POV-Ray : Newsgroups : povray.off-topic : Quantum Pov, soon? Server Time
11 Oct 2026 17:13:21 EDT (-0400)
  Quantum Pov, soon? (Message 51 to 100 of 130)
<<< Previous 50 Messages Goto Latest 50 Messages Next 30 Messages >>>
Subject: Re: Quantum Pov, soon?
Date: 9 May 2016 07:40:08
Message: <57307718$1@news.povray.org>
On 09/05/16 12:22, Thomas de Groot wrote:
> On 9-5-2016 13:12, Doctor John wrote:
>> For no apparent reason, I was immediately reminded of Leonard Cohen's
>> 'Anthem'.
>> There is a crack, a crack in everything
>> That's how the light gets in.
> Somehow, I think this would be an interesting Challenge for the TC-RTC.
Good idea! But rather than just those lines, why not use the whole song
as a source of inspiration?
There are several lines that conjure up (for me at least) some amazing
mental imagery.
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Date: 9 May 2016 07:48:54
Message: <57307926$1@news.povray.org>
>> On 09/05/16 11:12, Stephen wrote:
>>> Thanks, but I got it from  James Blish's 1954 short story "Beep"
>>> I'm sure there is a line that says physics is physics and you can't play
>>> the cracks of the piano
>> 'Anthem'.
Seconded.
Regards
Date: 9 May 2016 07:50:26
Message: <57307982$1@news.povray.org>
>>> 'Anthem'.
> mental imagery.
Don't hold your breath. ;)
Regards
Date: 9 May 2016 08:13:12
Message: <57307ed8$1@news.povray.org>
On 5/9/2016 11:20 AM, Orchid Win7 v1 wrote:
> Tangentially:
> https://hackaday.com/2016/04/30/megaprocessor-is-a-macro-microprocessor/
There are some strange people in the world. I've read about a couple of
projects like that.
 > Apparently the LEDs consume most of the power. And where I was thinking
 > that LEDs are extremely low-power...
He uses 10,548 LEDs and at 20 milliamps a pop. That makes, how many amps...?
Now how does he do that?
Regards
Date: 9 May 2016 08:57:55
Message: <57308953$1@news.povray.org>
> I guess it depends on what your goal is. If your goal is "design
> circuitry that can be manufactured in the real world and sold to people
> at a profit", there's an awful lot of real-world stuff that's quite
> important. If your goal is "I wonder how my PC works", then... not so much.
Unless, by "how my PC works", you mean why it needs a million tiny (or
not so tiny) capacitors on the motherboard, or why the tracks are laid
out that way, or why certain parts are grounded together and certain
parts are not, or why there are transformers next to the ethernet
socket, why there is a heatsink on some ICs but not others ... etc.
> Tangentially:
You mean like this one? :-)
http://www.leds4less.co.uk/100w-led-floodlight--ip65-waterproof--1000-watt-equivalent-459-p.asp
Are you aware that you can light your home/office with LEDs now, or
light your way when cycling with them, or even some newer cars use them
for headlights too?
Needless to say, LEDs come in all sizes, but a rough rule of thumb is
that they convert about 10% of the electrical power used into visible
light (the other 90% going to heat). Which makes them "low power",
compared to an equivalent "old" style bulb with the same light output.
Date: 9 May 2016 11:46:30
Message: <5730b0d6$1@news.povray.org>
Am 09.05.2016 um 10:20 schrieb Stephen:
> On 5/9/2016 7:45 AM, scott wrote:
>> Chapter 10 is "digital electronics", but many of the preceding chapters
>> are worth understanding before you start to make anything "digital". In
>> the end, a digital "gate" is actually just transistors, so if you
>> understand how transistors work you'll understand why a gate behaves the
>> way it does.
> A very good point. Most people think that a digital transistor is
> different from a transistor for an amplifier.
Try to push an amp or two through a "digital" transistor, and you'll see
that they /are/ different :P
Date: 9 May 2016 11:55:15
Message: <5730b2e3$1@news.povray.org>
On Mon, 09 May 2016 10:52:33 +0100, Doctor John wrote:
> On 09/05/16 10:22, Stephen wrote:
>> Quantum is playing the cracks between the keys of the piano.
> Now _that_ is a seriously good mental image.
I like it.
Jim
"I learned long ago, never to wrestle with a pig. You get dirty, and
besides, the pig likes it." - George Bernard Shaw
Date: 9 May 2016 12:02:13
Message: <5730b485$1@news.povray.org>
>>> way it does.
One
Regards
Date: 9 May 2016 12:11:27
Message: <5730b6af@news.povray.org>
Am 09.05.2016 um 14:57 schrieb scott:
With single-wavelength indicator LEDs as in the example, the efficiency
can be a good deal higher (typically about 40% for red LEDs, if
Wikipedia can be trusted on this one).
Still, even indicator LEDs need to be able to compete at least with
indirect daylinght on a sunny day, which is a *shitload* of lumen.
Which is why under many lighting conditions /anything/ employing
reflection -- whether it is reflective LCDs or e-ink -- is more
efficient than even the best LEDs.
Date: 9 May 2016 12:14:33
Message: <5730b769$1@news.povray.org>
Am 09.05.2016 um 11:52 schrieb Doctor John:
With slight emphasis on "mental"? ;)
Date: 9 May 2016 12:34:44
Message: <5730bc24$1@news.povray.org>
See you, Jimmy!
Pick your ship and name your place. :-P
Regards
Date: 9 May 2016 15:50:09
Message: <5730e9f1@news.povray.org>
To which the traditional reply is:
Outside, now, and if I'm not there in 5 minutes, start without me.
John
Protect the Earth
Date: 9 May 2016 17:30:42
Message: <57310182@news.povray.org>
>> much.
I have to admit, I have frequently wondered why this *digital* device
has hundreds of *analog* components on it (mostly capacitors and
inductors). I mean, I get why they're on the motherboard rather than on
the silicon die, but why do you need them at all?
Is there a simple relationship between circuit design and heat output? I
mean, is it something as simple as number of switching elements and how
fast they switch per second? Or is it something more complicated?
>> Tangentially:
> for headlights too?
Well yes, but those aren't what the guy was using. He's not trying to
light the building, just tell you which circuits are on or off. :-P
Interesting. I didn't realise the efficiency was still that low.
(Obviously incandescent bulbs are notoriously inefficient. But I thought
LEDs were a bigger step forward than that...)
Date: 9 May 2016 17:37:03
Message: <573102ff@news.povray.org>
>> Tangentially:
> projects like that.
Personally, I say well played to the guy. It must have cost him a damned
*fortune* to do all this!
I see so many projects that are all like "an entire computer built using
only 7400s"... and then you realise they actually meant "ICs in the 74xx
product catalog", not just the 7400 itself. So that means entire
flip-flops, adders, counters, encoders, etc in a single chip, not the
individual logic gates you were expecting. And then you find out it uses
off the shelf 64KB RAM chips. And then the guy added a "graphics card"
that's actually a Raspberry Pi. So... an entire computer with 2,000,000x
the processing power of the "computer" you're building? :-P And at this
point, all kind of credibility is kinda lost.
At least *this* project appears to be doing stuff for real. And he's
obviously given a lot of thought to making it *visual* what's going on,
which is nice. Aesthetics are often forgotten on hard-core electronics
projects like this.
> amps...?
I've never built any circuit that uses more than about 3 LEDs. Which
means the power used by the LEDs is negligible. I guess I failed to
anticipate how things stop being negligible when you have a metric tonne
of them! :-P
Date: 10 May 2016 03:12:22
Message: <573189d6$1@news.povray.org>
>>>> play
>>> 'Anthem'.
> Seconded.
Good. I am going to prepare this for the future. There two possible
lines in fact: the Blish citation and the Cohen lyrics.
Date: 10 May 2016 04:11:47
Message: <573197c3$1@news.povray.org>
Am 09.05.2016 um 23:30 schrieb Orchid Win7 v1:
To keep the primary components (mostly transistors) firmly within the
range of operating parameters where they behave "digitally".
Most of the capacitors are there to keep the supply voltages stable. You
wouldn't believe how much noise a digital circuit feeds back into its
power supply, and you don't want that noise to feed forward into other
parts of the circuitry.
Power consumption (and hence heat output) of modern (i.e. FET-based)
digital electronic circuitry mainly depends on the total number of
transistors changing state every second, because that's when currents flow.
However, the relationship between per-transistor switching frequency and
power consumption is non-linear (presuming the circuitry is operated at
its limits), since higher switching frequencies require faster charge
transfers, which means shorter pulses of higher currents, which in turn
also require higher voltages to drive them.
In addition to this inevitable "payload" power consumption there will be
various parasitic losses, such as from inevitable signal line
inductivities and capacitances, as well as plain old leakage currents,
all of which obviously get worse with increased operating voltages, chip
area and complexity, but in /very/ non-linear ways.
Date: 10 May 2016 04:36:20
Message: <57319d84$1@news.povray.org>
>>>>> play
>>>> 'Anthem'.
>> Seconded.
Noooooooo! I was talking about "Playing on the cracks of the piano"
Leonard Cohen's music should be banned on public health grounds. [Hate
Marmite]
And yes I am up for a flame war. I have principles.
Regards
Date: 10 May 2016 04:37:39
Message: <57319dd3$1@news.povray.org>
Top posting for effect. ;)
Geek porn. :)
Regards
Date: 10 May 2016 04:57:56
Message: <5731a294$1@news.povray.org>
On 05/10/2016 10:37 AM, Stephen a dit:
> Geek porn. :)
    We also do that in Toulouse :)
    http://wemakeporn.tetalab.org/
http://weblog.mixart-myrys.org/?post/2016/03/De-la-temporalisation
Date: 10 May 2016 05:25:24
Message: <5731a904$1@news.povray.org>
>>> Tangentially:
>> projects like that.
So do I
For people of a certain age, 7400s does mean "ICs in the 74xx product
catalogue". For the rest of it I see what you are getting at.
But let me put an alternative view.
They are not obsessives like the guy above but hobbyists. Doing a little
bit is much better than doing nothing but thinking about it. Credit to
them as well.
> projects like this.
There was a fashion for computers to show the contents of their
registers in a matrix. {Some men believed that you could see the
workings of the computer mind. </Bad Jeremy Clarkson voice }
Another nice detail.
Then again I wouldn't want to be married to him, unless...
I once knew a guy, offshore. Who built a 1:10 scale model of the Flying
Scotsman. Hand turned/formed/riveted down to making the rivets and
threaded screws.
Nice man but don't ask him to a party. :)
> of them! :-P
Ah! the definition of a scientist. :-P
Electronics was my hobby as well as my job. And most companies
encouraged us to do home projects. At least 30% of a project could be
counted on as tinsmithing. (And hoping your power supply was up to the
job after all those modifications.)
Regards
Date: 10 May 2016 05:31:21
Message: <5731aa69$1@news.povray.org>
Well?
There is the "See you Jimmie" modifier to take into account and the smiley.
The language is not without its syntax. :)
Which, I think. Puts you into Hump.
Regards
Date: 10 May 2016 05:58:02
Message: <5731b0aa@news.povray.org>
>> Geek porn. :)
And I hope you are very happy doing it. ;)
It looks an interesting project. Art and Technology? No. I got it the
wrong way round.
You could have posted your hackerspaces page. It took me ages to cotton on.
I think it is really great that there are projects like this and the
repairers ones.
Regards
Date: 10 May 2016 06:03:57
Message: <5731b20d$1@news.povray.org>
I don't know which version you're playing, but, under the Lipka-de Groot
variation, my action entitles me to cross three diagonals. (See also
Henderson's commentary on the 2012 world championship final)
John
Protect the Earth
Date: 10 May 2016 06:12:45
Message: <5731b41d$1@news.povray.org>
> Marmite]
Your musical education is sadly lacking in certain key areas, though you
do score bonus points for appreciating Wagner et al.
> ... I have principles.
Don't worry. A short course of amoxycillin will soon cure that :-p
John
Protect the Earth
Date: 10 May 2016 07:20:40
Message: <5731c408$1@news.povray.org>
>> Marmite]
> John
Listening to Cohen should be compulsory for certain persons. For example
before or better during a POV-Ray render.
Date: 10 May 2016 07:24:57
Message: <5731c509$1@news.povray.org>
>> Marmite]
He goes on a bit as well.
You know the one with Irish princess, a king, a best friend, a forced
marriage, a love potion that looks like a poison. A cheery finale where
the curtain comes down as they all dance around the Maypole.
Ha!
If you are talking modern stuff. Berlioz is your man. Something upbeat.
I did not say incorruptibility was one of them. So try again. ;)
Regards
Date: 10 May 2016 07:27:21
Message: <5731c599$1@news.povray.org>
Which chapter of the Spanish Inquisition do you belong to?
Regards
Date: 10 May 2016 07:31:12
Message: <5731c680$1@news.povray.org>
The tough one. We light the fire under the grill for breakfast.
Date: 10 May 2016 07:32:44
Message: <5731c6dc@news.povray.org>
> John
Sorry.
I'm playing to the orthodox version of:
"Are you looking at me? Ya bampot. (without reference to hospital food)"
branch.
Sorry for any inconvenience.
Regards
Date: 10 May 2016 07:33:52
Message: <5731c720$1@news.povray.org>
Must be true.
Regards
Date: 10 May 2016 08:02:57
Message: <5731cdf1$1@news.povray.org>
>>>> example
> Must be true.
Of course we have our anthem too:
You know that it would be untrue
You know that I would be a liar
If I was to say to you
Girl, we couldn't get much higher
Come on baby, light my fire
Try to set the night on fire
Date: 10 May 2016 11:48:20
Message: <573202c4$1@news.povray.org>
Am 10.05.2016 um 10:36 schrieb Stephen:
> Marmite]
And a flame war you can have!
(Cue: Who By Fire)
Seriously -- I see how one might argue about /some/ of his songs, but
let me say just one word:
Suzanne.
Anyone disliking /that/ song must have inhaled too much petrol fumes
while working offshore.
Date: 10 May 2016 11:49:02
Message: <573202ee$1@news.povray.org>
Am 10.05.2016 um 13:20 schrieb Thomas de Groot:
Hear, hear!
Date: 10 May 2016 11:51:43
Message: <5732038f$1@news.povray.org>
Am 10.05.2016 um 14:02 schrieb Thomas de Groot:
>>>>> example
>> Must be true.
Nice try, but not Cohen.
(Cue: "Joan of Arc")
Date: 10 May 2016 13:38:24
Message: <57321c90$1@news.povray.org>
>> Marmite]
> (Cue: Who By Fire)
Gene Kelly - Singin' In The Rain
or
https://www.youtube.com/watch?v=291ET6Py6H8
> Suzanne.
You're not a fan of "Die Leiden des jungen Werthers" are you, by any
chance?
Funnily enough. It was when I was working offshore I gave up listening
to pop music.
Regards
Date: 10 May 2016 13:57:04
Message: <573220f0$1@news.povray.org>
Am 10.05.2016 um 19:38 schrieb Stephen:
>>> Marmite]
>> (Cue: Who By Fire)
> or
Averted!
Praise be to the GEMA who protected me from whatever song may have been
lurking in the video...
>> Suzanne.
> chance?
Never read it; I've heard that in a nutshell it's about some suicidal
depressive guy. Not sure what that has to do with "Suzanne" though --
while varous of Cohen's songs do indeed tend towards the dark blue end
of the spectrum, I don't think "Suzanne" falls into that category.
> to pop music.
You wouldn't call Cohen's music "pop music", would you?
Date: 10 May 2016 15:49:42
Message: <57323b56$1@news.povray.org>
> Averted!
Happy, happy talk.
>>> Suzanne.
24 seconds, I lasted. And that was pushing it.
I would rather listen to something like this.
[Victoria Wood spoiler]
https://www.youtube.com/watch?v=iKRcm5v30tw
>> chance?
> Never read it;
Hallelujah! You were saved a fate worse than boredom.
Well there was a whole movement of youths that read it and didn't live
to be anyone's ancestors.
I may be a wee bit biased. I grew up going to parties where there were
whole rooms of girls swooning over the thought of a romantic death. And
the boys competing with each other over who was the most lovelorn*. It
really put a dampener on things.
And none of them had taken drugs.
I suppose it was pre-goths.
And I don't do introspection, either.
*That may just have been a ploy for nefarious reasons.
>> to pop music.
Yes, I would. (For most values of popular.)
Regards
Date: 10 May 2016 17:54:34
Message: <5732589a$1@news.povray.org>
Am 10.05.2016 um 21:49 schrieb Stephen:
>>>> Suzanne.
Tsk, tsk.
Now I'd call you a peasant, but that would be an insult to farmers.
As a novelty -- interesting.
As something to listen to a second time -- nah.
Definitely too much petrol fumes.
Date: 10 May 2016 18:31:19
Message: <57326137$1@news.povray.org>
>>>>> Suzanne.
> Tsk, tsk.
You call that Flame War Bait?
  for there is nothing either good or bad, but thinking makes it so.
[by you know who]
The difference is. I would listen to it again in a couple of years.
BTW Where do you think we got the petrol? The nearest petrol station was
either in Bergen or Lerwick and helicopters don't use petrol.
Regards
Date: 10 May 2016 19:53:03
Message: <5732745f$1@news.povray.org>
Am 11.05.2016 um 00:31 schrieb Stephen:
Last time I checked, petrol is a component of crude oil, right?
Date: 11 May 2016 02:09:53
Message: <5732ccb1$1@news.povray.org>
Yes, you get petrol from crude after it has been processed at a refinery.
It doesn't come out of the ground as petrol.
Regards
Date: 11 May 2016 02:52:51
Message: <5732d6c3$1@news.povray.org>
>>>>>> example
>>> Must be true.
Cohen? No, of course not! He is but one of our saints.
Date: 11 May 2016 02:53:51
Message: <5732d6ff$1@news.povray.org>
> Hear, hear!
So, what are you waiting for to implement this in your next alpha?
Should have been done yesterday.
Date: 11 May 2016 03:36:57
Message: <5732e119$1@news.povray.org>
>> Hear, hear!
You could change this file.
C:\Program Files\POV-Ray\v3.7\sounds\Parse Error.wav
Regards
Date: 11 May 2016 03:38:56
Message: <5732e190@news.povray.org>
My old company had an LCD design where half of each sub-pixel was
reflective and half transmissive. It looked just as good under direct
sunlight as in a dark room. However it needed a much brighter (=larger
and hotter) backlight and obviously was more expensive. You can find
this technology in some old high-end Nokia phones and in BMWs with
built-in satnav older than 2-3 years. I don't think any consumer stuff
uses those any more unfortunately, mainly due to the high cost, but it's
still used for military LCDs.
Date: 11 May 2016 04:05:47
Message: <5732e7db$1@news.povray.org>
Aha - so you are not just interested in a fictional perfect logic device
then? :-) Start at the beginning of the book. All will make sense.
voltage x current
> I
As clipka mentioned, a transistor used in digital circuits is either in
a state where the current flow is zero ("off") OR the voltage drop is
zero ("on"), so heat output is usually zero. It's switching between
those two states, when both voltage and current are non-zero, that
significant heat is dissipated within the transistor.
https://en.wikipedia.org/wiki/Luminous_efficacy
Date: 11 May 2016 07:28:04
Message: <57331744$1@news.povray.org>
>>>> example
>>> Hear, hear!
LOL You got me.
Date: 12 May 2016 12:28:24
Message: <5734af28@news.povray.org>
Am 11.05.2016 um 10:05 schrieb scott:
Um... no?
The fact that modern digital circuitry only draws power when switching
between states has nothing to do with the voltage drop across the
transistor; as a matter of fact, the type of transistor used in modern
digital circuitry acts pretty much like a low-ohmic resistor when
switched on, and will happily draw as much current as you happen to
allow it to, accompanied by a corresponding increase in the voltage drop
and a merry self-heating, up to the point of destruction.
The fact that modern digital circuitry draws virtually no power in
stable state is that (1) they use FET (Field Effect Transistor, aka
unipolar transistor) technology, in which the transistor's control
terminal (the "gate") is isolated from the other terminals (the "source"
and "drain"), controlling the source-drain voltage exclusively through
the presence of charge (held there by a sufficiently high
gate-source/drain voltage); as a result, the DC component of the gate
current is zero, i.e. the only time when current flows to or from the
base is when the base voltage is changed. And (2) the FETs are always
wired in such a way that in a stable state each switched-on FET connects
the power rail with nothing but other FETs' gates, or switched-off FETs
that would connect those same gates to the other power rail in the
complementary state.
(So yeah, the voltage drop across a switched-on transistor in a modern
digital circuit typically /is/ zero, but only in the same sense as the
voltage drop across a simple resistor with one terminal wired to a power
source and the other terminal floating in mid-air is also zero.)
Pre-FET-era digital circuitry was instead based on bipolar transistors,
in which a current must flow through the control terminal (called the
"base" in that case) to switch the transistor on. Those transistors did
in fact have a constant voltage drop in the "on" state, but even that
was distinctively non-zero.
(As an interesting side note, the earliest transistor prototypes were
actually FETs; however, they were not feasible to manufacture back then,
so bipolar transistors took the lead for a while.)
Date: 12 May 2016 12:35:00
Message: <web.5734afb0bbfea74791327a850@news.povray.org>
Stephen <mca### [at] aolcom> wrote:
> http://www.bbc.co.uk/news/technology-36203043
> Regards
>      Stephen
> General-purpose machines, which IBM calls "universal" quantum computers, will
eventually use more than 100,000 qubits
funny name for the measure:  quantum bits, qubits.  homophonous to the biblical
cubits :)
povray for quantum computing?  expect more 20 years, after they get into GPUs
Date: 12 May 2016 12:35:59
Message: <5734b0ef$1@news.povray.org>
Am 11.05.2016 um 08:09 schrieb Stephen:
Ha -- but it does come out of the ground /with/ petrol being part of it!
So where there's crude oil, there /are/ petrol fumes. QED.
