Let's say that I have a array of points generated from a height field.
But I want areas of low slope to be made completely flat and rounded to
the nearest 24 vertical units.
I know that the result will no longer be a classic heightfield since
there will be vertical areas that will need to be joined by new
triangles. But how would I accomplish this?
The simplest thing to do would be to measure the slope of each triangle
relative to the ground plane and then alter the vertices. But the
triangles are in a regular grid:
http://i421.photobucket.com/albums/pp292/SharkD2161/LDraw/terrain_nosteps_standin_01_zps6hreaqla.png
It will look funny since all they are all oriented in the same direction.
Thanks for the help!
Mike
Am 15.08.2015 um 06:49 schrieb Mike Horvath:
Sounds like what you want is the equivalent of a 2D array of boxes, with
each box's height determined by an input image. Do I understand that
correctly?
POV-Ray currently doesn't provide any native support for such an object
(except of course an actual array of boxes, a mesh generated by a custom
macro, or some such). It shouldn't be too difficult to implement such a
primitive though.
> correctly?
> primitive though.
I only need the special behavior when the slope is already low. For
areas with a large slope I want to retain the original smooth mesh.
I will have to do the calculations myself because I need to be able to
import the mesh into LDraw.
Hash: SHA256
>>> field. But I want areas of low slope to be made completely flat
>>> and rounded to the nearest 24 vertical units.
>>> since there will be vertical areas that will need to be joined
>>> by new triangles. But how would I accomplish this?
>> boxes, with each box's height determined by an input image. Do I
>> understand that correctly?
>> object (except of course an actual array of boxes, a mesh
>> generated by a custom macro, or some such). It shouldn't be too
>> difficult to implement such a primitive though.
> For areas with a large slope I want to retain the original smooth
> mesh.
Assuming the height-field is created from an image, what you seems to
want is a local filter to detect slope and make them flat... aka
uniform in colour.
With the exception of nearest 24 vertical unit rounding, that looks
like a color/palette reduction in any decent picture manipulation
program. That kind of thing.
> to import the mesh into LDraw.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2
iJwEAQEIAAYFAlXPAN0ACgkQhKAm8mTpkW2fcAQAifIjBBLeXx45pPguEg2d2YXI
hdev1wOnwEbrEMW0GGJ/oTPJ6bAKY78+LeKh/Bn7m5JXVCf8FRPA/MHWSNjwXnJ4
WAYRGgHkOM4SMZtUKB1KjB3i310FOFJ8qRQusl8R3oG2o4X8CxnyyboN461Wz+Q6
SaOq9MvsmB9lH6SZi50=
=4Hr0
-----END PGP SIGNATURE-----
> uniform in colour.
I was wondering if the slop pattern could be used to create a modified
image to use as a height field.
Regards
How do I calculate the slope of a 3D triangle with respect to the ground
plane? And I need a non-POVray solution. Thanks.
Mike
On Sat, 15 Aug 2015 06:49:23 +0200, Mike Horvath <mik### [at] gmail com>
> Mike
Maybe open the map in Photoshop. The largest areas should be the flattest
areas, so they should be easy to select with the Magic Wand Tool. Once
selected, Image adjustment/Gradient Map should do the trick if you edit
the gradient to be only 24 shades of grey.
-Nekar Xenos-
Hash: SHA256
> ground plane? And I need a non-POVray solution. Thanks.
> Mike
basic 3x3 matrix of delta, in height field.
You get 8 products ( assume a 3x3 grid, numbered clockwise around the
center cell, of vectors from center cell to border cell: 1-c-2, 2-c-3,
...up to 8-c-1 ).
The projection on the plane of each products is 45°, so the sum of the
8 values gives you a criteria to detect a relative null curvature.
(there is the true flat situation, and the monkey saddle, but for the
central point, all of them are of flat at center).
Now, if you have a true triangle, it's another matter, just compute
the normal and normalize it, then project on the vertical axis and
check the length of the projection.
Version: GnuPG v2
iJwEAQEIAAYFAlXQ17IACgkQhKAm8mTpkW117wP9Fa2lWNrXLdfg2bU5zT6Fq5HX
aUwL5j/M7N5v9nKGPJAQwwLncb3R0Uzr0kZQS4s18g+JYsdnaovj2eZd+8QfChNd
gpXunDXsvdva1WZTGPjCmkXjVakdKre79MwjShQoKvhjSOHCKR13dnpTILExTwsm
EQHjBpCJ80RFk9rFrQI=
=qiQo
Some code would be helpful. JScript or VB or Lua please.
Mike
> flattest areas, so they should be easy to select with the Magic Wand
> Tool. Once selected, Image adjustment/Gradient Map should do the trick
> if you edit the gradient to be only 24 shades of grey.
1. An image is not going to work because the result may have coordinates
sharing the same XZ positions, but differing in Y. You can't do this
with images.
2. I want a solution in code, not one where I have to do things by hand.
>> uniform in colour.
Can POVray produce images suitable for using as heightfields?
>>> uniform in colour.
Yes, use an orthographic camera and a square aspect ratio.
But I don't have enough experience to guide you on the slope pattern.
Regards
What I mean is, isn't there a special 16 bit format used by
heightfields? Can POVray save as this special format?
Mike
On Thu, 20 Aug 2015 02:17:24 +0200, Mike Horvath <mik### [at] gmail com>
Yes there is. But I can't remember the command line settings. I think it's
in the docs.
-Nekar Xenos-
Am 20.08.2015 um 02:17 schrieb Mike Horvath:
There /used/ to be a special variant of the .gif format known as POT
files, back in the good old times when most file formats were limited to
8 bit (total!) per pixel.
To my knowledge, POV-Ray was never able to write this format itself (in
fact it seems that the only commonly known program that ever wrote this
type of format was the infamous FractInt), and I'm not even sure whether
POV-Ray can still read it.
Also IIRC there's some hackish solution in the code for using two colour
channels of a 3*8 bits-per-pixel file format to achieve a depth of 16
bits; again, I'm not sure whether POV-Ray can also write this format.
Be that as it may, all those solutions are pretty much obsolete these
days; POV-Ray can use any of the supported image file formats for height
field data input, including several contemporary ones that natively
support a depth of 16 bits per colour channel (such as PNG).
To generate an output file with 16 bits per colour channel, use the
"Bits_Per_Color=n" ini file option, or the "+Fxn" command-line option
where "x" is the letter representing the desired file type, such as "N"
for PNG.
Specifically for the use with height fields, POV-Ray also supports
greyscale-only 16-bit file output (which saves a bit of disk space and
is faster and more memory-efficient when used as input) for the PNG file
format; to enable this, use "Greyscale_Output=true" or "+FNg".
One thing worth noting is that you should specify the "File_Gamma=1" ini
file option and "assumed_gamma 1.0" global scene setting when generating
files for height fields.
On 8/20/2015 6:03 AM, clipka wrote:
> There/used/ to be a special variant of the .gif format known as POT
That is how I first heard of PovRay. From the FractInt (why infamous?)
help doc.
Regards
> help doc.
Yes, POV-Ray can use POT files for height_fields. See the Docs.
Fractint was far from infamous. To the contrary, it was the most
formidable mandelbrot generator of its days available to the general
public. It contributed to my discovery and use of POV-Ray too.
Am 20.08.2015 um 08:20 schrieb Stephen:
> help doc.
Infamous because, while I hate to admit it, my English isn't perfect :-}
For some reason I was convinced that the word could be used with a
connotation of respect for outstanding achievements and bravado
bordering (or beyond) the illegal - possibly because the German
equivalent, "berüchtigt", can sometimes be used in this sense
(especially in the combination "berühmt-berüchtigt").
Strike that, and insert "badass" instead.
It is probably better than mine. :-)
Init!
Google translates berüchtigt as notorious. Which fits in with your
definition. I would have said the renowned Fractint.
I don't suppose it is any easier when words like wicked and cool, have
reversed their meanings in recent years.
Regards
> Mike
Wow, Stack Exchange is stumped too! So far about a half dozen people
haven't been able to figure it out.
Mike
That is interesting. I think that in Dutch (beroemd-berucht) that would
not be possible. At least I think so... Language is a tricky business.
