POV-Ray : Newsgroups : povray.off-topic : Storey height Server Time
4 Mar 2026 19:02:11 EST (-0500)
  Storey height (Message 1 to 5 of 5)
Subject: Storey height
Date: 6 Feb 2016 03:56:48
Message: <56b5b550@news.povray.org>
How high are storeys in European buildings in meters usually? Is 3
meters sufficient?
Mike
Subject: Re: Storey height
Date: 6 Feb 2016 05:20:21
Message: <56b5c8e5$1@news.povray.org>
Hash: SHA256
> meters sufficient?
Do we speak of space between floor and ceiling, or between identical
element, from one level to another ?
And about modern (like post 1960) building, or older ones ?
For instance in Paris, Haussmanian's building have decreasing storey's
height as you go up. Historically, the owner lived at the bottom, and
the higher you went, the less money you owned. Under the roof, bedroom
for servants are usually quite small, both in surface and height.
Minimal height, inside, for a surface to count for rent and sell is
1.80m. Doors are usually higher, I would say between 2m to 2.15m, and
there is usually a margin of 30 to 60cm to the ceiling.
If we are in some office, there might be some additional height in the
ceiling itself before reaching the supporting floor (for cable and
ventilation).
And in some region, small houses might also have a ceiling below 1.7m
(dating from a time when people were smaller, and heating was
expensive), they are painful to sell now. (and most modern furnitures
won't fit... no full height fridge there)
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2
iJwEAQEIAAYFAla1yOQACgkQhKAm8mTpkW0UZQQAvvvve2xAiPMgsisYP+4qZMWb
Ny3nlWORwZhKYSbNjxTKPxTrF4tjHu2X9JJ3c2neJ1wWjDtBI9GsHsVFD9GAIOsN
4smYW0wLMkLTuAtTYt1dYU5nDUoRCDdhJSn9WRpovgjQjvLuMjIFHmiwMzuOL1b2
/mhRT64tKEkZ1kFYUu0=
=bZ1w
-----END PGP SIGNATURE-----
Date: 6 Feb 2016 06:39:36
Message: <56b5db78$1@news.povray.org>
> meters sufficient?
Will this help?
http://www.ctbuh.org/HighRiseInfo/TallestDatabase/Criteria/HeightCalculator/tabid/1007/language/en-GB/Default.aspx
Regards
Date: 6 Feb 2016 07:26:36
Message: <56b5e67c@news.povray.org>
>> meters sufficient?
> Will this help?
Interesting!
Date: 6 Feb 2016 08:21:26
Message: <56b5f356$1@news.povray.org>
>> meters sufficient?
> Will this help?
Yes, thanks! I decided upon 3.5 meters since that is a happy in between.
Mike
