Pro Tip:
Keeping your desk covered with obsolete paperwork can be an effective
first line of defense against beverage spills.
(A thorough mix of obsolete and important paperwork -- not so much.)
Confirmed by experiment.
Also, the "sticky keys" keyoard setting has no effect on coke stains.
On 1/29/2016 6:36 PM, clipka wrote:
> Pro Tip:
I coughed and spit some water on my monitor once. There's still a dark
splotch near the bottom where the pixels are dead.
Mike
Le 2016-01-29 18:36, clipka a écrit :
> Pro Tip:
I heard that - although never tried - most keyboards can go in the
dishwasher (without soap), upside down on the top rack. You just have
to make sure they dry completely before reconnecting them.
/* flabreque */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
/* @ */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
/* gmail.com */}camera{orthographic location<6,1.25,-6>look_at a }
Am 30.01.2016 um 02:14 schrieb Francois Labreque:
>> Pro Tip:
FEAR THE KEYBOARD SFFERED A LTTLE BT:::
>> Pro Tip:
Never put a keyboard in a dishwasher, it gets too hot and will most likely
deform the keyboard.
What I use is hand warm water in a tub, gentle dish soap and a soft brush. It
will get the keyboard clean and shiny again. You just have to rinse it
thoroughly to get the soap out. After that just let it dry. For that I put it
on a fan.
Ger
It's easier to just throw the keyboard away at the end of the day, and use a new
one daily. I have 1,732 new keyboards sitting in my closet, awaiting use...
Of course, if you're environmentally-minded, you can recycle 'em as art. I glue
the old ones together, to make a big impressive-looking ball. It's now 17 meters
in diameter. People are always complimenting me on my ingenuity and aesthetic
taste.
Am 30.01.2016 um 09:57 schrieb Kenneth:
Not really an option in this case -- we're talking about a Logitech G19
here. They're not even making them anymore.
FYI
http://www.amazon.de/Logitech-Gaming-Tastatur-schnurgebunden-deutsches-Tastaturlayout/dp/B001S2W5U2
or
http://www.amazon.co.uk/Logitech-920-000978-G19-Gaming-Keyboard/dp/B001RORKH4
Regards
>>> Pro Tip:
But you will have lots of hot keys. ;-)
> on a fan.
The fan is more than a good idea.
When I used to work for a living. It was essential to blow the water
off. Otherwise you get mineral deposits and that can cause tracking or
changes in capacitance.
Now here is something you might find hard to believe because I did.
Coffee with milk is good for cleaning the outside of equipment such as
the beige system boxes of old.
Regards
> taste.
I purposefully got my keyboards second hand. I like them because they
are nice and solid. Not the cheap flimsy things you get when you buy a
PC at the local box store.
Mike
Am 30.01.2016 um 14:42 schrieb Stephen:
>>> and use a new
>>> use...
> FYI
I had found that one already. Did you have a look at the price for a new
one? EUR 421,68, that's about 320 GBP at the current exchange rate.
> or
Not an option, as it sure as hell isn't a German one.
But I'm mildly optimistic about the specimen I gave a few sips of coke
to drink. I've gone for the disassemble-cleanse-reassemble approach now.
First of all, a bit to my surprise, the G19 doesn't use fancy individual
switches that the phosphoric acid- and sugar-rich liquid might have
seeped into to avoid detection. Instead, it uses a multi-layered
sandwich structure, at the core of which is a membrane keyboard -- a
transparent one, presumably to facilitate illumination of the key caps,
so that I can say with absolute certainty: No coke has made its way to
the actual key contacts.
Above that sits a shaped mat of thin rubber effect the desired key
travel and pressure point, and atop of that the top cover assembly with
the keycaps mounted safely in a rack, which greatly simplifies
maintenance of this portion of the keyboard. All these components got
their fair share of beverage, and some keys had already become sticky
not only to the touch but also in terms of movement, but they've all
gotten a thorough rinse with soap and warm water and should be perfectly
fine now. (The keycap assembly has also received a thorough shower on
this occasion.)
Below the membrane keyboard is a piece of transparent plastic, obviously
serving as a light guide, and below that a highly reflective white sheet
of whatever; Some coke had managed to creep between these two, but they
also received a good rinse, as did the bottom cover.
The display that sits at the back of the keyboard should also be fine,
as it hasn't received any coke in places where it could have seeped inside.
So the only thing that still worries me is the keyboard electronics. I'm
not sure whether I want to drown that in water just to be sure, or just
be content with having wiped it with a wet cloth and then wiped it dry
again.
Oh, and then of course there's the other thing to be worried about:
Whether I'll be able to reassemble it properly ;)
>> use a new
>> use...
>> art. I glue
>> 17 meters
>> aesthetic
>> taste.
I can understand that. They don't feel right typing on them.
My last k/board was an inexpensive gaming one, a Corsair k30 keyboard.
About 40 GBP.
It feels solid and sturdy with a positive key action, well worth the
money and that is not counting the illuminated keys and extra keys for
macros.
Regards
>>>> and use a new
>>>> use...
>> FYI
No I did not. You could buy two cheap laptops at PC World for that
price. (If you had taken leave of your senses.)
I thought the price of the German one was pricy so that's why I posted
the UK one without thinking.
>> or
Colour me thick. I forgot about that. I was given a laptop for work and
it had a Norwegian k/board.
Quite inconvenient.
That's good. It will five you something to do over the weekend. ;-)
And we all know what happens when you put coper coins in a can of coke.
> again.
I would have rinsed it off and maybe rinsed of the water with alcohol
before drying. That is an option for later if it does not work.
I'm terrible with membranes and the like. And I’ve never successfully
put back together anything that used an elastomeric connector.
Regards
Am 30.01.2016 um 17:27 schrieb Stephen:
No banana, unfortunately. The U, I and Caps Lock keys remain dead, and
seem unwilling to be revived.
Which means that for now I'm stuck with a spare keyboard I originally
bought for the occasional direct access to my otherwise headless Linux
box, chosen specifically for its tiny dimensions and affordable price.
/Not/ the thing that's fun to use for software development.
I hate to be begging, but as I'm currently short on money (and high on
round tuits since a couple of days now, which is a bad sign as far as
finances go), while at the same time I don't see a point in replacing
one crappy keyboard with another marginally less crappy one, I'd like
everyone to know that donations would be highly welcome at this point.
I guess my current dream keyboard would be one of these:
http://www.amazon.de/registry/wishlist/VJ0OCNX5ZOGH
Having gotten quite used to the 12 programmable macro keys on the G19, I
must confess I'm hesitant to get anything with fewer of those.
The internal organs of this gadget sound somewhat similar to those of
the Microsoft Ergonomic Whatsit of some years back, the one that vaguely
resembled a grand piano. I trust that you've wiped down *all* the
contacts with an alcohol prep pad...?
As I recall, the trick with the MS Whozit was to lift out the sheet with
the printed circuits, tip it slightly, and squint at it--*any* spot that
the looked a little brownish or burnt got a good wipe-down with alcohol.
I did manage to resurrect a couple of them multiple times with this
treatment.
And consider--if you can get U and I to work, you can live without caps
lock. :)
#macro T(E,N)sphere{x,.4rotate z*E*60translate y*N pigment{wrinkles scale
.3}finish{ambient 1}}#end#local I=0;#while(I<5)T(I,1)T(1-I,-1)#local I=I+
1;#end camera{location-5*z}plane{z,37 pigment{granite color_map{[.7rgb 0]
[1rgb 1]}}finish{ambient 2}}// TenMoons
Am 31.01.2016 um 07:21 schrieb Sherry K. Shaw:
> treatment.
There are a few problems with applying this remedy to my G19:
- The G19's printed circuits sheet isn't a single sheet, but again a
sandwich of three sheets: A single-sided upper contact layer, a spacer,
and another apparently double-sided layer. These layers are heat-welded
together at strategic points, making it difficult to get a good glimpse
of the contacts from an angle, let alone access them specifically.
- I don't have any alcohol at home - not even a beer ;)
- There is plenty of evidence that the brown ooze never ever reached the
U and I key contacts, and instead wreaked havoc somewhere else to kill
an entire row of the key matrix (the G19 has 5-key rollover, so it is
reasonable to assume that the rows and columns of the matrix are only
sparsely populated).
> lock. :)
Yeah, that thought had already crossed my mind, too ;)
> taste.
A real life Katamari-Damacy.
>>> Pro Tip:
I forgot that nowadays, they're made of cheap plastic.
And you call yourself a German?
(And before you ask, yes, my igloo is filled with maple syrup)
Is it part of the Canadian maple syrup reserve that was stolen? ;-)
Regards
Ah. I recall the three plastic sheets in the MS keyboard as being
separate, but I don't recall if they were that way originally or if they
required encouragement.
My husband was an insulin-dependent diabetic, so consequently we kept a
supply of the little alcohol wipes for his injections and finger-sticks.
It turns out that they're extremely useful for cleaning contacts,
displays, and so forth--anything that you really don't want to hose down
with the Scrubbing Bubbles.
--Sherry Shaw
On 1/31/2016 4:17 PM, Sherry K. Shaw wrote:
> we kept a supply of the little alcohol wipes for his injections and
> finger-sticks. It turns out that they're extremely useful for cleaning
> contacts, displays, and so forth--anything that you really don't want to
> hose down with the Scrubbing Bubbles.
I have about three quartes a litre of IPA (Isopropyl alcohol) for
cleaning things. I got fed up with using vodka. :-)
Regards
Is *that* why it's called "Greenking IPA"?
Naw, there is only one real IPA and it is called McEwan's. :-P
Regards
A sad waste of vodka (although personally I'd prefer rum to not
waste--preferably in conjunction with fruit juice and neon-colored
liqueurs, with a little paper umbrella on top to keep the rain out.
Although Kool-Aid also works.) :)
--Sherry Shaw
A waste indeed hence the IPA.
It would have been my wife’s vodka. I drink whisky which leaves a stain
when it dries. Now, your witches brew could be used as a nutrient. ;-)
Regards
I refuse to answer that question without my lawyer present.
An acceptable answer. :)
Regards
When I was a child, we got a shiny new Acorn A3010 for Christmas. My
sister spilt Ribena around the Delete key area, so even many years later
that key always got stuck down if you pressed it. I got into such a
habit of never using that key (as it would end up deleting everything
after the cursor before you could wiggle it back up), that even today it
feels dangerous to use it.
>> lock. :)
German caps lock should be called shift lock.
Am 02.02.2016 um 09:20 schrieb scott:
>>> lock. :)
As a matter of fact it is called Feststelltaste (loosely translating to
lock key), and typically labelled ⇩ (loosely translating to downward
arrow) :P
As for its function, that depends on the keyboard driver you're using.
On Windows for instance, the "Deutsch (Standard)" keyboard driver
follows the German official norm, which continues the tradition of
mechanical typewriters to have the key operate as shift lock, but German
keyboard drivers do exist that configure it as caps lock, such as the
"Deutsch (IBM)" keyboard driver on Windows.
Obviously the "Deutsch (Standard)" use of the key is the more
straightforward: Locked state matches the shifted state, and that's
that. On the other end of the spectrum, the "Deutsch (Schweiz)" not only
restricts the function of the key to the letter keys, but goes so far as
to make some keys yield results that differ from both the shifted and
unshifted sate.
> arrow) :P
If only I'd known it was as simple as changing my keyboard driver to IBM...
On 2-2-2016 15:18, clipka wrote:
> ... both the shifted and
> unshifted sate.
Yum yum... What kind of dressing goes with that? ;-)
>> unshifted sate.
A chemise. And when un-shifted makes the eyebrows rise. ;-)
Regards
>>> unshifted sate.
Ah! We here have a little difficulty I overlooked. I read "sate"
(Indonesian and popular in NL) as the pieces of pork pricked on a stick
and generally served with peanut sauce. However, I like your reading of
the word :-)
If you choose the multicoloured keyboard for inspiration, it can cost a few
bucks more ...
http://www.amazon.de/gp/product/B00MVT7AYW?psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s00
Download '81aua3tovdl._sl1500_[1].jpg' (147 KB)
Preview of image '81aua3tovdl._sl1500_[1].jpg'
![81aua3tovdl._sl1500_[1].jpg](/povray.off-topic/attachment/%3Cweb.56b3a131d824e880adb2e4f80%40news.povray.org%3E/81aua3tovdl._sl1500_%5B1%5D.jpg?ttop=438856&toff=350&preview=1)
Am 04.02.2016 um 20:07 schrieb Theogott:
> bucks more ...
That don't impress me much; what I'm after is a few more dedicated macro
keys.
> bucks more ...
What's the use of the colours? looks like gadgetry.
>> a few
>> bucks more ...
To go with the flashing disco lights on you system box. :-)
Regards
>>> a few
>>> bucks more ...
Useless then.
>>>> a few
>>>> bucks more ...
> Useless then.
Worse than useless a distraction.
I had a pc that had a flashing neon light on a fan.
Snip! snip! and bob's your aunt. :)
Regards
>>>>> a few
>>>>> bucks more ...
>> Useless then.
How terribly horrendous! I hate it when others decide what is good for
you (flashing lights for instance).
>> a few
>> bucks more ...
It's to go with your clear case and its neon lights.
https://scontent.cdninstagram.com/hphotos-xft1/t51.2885-15/s640x640/sh0.08/e35/12362418_1524224207890655_1490508958_n.jpg
https://scontent.cdninstagram.com/hphotos-xpt1/t51.2885-15/s640x640/sh0.08/e35/12353459_775571625903583_1955055891_n.jpg
It's like putting fog lights and a spoiler on your 2002 Nissan Sentra.
Am 05.02.2016 um 09:09 schrieb Thomas de Groot:
>> a few
>> bucks more ...
The purpose of the illumination is, in descending order of importance,
(1) to show off
(2) to see the keys even in almost total darkness
(3) to show off
(4) to remember what mode or profile you've currently set the
programmable keys to
(5) to show off
(6) to remember what type of stuff which key does in the game you're
currently playing
(7) to show off
(8) to remember what combo keys go with a particular key you've just pressed
(9) to show off
For the purpose of (1), (3), (5), (7) and (9) you can set the keyboard
to show all kinds of fancy animations.
For the purpose of (2), you can set the entire keyboard to show a
uniform colour with adjustable brightness. For the purpose of (4), you
can specify the colour on a per-profile or per-mode basis, e.g. for a
roleplay game you might want to use green to indicate that the macro
keys are currently set up for playing as a healer, yellow for a ranged
weapons fighter, red for a melee weapons fighter, and blue for a mage.
For the purpose of (6), you can specify the colour on a per-key basis,
e.g. you might assign blue to movement keys, yellow to keys for
switching weapons, red for attacking, and for non-combat stuff.
For the purpose of (8), the newest generation of keyboards also allow
you to further specify the colour based on what keys you're currently
pressing, or have just pressed a few moments ago.
My no-longer-trusty old G19 catered to (1)-(5).
The Corsair k95 RGB keyboard I expect to be delivered tomorrow will
cater to (1)-(9) and presumably (11) and (13), but the main reason I'm
getting it is the whopping 18 dedicated macro keys. I'm also looking
forward to the ability to re-program not only those dedicated macro
keys, but each and every key I feel like messing with.
Like, say, reprogramming the decimals separator on the numeric keypad to
either "." or "," to match the application I'm currently working with.
Getting fancy illumination with this is ok.
>> a few
>> bucks more ...
Keyboard lights could be useful for something like this.
http://isometricland.net/keyboard/keyboardchart.php?gam=51&sty=1&lay=1
Mike
>>> a few
>>> bucks more ...
> [snip]
I see that my life is slowly drifting away from the mainstream. I shall
soon be resting in the stagnant backwaters. :-) Fine by me by the way.
If you can give purpose to the lights, then OK of course.
Am 05.02.2016 um 20:17 schrieb clipka:
A metal casing top is also an interesting feature...
This baby needs some modding though: The light bleeding out from under
the key caps /is/ counter-productive for all purposes except showing off.
That's what I thought.
