes; L is the vertical axis."
Would it be better to say "projected" instead of "plotted"? Are there
any other issues with wording?
Thanks.
Mike
Date: 24 Mar 2017 17:38:18
Message: <58d591ca$1@news.povray.org>
Am 23.03.2017 um 23:31 schrieb Mike Horvath:
Looks ok to me. "Plotted" should be clear enough.
