POV-Ray : Newsgroups : povray.off-topic : WebGL Server Time
16 Oct 2026 12:43:07 EDT (-0400)
  WebGL (Message 1 to 28 of 28)
Subject: WebGL
Date: 5 Jun 2016 10:05:26
Message: <575431a6$1@news.povray.org>
Hey guys. Remember this?
http://madebyevan.com/webgl-path-tracing/
Yeah, well now there's this:
http://jonathan-olson.com/tesserace/tests/3d.html
Firstly, it looks a bit less like a computer simulation and more like
the Real World. Only a bit, but hey.
My favourite feature is that you can adjust the lens aperture and focus
distance. I was just wondering whether you could accurately simulate
depth of field using path tracing! Now we just need to be able to change
the focal length of the lens too... (There are also options for
adjusting the exposure.)
For a camera nerd, this is quite fun! (Well, it beats Nikon's "lens
simulator", which just shows a static JPEG with variable magnification!)
Sometimes I really wish I knew how to do this stuff for myself...
What *would* be interesting is to see how this handles a scene of
non-trivial complexity. I'm going to say "like a glacier"...
Subject: Re: WebGL
Date: 5 Jun 2016 10:11:27
Message: <5754330f$1@news.povray.org>
...well, there is this:
http://reindernijhoff.net/2015/04/realtime-webgl-path-tracer/
Granted, it's grainy as *hell*, but at a tiny resolution it's watchable.
Maybe give it ten years, and the GPU will have enough horsepower for
people to actually put this stuff in game engines.
Maybe.
Subject: Re: WebGL
Date: 6 Jun 2016 08:36:10
Message: <57556e3a@news.povray.org>
Follow a tutorial on WebGL - or if you want to skip all the html/js
boilerplate stuff you'll need to know, go straight to something like
shadertoy. There are plenty of examples, and shadertoy now supports
reading back pixels from previous frames, so you can do
multi-frame-averaging for path-tracing amongst other effects.
Building a lens simulator (with real-time path-traced results) sounds
feasible and very interesting.
Subject: Re: WebGL
Date: 8 Jun 2016 13:06:27
Message: <57585093$1@news.povray.org>
Well, I went to the ShaderToy website... and discovered that apparently
Opera has WebGL support that's flaky as *hell*! The number of times I
have to close and reopen the browser to turn WebGL back on...
Some of the shaders on offer are absurd. I saw one that was a real-time
simulation of waves crashing on a giant sea... fractal wave
distribution, subsurface scattering, specular highlights... and wondered
why the hell they don't put this in games yet!
But mostly, attempting to browse the shaders just broke Opera.
After about an hour of squinting at the sparse ShaderToy documentation
and making some educated guesses, I did eventually manage to build a
trivial ray-tracer that runs in real-time. I have no idea how to do
random number generation yet, but we'll see...
Subject: Re: WebGL
Date: 9 Jun 2016 03:11:22
Message: <5759169a$1@news.povray.org>
Come on, make it public and post the link then for all to see :-)
I had a bit more of a think about how you might do a lens simulation.
You start by firing the ray from a random point within the pixel on the
sensor, and fire it at a random point on the surface of the first lens
element. Then follow that ray through the lenses (assume no reflection
for speed here), if it gets too far from the lens axis then return
black, otherwise once it gets out of the end of the lenses and into the
scene do the raytrace as normal.
With the above you should be able to move about individual lens elements
in almost real time (it might take a second or two to smooth out the noise).
Yes that is tricky, but I'm sure you've already looked at other shaders
there to see how they do it. Something involving the sine of the
coordinates multiplied by some huge value IIRC.
Subject: Re: WebGL
Date: 9 Jun 2016 13:53:43
Message: <5759ad27$1@news.povray.org>
I'm sure you've all seen a white sphere with some coloured lights. :-P
> noise).
That sounds quite complex. (In particular, it seems to require me to
actually design a real lens assembly, and implement real refraction.)
I was thinking more along the lines of a camera entity that fires rays
in a pattern that matches a theoretical ideal lens. But I need to figure
out the equations for that first...
Yeah, not just a random number per pixel, but *multiple* random numbers!
Multiple, statistically-independent numbers... This is not trivial.
Subject: Re: WebGL
Date: 9 Jun 2016 14:00:16
Message: <5759aeb0$1@news.povray.org>
Yesterday I had another go at this, and hit a show-stopping snag: No
flow control.
It seems that implementing reflection is essentially impossible. You
can't do recursive functions. You can't do arrays. [Well, you can... but
the array indices must be known at compile-time, thus negating all
possible advantages of arrays.] You can't do while-loops with
complicated break or continue conditions. You can't do function
pointers... In short, it seems that all code jumps and data accesses
must be statically known at compile-time.
Obviously, the rendering equation is inherently recursive. You fire a
ray, which spawns further rays with are recursively traced like the
first one. But without the ability to dynamically trace different
primitives differently, or apply different surface characteristics
dynamically, or basically do *anything* dynamically... You end up
basically needing to write some kind of engine to *generate* the WebGL
code, hard-coded to the particular geometry of your scene.
I see now why no computer game will ever use this technology. It's fast
because it's *completely inflexible*.
I am now baffled as to how all the *other* people managed to do so much
cool stuff in a language that abhors conditional branching... Clearly
I'm going to have to cheat and look at the source code. But I fear I
won't be able to comprehend any of it.
In summary, it appears that implementing reflection is mathematically
impossible. I may perhaps still be able to realise my dream of rendering
depth of field effects realistically. (Although without a nice detailed
scene to look at, it might be rather disappointing...)
Subject: Re: WebGL
Date: 9 Jun 2016 14:46:06
Message: <5759b96e$1@news.povray.org>
OK, here ya go:
struct Ray
     vec3 S, D;
vec3 RayPoint(in Ray ray, in float t)
     return ray.S + ray.D*t;
Ray Camera(in vec2 uv)
     Ray ray;
     ray.S = vec3(0, 0, -5);
     ray.D = vec3(uv.x, uv.y, 1);
     return ray;
struct Sphere
     vec3 C;
     float R;
     float R2;
Sphere MakeSphere(vec3 center, float radius)
     return Sphere(center, radius, radius*radius);
float IsectSphere(in Ray ray, in Sphere sphere)
     // (P - C)^2 = r^2
     // (P - C)^2 - r^2 = 0
     // ((Dt + S) - C)^2 - r^2 = 0
     // (Dt + S - C)^2 - r^2 = 0
     // (Dt + V)^2 - r^2 = 0
     // D^2 t^2 + 2DVt + V^2 - r^2 = 0
     vec3 V = ray.S - sphere.C;
     float a = dot(ray.D, ray.D);
     float b = 2.0*dot(V, ray.D);
     float c = dot(V, V) - sphere.R2;
     float det = b*b - 4.0*a*c;
     if (det >= 0.0)
         return (0.0 - b - sqrt(det))/(2.0*a);
     else
         return -1.0;
float Illuminate(vec3 light, vec3 surface, vec3 normal)
     vec3 d = light - surface;
     return dot(normalize(d), normalize(normal));
vec2 MapScreen(vec2 xy)
     return (xy - iResolution.xy/2.0) / iResolution.y;
vec2 MapScreenExact(vec2 xy)
     return (xy - iResolution.xy/2.0) / iResolution.xy;
void mainImage( out vec4 fragColor, in vec2 fragCoord )
     Sphere s1 = MakeSphere(vec3(MapScreenExact(iMouse.xy)*4.0, 0), 1.0);
     vec3 l1 = vec3(-5, +5, -3); // Red
     vec3 l2 = vec3(+5, +5, -3); // Green
     vec3 l3 = vec3( 0, -5, -3); // Blue
     Ray cr = Camera(MapScreen(fragCoord.xy));
     float t = IsectSphere(cr, s1);
     if (t > 0.0)
         vec3 surface = RayPoint(cr, t);
         vec3 normal = surface - s1.C;
         float b1 = Illuminate(l1, surface, normal);
         float b2 = Illuminate(l2, surface, normal);
         float b3 = Illuminate(l3, surface, normal);
         fragColor = vec4(b1, b2, b3, 1);
     else
         fragColor = vec4(0, 0, 0, 0);
Copy & paste into the ShaderToy website and hit Go. You can click on the
image to move the sphere around. (It doesn't follow your cursor exactly
because of the perspective transformation.)
Subject: Re: WebGL
Date: 10 Jun 2016 02:59:11
Message: <575a653f$1@news.povray.org>
Obviously it's not, because there are plenty of shadertoy examples
showing it:
https://www.shadertoy.com/view/4ssGWX
Surfaces that reflect *OR* refract are trivial:
for(i=0;i<MAX_TRACE_DEPTH;i++)
   intersect = Trace( ray );
   if( REFLECT(intersect) ) ray = ReflectRay(ray , intersect);
   if( REFRACT(intersect) ) ray = RefractRay(ray , intersect);
To do surfaces that do both you need to choose randomly at each
intersection which ray to follow (weighted appropriately depending on
the material) and then average over a larger number of samples. You can
either do many samples per frame (but obviously this gets slow for
complex scenes), or what is commonly done is to average over many frames
(and reset the average if the camera is moved). Or both.
Subject: Re: WebGL
Date: 10 Jun 2016 03:23:54
Message: <575a6b0a@news.povray.org>
> showing it:
Interesting. On my browser, that just crashes.
The difficulty is figuring out what surface was hit just from the
intersection coordinates. And perhaps a perfect reflection isn't so
hard, but I wanted to have the colour change slightly on each
reflection... but I can't figure out how to stack up the colour changes
until you get to the end of the reflection chain, and then unstack them
again.
Still trying to work out how you "average over several frames".
ShaderToy is great fun, but so *utterly* undocumented... it's quite hard
to figure out how to do anything.
Subject: Re: WebGL
Date: 10 Jun 2016 03:28:32
Message: <575a6c20$1@news.povray.org>
> OK, here ya go:
Welcome to the dark side...   :-)
Subject: Re: WebGL
Date: 10 Jun 2016 03:33:33
Message: <575a6d4d$1@news.povray.org>
Yes I realised that later too, Google didn't seem to throw up any real
data on proper lens design (for pretty obvious reasons), only very
simple examples. Still it might be interesting, and you never know if
you made it slick enough one of the big lens manufacturers may show some
interest in you or your code.
Look through the POV source? :-)
Exactly, poor RNGs in these sorts of things can cause some bizarre
artefacts.
Subject: Re: WebGL
Date: 10 Jun 2016 03:50:04
Message: <575a712c$1@news.povray.org>
>> showing it:
Odd. But then you did say half the examples on shadertoy didn't work on
whatever browser you had. Tried Chrome/IE?
You could have an intersection struct with surface normal and material
ID in it as well.
> again.
You need to keep track of a "cumulative coefficient of reflection" value
as you go (make it a vec3 if you want coloured reflections):
vec3 CCOR = vec3(1,1,1);
vec3 colour = vec3(0,0,0);
for(int i=0;i<MAX_TRACE_DEPTH;i++)
   isect = Raytrace();
   colour += CCOR * isect.diffuse_colour;
   CCOR *= isect.reflection_colour;
Subject: Re: WebGL
Date: 10 Jun 2016 14:03:43
Message: <575b00ff$1@news.povray.org>
Yeah, it seems the smaller examples run just fine, but bigger ones freak
it out. In particular, browsing the shaders seems to try to run too many
shaders at once and break Opera. (And once it's broken, only restarting
the browser will fix it. It just doesn't *try* any more.)
> ID in it as well.
Material ID is something I hadn't thought of. (I'm trying to do a
checkerboard for the ground, which makes calculating the colour...
interesting.)
> isect = Raytrace();
I'm thinking about the associative/distributive property of the reals,
though... If one object adds 4% blue and then reflects 95%, and the next
object adds %6 yellow and reflects 50%, and the final object is green,
you need
   ((green * 50%) + 6% yellow) * 95% + 4% blue
but the algorithm above gives
   ((4% blue * 95%) + 6% yellow) * 50% + green
which I don't think simplifies to the same result. You'd have to neither
trace all the rays backwards (i.e., from scene to camera), which is
laughably inefficient, or somehow store a history (array?) of all the
intermediate steps so you can reverse them...
...then again, I think I'll just give up on reflection, and see if I can
make the lens work with a checkerboard. :-P
Subject: Re: WebGL
Date: 10 Jun 2016 14:06:39
Message: <575b01af$1@news.povray.org>
Pfft. I doubt anything I'll ever do will be "slick". But maybe I can
make something interesting.
(Would be nice if ShaderToy would let you add sliders to control your
shader!)
Any idea where in the 25,000,000 LoC I should start looking?
(You never know, maybe there's a file named camera.c or something...)
> artefacts.
There's a couple of StackOverflow questions about this. It seems the
best results are obtained by using an integer hash function... yet
ShaderToy seems to not support bitwise integer operations, so that's
kind of not an option.
That said, there's a widely used sin-based method, which gives awful
results. But if you iterate it a few times... it's not *too* bad.
Still waiting on how you average consecutive frames.
Subject: Re: WebGL
Date: 10 Jun 2016 14:10:01
Message: <575b0279$1@news.povray.org>
There is, in fact, a camera.cpp file.
OMG, look at this:
/// POV-Ray is based on the popular DKB raytracer version 2.12.
/// DKBTrace was originally written by David K. Buck.
/// DKBTrace Ver 2.0-2.12 were written by David K. Buck & Aaron A. Collins.
I am *almost certain* that the man I bought my flat from was called
Aaron Collins... o_O
Subject: Re: WebGL
Date: 12 Jun 2016 08:02:44
Message: <575d4f64$1@news.povray.org>
OK, I think I've cracked it:
If you click the "new tab" button, it gives you another shader, that
renders to Buffer A. If you then set iChannel0 to be Buffer A, you can
do a texture2D(iChannel0, coords) to read the previous frame's pixel value.
Now you just need to set the main image shader to be a texture2D()
lookup on Buffer A, and you're golden.
Not what you'd call "obvious"...
Subject: Re: WebGL
Date: 12 Jun 2016 09:30:09
Message: <575d63e1$1@news.povray.org>
Sadly, it contains the data structures for *describing* the camera, but
nothing whatsoever to do with *casting rays*.
It seems *that* is in tracepixel.cpp. Looking into it further, it seems
that TracePixel::CreateCameraRay() has a giant switch-block for every
possible camera type, but they all end with JitterCameraRay(). This,
seemingly, is where the focal blur stuff happens.
In full:
void TracePixel::JitterCameraRay(Ray& ray, DBL x, DBL y, size_t ray_number)
     DBL xjit, yjit, xlen, ylen, r;
     Vector3d temp_xperp, temp_yperp, deflection;
     r = camera.Aperture * 0.5;
     Jitter2d(x, y, xjit, yjit);
     xjit *= focalBlurData->Max_Jitter * 2.0;
     yjit *= focalBlurData->Max_Jitter * 2.0;
     xlen = r * (focalBlurData->Sample_Grid[ray_number].x() + xjit);
     ylen = r * (focalBlurData->Sample_Grid[ray_number].y() + yjit);
     // Deflect the position of the eye by the size of the aperture, and in
     // a direction perpendicular to the current direction of view.
     temp_xperp = focalBlurData->XPerp * xlen;
     temp_yperp = focalBlurData->YPerp * ylen;
     deflection = temp_xperp - temp_yperp;
     ray.Origin += deflection;
     // Deflect the direction of the ray in the opposite direction we
deflected
     // the eye position.  This makes sure that we are looking at the
same place
     // when the distance from the eye is equal to "Focal_Distance".
     ray.Direction *= focalBlurData->Focal_Distance;
     ray.Direction -= deflection;
     ray.Direction.normalize();
Good luck *ever* figuring out what the hell any of it means, of course...
Subject: Re: WebGL
Date: 12 Jun 2016 09:48:33
Message: <575d6831$1@news.povray.org>
On 12/06/2016 02:30 PM, Orchid Win7 v1 wrote:
> In full:
> // Deflect the direction of the ray in the opposite direction we deflected
> // the eye position. This makes sure that we are looking at the same place
I'm not entirely sure why that method is so complicated, but it
*appears* the key part of the algorithm is this:
ray.Direction *= focus_distance;
The aperture determines the maximum size of deflection, and the focus
distance is mentioned above. Plugging these two into my shader, I seem
to be able to get it to produce blurry images focused at a specific
distance.
Subject: Re: WebGL
Date: 12 Jun 2016 09:53:22
Message: <575d6952@news.povray.org>
> distance.
In case anybody cares:
float Rand(vec2 v)
     return fract(sin(dot(v.xy ,vec2(12.9898,78.233))) * 43758.5453);
float Rand(vec4 v)
     float a = Rand(v.xy);
     float b = Rand(v.zw);
     vec2 ab = vec2(a, b);
     float c = Rand(ab * v.xy);
     float d = Rand(ab * v.zw);
     vec2 cd = vec2(c, d);
     return Rand(ab * cd);
struct Ray
     vec3 S, D;
     Ray ray;
     ray.D = vec3(uv.x, uv.y, 1.0);
     const float Aperture = 0.2;
     const float FocusDistance = 18.0;
     float r1 = Rand(vec4(uv, 0, iGlobalTime));
     float r2 = Rand(vec4(uv, 1, iGlobalTime));
     float r3 = Rand(vec4(uv, 2, iGlobalTime));
     vec3 deflection = vec3(r1, r2, 0);
     deflection = Aperture*deflection;
     ray.S += deflection;
     ray.D *= FocusDistance;
     ray.D -= deflection;
     ray.D = normalize(ray.D);
     return ray;
struct Plane
     vec3 N;
     float D;
float IsectPlane(in Ray ray, in Plane plane)
     // NP = d
     // NP - d = 0
     // N(Dt + S) - d = 0
     // ND t + NS - d = 0
     // ND t = d - NS
     // t = (d - NS)/ND
     return (plane.D - dot(plane.N, ray.S)) / dot(plane.N, ray.D);
struct Sphere
     vec3 C;
     float R;
     float R2;
     // (P - C)^2 = r^2
     if (det >= 0.0)
     else
         return -1.0;
     float i = dot(normalize(d), normalize(normal));
     if (i < 0.0)
         return 0.0;
     return i;
vec3 ColourGround(in vec3 surface, in vec3 normal)
     float u = floor(surface.x / 3.0);
     float v = floor(surface.z / 3.0);
     if (mod(u+v, 2.0) == 0.0)
         return vec3(0.4, 0.4, 0.4);
     else
         return vec3(1.0, 1.0, 1.0);
vec3 TraceRay(in Ray ray)
     Plane ground = Plane(vec3(0, 1, 0), -5.0);
     Sphere sphere1 = MakeSphere(vec3(MapScreenExact(iMouse.xy)*4.0, 0),
1.0);
     float groundT  = IsectPlane(ray, ground);
     float sphere1T = IsectSphere(ray, sphere1);
     int object = 0;
     if (groundT < 0.0 && sphere1T < 0.0)
         object = 0;
     if (groundT > 0.0 && sphere1T < 0.0)
         object = 1;
     if (groundT < 0.0 && sphere1T > 0.0)
         object = 2;
     if (groundT > 0.0 && sphere1T > 0.0)
         if (groundT < sphere1T)
             object = 1;
         else
             object = 2;
     if (object == 0)
         return vec3(0, 0, 0);
     vec3 surface, normal, colour;
     if (object == 1)
         surface = RayPoint(ray, groundT);
         normal = ground.N;
         colour = ColourGround(surface, normal);
     if (object == 2)
         surface = RayPoint(ray, sphere1T);
         normal = surface - sphere1.C;
         colour = vec3(1, 0, 0);
     float b1 = Illuminate(vec3(0, +10, 0), surface, normal);
     return colour*vec3(b1, b1, b1);
     vec4 prev = texture2D(iChannel0, fragCoord.xy / iResolution.xy);
     vec3 colour = TraceRay(cr);
     fragColor = vec4(colour/float(iFrame), 1) + prev*(1.0 -
1.0/float(iFrame));
     fragColor = clamp(fragColor, vec4(0, 0, 0, 0), vec4(1, 1, 1, 1));
You'll need to configure this for frame averaging, by setting this up as
the shader for Buffer A, and configuring iChannel0 = Buffer A. Then set
the main shader to just render Buffer A to the screen.
Subject: Re: WebGL
Date: 13 Jun 2016 03:13:05
Message: <575e5d01$1@news.povray.org>
>> isect = Raytrace();
> you need
No, the algorithm does give the same result as you want, step through it
with your example:
CCOR = 100%
col = black
1st intersect:
col = black + (100%)*4% blue = 4% blue
CCOR = 100% * 95% = 95%
2nd intersect:
col = 4% blue + (95%) * 6% yellow
CCOR = 95% * 50%
3rd intersect:
col = 4% blue + (95%) * 6% yellow + (95%*50%) * green
CCOR = 95% * 50% * 0%
Subject: Re: WebGL
Date: 13 Jun 2016 03:47:38
Message: <575e651a$1@news.povray.org>
Once I realised that you need to set iChannel0 to Buffer A for both
Buffer A and the main image, it worked a treat :-)
Subject: Re: WebGL
Date: 20 Jun 2016 03:00:54
Message: <576794a6$1@news.povray.org>
I finally got around to porting my WebGL version (which I had to write
because shadertoy didn't support multiple buffers back then):
https://www.shadertoy.com/view/MsySzd
BufferB is used to store the camera viewing angles and the frame number
that the viewing angles last stopped changing (so the BufferA knows
where to start averaging the frames from).
If it doesn't work on your GPU try reducing the number of SAMPLES (at
the top of BufferA). The end result will be the same, it will just look
a bit worse whilst rotating the camera.
Subject: Re: WebGL
Date: 20 Jun 2016 13:59:00
Message: <57682ee4$1@news.povray.org>
Ah yes, I thought I remembered there being prior art in this space...
Interesting. I made a version of mine that only averages together the
previous N frames, and set the camera to rotate constantly. By changing
N, you can choose between grainy images or a weird motion blur. Looks
vaguely like thermal imaging, actually...
You'll be unsurprised to hear that this breaks Opera.
Looking at some of the stuff people have done, you wonder why this
amazing tech isn't in games...
...and then you realise it doesn't scale to non-trivial geometry. I'm
still figuring out how the GPU actually works, but it *appears* that it
works by executing all possible code paths, and just turning off the
cores that don't take that branch. That's find for 4 trivial primitives;
I'm going to say it doesn't scale to hundreds of billions of objects.
Pity. It would be so cool...
Subject: Re: WebGL
Date: 21 Jun 2016 06:58:55
Message: <57691def@news.povray.org>
What GPU do you have? Have you tried this Chrome or IE?
Yes, that's how I understand it too. Writing this:
if(some_condition)
  DoA();
else
  DoB();
Runs the same speed as this:
DoA();
DoB();
For "small" scenes though, this is still orders of magnitude faster than
it would ever run on a CPU.
I suspect if you started to modify and optimise the hardware to cope
better with more dynamic branching and recursion etc, you would end up
back with a CPU :-)
Subject: Re: WebGL
Date: 21 Jun 2016 16:10:50
Message: <57699f4a$1@news.povray.org>
Apparently Opera is "widely known" for having rubbish WebGL support.
> if(some_condition)
> DoA();
> else
> DoB();
> DoA();
> DoB();
The CPU may be superscalar, but having 4-vector float arithmetic in
hardware, in parallel, on a bazillion cores has *got* to be faster. ;-)
> back with a CPU :-)
I don't know. I think the main thing about the GPU is that it's SIMD. My
CPU has 4 cores; my GPU has nearer 400. I gather that each individual
core is actually slightly *slower* than a CPU core - it's just that
there's a hell of a lot of them. Also that memory access patterns are
very predictable (until you do complex texture lookups), which enables
the memory scheduling to have massive bandwidth with all the latency
hidden away, so you have no pipeline stalls or cache misses to worry about.
Then again, I don't design GPUs for a living, so...
I suspect there's probably a way to render complex scenes in multiple
passes such that you can do batch rendering. I'm not sure if it'll ever
scale to realtime.
(Doesn't Blender or something have an optional unbiased rendering engine
for the GPU?)
Subject: Re: WebGL
Date: 14 Jul 2016 16:28:16
Message: <5787f5e0@news.povray.org>
Is there some sort of offline client program for ShaderToy? It would be
really nice to not have to put up with the frailness of Opera, and to be
able to easily *save* my source code, etc.
I still hope to do this soon...
PS. Just for giggles, try running ShaderToy on your *phone*! It actually
works... kinda...
Subject: Re: WebGL
Date: 26 Jul 2016 08:30:12
Message: <579757d4$1@news.povray.org>
Not that I'm aware of, presumably just saving the web page doesn't work?
Why don't you use a different browser?
> works... kinda...
Yes I was surprised at that too, at first I thought the web site was
just sending a static bitmap or something, but no, my £100 smartphone is
actually running WebGL! The simple shaders run very smoothly.
