POV-Ray : Newsgroups : povray.off-topic : Hacknet Server Time
15 Jun 2026 15:50:30 EDT (-0400)
  Hacknet (Message 21 to 30 of 34)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: Hacknet
Date: 4 Nov 2015 19:12:23
Message: <563a9ee7$1@news.povray.org>
On 11/4/2015 10:53 PM, Jim Henderson wrote:
> On Wed, 04 Nov 2015 22:14:15 +0000, Stephen wrote:
>>> Could be - generally a harmonic frequency can cause weirdness as well -
>>> I
>>> was more talking about why it's lines and not just snow.  The proximity
>>> of the transmitter to the "receiver" is what causes that.
>>   From the little I know only having worked, with Comms guys. You are
>> right but then you could tell me anything. It is all magic to me.
>> They even told me that our phone calls were bounced off the sky and the
>> sea. And I believed them.
> Well, I do have a radio license. ;)
So do I. Albeit the lowest level (RT). I could use a marine radio on a
fishing vessel or stand in for the RO on an Oil Rig.
> But that's the reason that proximity to the transmission point for the EM
> waves matters - and a closer but power power (at transmission point)
> overpower a signal that's farther away but stronger.  With a 5W
> transmitter that's not well filtered, an amateur radio operator can
> disrupt commercial radio (AM/FM) and TV (VHF/UHF) transmissions quite
> significantly.  Every amateur radio operator has to learn at least a
> little about this in the US, because we're responsible for dealing with
> harmful interference we might cause with our gear.
It is quite a fearsome exam. With Morse code and regulations.
> Even with well-filtered equipment, though, if I put the transmission
> source for my radio right next to a computer monitor or CRT display, I
> can cause some interference.
Don't forget the cable. Bad connections can cause reflections. ;-)
Regards
Date: 4 Nov 2015 20:08:00
Message: <563aabf0$1@news.povray.org>
>>>> I
>>>> proximity of the transmitter to the "receiver" is what causes that.
>>> the sea. And I believed them.
I thought you did - so I was a little surprised. :)
>> EM waves matters - and a closer but power power (at transmission point)
Code isn't required in the US any more - they dropped it out of (as I
understand it) fear that not enough people would join the hobby to
justify the spectrum use.
Oh yes, absolutely.  I also tend to pick up RF from my PCs on my
headphones (the ones plugged into the PC), even with a proper ground.
Jim
"I learned long ago, never to wrestle with a pig. You get dirty, and
besides, the pig likes it." - George Bernard Shaw
Date: 5 Nov 2015 03:12:54
Message: <563b0f86@news.povray.org>
> I left a program running overnight. The next morning, even after booting
> back into Mac OS, the text was still faintly visible.
That should go away after a while, but I'd be careful leaving a static
image for any longer on that screen if that happens already after just a
night.
>>> While we're on the subject, what causes the weird diagonal lines that
>>> all RF-modulated signals have?
>> Non-perfect electronics :-)
> Why lines though? Why not random snow or something?
Designing RF stuff is tricky as every part of your circuit will blast
all the other parts with whatever signal is on it. I suspect it's just
some interference or some component creating harmonics, and they just
happen to manifest as diagonal lines.
Date: 5 Nov 2015 03:55:49
Message: <563b1995$1@news.povray.org>
There is a big difference between being able to use a radio and design
and maintenance.
It's not? I thought it was an international requirement for a Ham
licence. Even at foundation level (5 wpm).
See, black magic. :-)
Regards
Date: 5 Nov 2015 11:47:09
Message: <563b880d@news.povray.org>
> and maintenance.
Well, true - I don't know what the UK tests are like - in the US, there's
a lot of radio theory even in the lowest level exams.
The Extra class license is (or at least "used to be" - I took my exams 20
+ years ago now, and that was only the technician level exam) more
difficult than some of the commercial license exams.  At least, that's
what I was told by someone who had both a commercial license and an extra
class license. :)
Nope, no requirement at all now.  The ITU ratified a decision to allow
each country to decide on its own if CW was required or not back in
2003.  The FCC dropped the requirement from all license classes in 2006
(effective in 2007).
I got a "technician" class license in the early 90's, just after the
requirement was dropped for that class (but the class was limited to 2m,
70cm, and 6m - nothing in the ranges the ITU required it for - generally
below 30 MHz IIRC).  Same exam as the then-new "Technician Plus" (which
was the old "technician" class, confusingly), and my license was
grandfathered back to full Technician when the requierment was dropped
from all classes in 2007.
>>>> I can cause some interference.
LOL
Date: 5 Nov 2015 13:26:25
Message: <563b9f51$1@news.povray.org>
It did. A few hours later, it was gone.
> night.
Quite. We only have the damned thing for testing purposes...
OK...
Date: 5 Nov 2015 13:28:33
Message: <563b9fd1$1@news.povray.org>
But do you have to be able to use a Smith chart?
Date: 5 Nov 2015 13:31:51
Message: <563ba097$1@news.povray.org>
>> and maintenance.
What I meant was the difference between theory and practice.
> class license. :)
I should hope so. Was it military training? I've worked with a couple of
exRN "Sparkers" and "bunting tossers". There would be a lot of drink
involved, I would guess.
Obviously I'm not up to date. I imagine "Attics, cardigans and a tuned
loop antenna".
All done by Magic. :-)
> LOL
Regards
Date: 5 Nov 2015 14:04:42
Message: <563ba84a$1@news.povray.org>
Not for an operator's ticket.
Regards
Date: 5 Nov 2015 15:51:49
Message: <563bc165@news.povray.org>
FYI
Humphrey Lyttelton. That reminds me.
http://www.bbc.co.uk/programmes/b007jndb
Regards
