Coming up often and just noted that again in Ger's answer in the thread
above.
What is the meaning of percentages higher than 100? I don't get it.
If my bottle of wine is considered 100% full, what would be 200%? Two
bottles of wine? :-)
> above.
The answer is pretty simple.
If 1 (one) core is working on povray that would be 100% load. If 2 cores are
working on povray that would be 2 x 100%. So, in my case that would be 8
cores, each working at (or close to) 100%, so 800%.
The percentage load is taken from the "1 core" or "1 proc" view.
Ger
>> above.
OK. I missed the 8 cores obviously. it makes sense, but
Still, I feel uncomfortable with the notion itself and would rather
think that povray is rendering at 100%, divided over 8 cores... each
working at 100%... for me, that does not add up to 800%, only to faster
rendering, which is why I guess this is a semantic question.
Yes, typically % is defined as % of some (obvious) maximum. Defining CPU
load as a % of only 1 core being fully loaded seems a bit
counter-intuitive. But so long as everyone is aware of this, and they
know exactly how many cores are in the CPU then it shouldn't be a huge
problem. If we didn't know there were 8 cores, 800% could mean anything.
Also, in general, when you combine percentages from various bits you
need to sum the numerators and denominators separately, otherwise you
get a wrong result.
eg
Bag 1 has 6 apples out of space for 10 : 6/10 = 60% full
Bag 2 has 3 apples out of space for 4 : 3/4 = 75% full
Combined there are 9 apples out of space for 14, so 64% full. NOT 135% full!
> get a wrong result.
> eg
> full!
Thanks indeed. That sums it up nicely :-)
The case of Ger's which triggered my thread is pretty obvious and
acceptable in the context. However, the misuse nowadays in all kinds of
situations seems to be growing and can be pretty annoying sometimes.
Yes, whenever an athlete/sportsperson says they "gave it 110%" they
should be immediately investigated for doping :-)
That's a fair assumption indeed ;-)
Am 02.09.2015 um 09:15 schrieb Thomas de Groot:
I think there are plenty of cases where values >100% are perfectly ok,
such as:
"This year, our budget has increased by 250% [compared to last year]."
"Let's see for how long we can push the engine to 120% [nominal] thrust."
"This amplifier has a gain of 420%."
"This telescope rod can extend to 550% [of its retracted length]."
Reminds me of my last company, where the profit was always hovering
around zero (and sometimes negative). The column "profit compared to
last year" was always an amusing one, it could be 1000000% or negative,
or the year after a negative amount they didn't know what to do so left
it blank that year :-)
> such as:
Yes, I suppose so but more often than not the bracketed portion is
omitted which results in confusion, at least for me.
One full bottle and a lot of spillage. ;-)
Regards
I think that the media percentage is different from normal percentage.
Regards
That was my conclusion too...
[finishes mopping up the mess left on the table]
The fun part is when you have 4 cores with hyperthreading, and a task
manages to consume more than 800% CPU...
In other news, the Windows "Process Explorer" tool considers my computer
to have 8 physical cores, when in fact it has 4 cores with 2x
hyperthreading. Which means that maximum utilisation is reported as 50%...
Running the marathon with one body / two legs is hyperthreading without
knowing it... ;-)
Am 19.09.2015 um 09:21 schrieb Thomas de Groot:
>> 50%...
> knowing it... ;-)
I /think/ that analogy limps a bit, as we'd say in German ;)
>>> 50%...
>> knowing it... ;-)
Of course, but I couldn't resist.
Ditto here, but all CPU-intensive apps I've got manage to get to a
reported 100% CPU (POV, commerical simulation tools, multi-threaded C#
apps, etc).
>> 50%...
> apps, etc).
Are you looking at the Windows Task Manager rather than the System
Internals Process Explorer?
>>> 50%...
>> apps, etc).
Both:
Download 'croppercapture[40].png' (54 KB)
Preview of image 'croppercapture[40].png'
![croppercapture[40].png](/povray.off-topic/attachment/%3C5600f82a%40news.povray.org%3E/croppercapture%5B40%5D.png?ttop=438856&toff=400&preview=1)
>>> apps, etc).
> Both:
Interesting. Perhaps you have a newer version of Process Explorer? Or
maybe there's some setting somewhere to configure this that I haven't
noticed...
> noticed...
v16.05 here, can't see any relevant setting.
If I tell POV to render with 6 threads I only get 50% usage, but with 12
threads I get 100% usage.
However the elapsed times for the benchmark are:
6 threads : 192s
12 threads : 136s
So 50% CPU is actually more like 70% CPU, but I guess it depends on the
exact algorithm (how nicely it can hyperthread).
>> noticed...
> 6 threads : 192s
> 12 threads : 136s
From my personal bench with povray, a HT-core is worth between 20 to
25% of a real core. (tests done on i7 980X, at nominal speed, with
benchmark scene)
If the OS is not total crap, the threads are allocated first on distinct
real cores.
beware, when comparing with time, the performance is 1/time.
your 6 threads has a performance index of 5.20833, about 0.868 per thread
your 12 threads has one of 7.35, about .613 per threads.
(and if you remove the 5.208 from the 7.35, the additional HT-core only
provides 2.142, that's 0.357 per HT-core, so a HT-core thread is in your
system about 41% of a real core thread, for povray-binary and your scene).
> benchmark scene)
This is on Win 7 with the standard POV binary, the benchmark scene and a
Xeon E5-1650 @ nominal speed.
Yes, I think the additional HT'd threads being worth 41% of a real core
thread, is the same thing as saying that if you only use the real cores
you're utilising about 70% of the total CPU performance available. I
assume that modern compilers optimise code to be hyperthread nicely?
Am 22.09.2015 um 15:06 schrieb scott:
Most unlikely - there's nothing much to optimize there.
In a hyperthreaded CPU, you actually /do/ have the number of cores that
the task manager claims you have, but they're not independent; instead,
they are organized in pairs that share various resources; for instance,
there might only be one floating-point arithmetics unit for each pair of
cores.
Any thread that needs any such shared resource /will/ compete for it
with any other thread running on the pair's other core. And as you
typically can't optimize away such resource requirements, you can't
optimize away the competition. In addition, different CPU types might
share different resources among core pairs, so you don't even know what
resources to try to avoid.
There might be ways for an application developer to optimize an
application for hyperthreading; the strategy would be to separate the
application's workload into two groups of threads that use different
sets of CPU resources, and coax the OS to run one thread from each group
in each pair of HT cores; this way, competition for resources will be
reduced. However, it might not be easy to partition the workload in such
a manner.
>> noticed...
> 6 threads : 192s
> 12 threads : 136s
Oh, I see. I'm still running the single-threaded POV-Ray binary. So if
it uses 1 core, it says 12.5% CPU. I thought you were saying your copy
says 100% for each CPU core used. ;-)
Now why doesn't that surprise me? :-)
It surprised me. Ver 3.7 is shiny.
Regards
Am 22.09.2015 um 22:58 schrieb Orchid Win7 v1:
Okay, now is officially the time for you to upgrade to POV-Ray 3.7. If
you refuse to, I /will/ consider that as a personal insult.
I've put a lot of effort into that version to make it awesome. You don't
need to try UberPOV (which is even more awesome), but you absolutely
/must/ install version 3.7. Now. No excuses.
(And yes, I /am/ at least semi-serious about the personal insult thing.)
I remember it being in beta for a long time, and having lots of
interesting-sounding stuff. I wasn't aware it had actually made it to
release version yet.
Then again, when was the last time I did much with POV-Ray? Sure, it's
running 24x7 working on an animation, but I wrote that years ago. I
haven't really "used" it much recently...
An animation! I would get the latest version just for the speed up.
You've mentioned this animation before. Refresh my memory, if you would?
Regards
https://www.youtube.com/watch?v=8s7I80H96CM
That took about 2 years to render. I'm currently rendering the sequel,
which is a similar thing inside a Cornell box.
