POV-Ray : Newsgroups : povray.off-topic : Fractal screen Server Time
16 Oct 2026 16:04:27 EDT (-0400)
  Fractal screen (Message 1 to 20 of 20)
Subject: Fractal screen
Date: 7 Aug 2015 13:05:00
Message: <55c4e53c$1@news.povray.org>
OK, so some people around here work with LCDs...
We've got a laptop at work with a cracked screen. Around where the crack
is, the pixels are all black. Which isn't surprising. Slightly more
interesting is the red vertical lines that seem to extend vertically
outwards from the cracks. Why red? Why every other pixel? Why vertical?
I have no idea.
What's weirder still is that close to the cracks, the dead pixels
exhibit a curiously fractal pattern. It looks like some kind of weird
pixellated plant growth or something. Does anybody have any idea why?
(I've got photographs, but I'd have to find something that has Bluetooth
in order to get them off my phone...)
Subject: Re: Fractal screen
Date: 7 Aug 2015 14:18:31
Message: <55c4f677$1@news.povray.org>
Unless we see them. It is not true. ;-)
Regards
Date: 7 Aug 2015 16:45:00
Message: <web.55c51792771bab4db426f96a0@news.povray.org>
No idea. But it reminds me of what I saw last year on somebody's water damaged
plasma TV. The unit worked fine, except for a localized black dendritic growth
that looked a lot like a cellular automaton. The guy said it changed and moved
across the screen over time... very strange (but cool).
Can you at least upload them to this site? http://postimage.org/
Date: 7 Aug 2015 19:41:42
Message: <55c54236$1@news.povray.org>
Am 07.08.2015 um 19:05 schrieb Orchid Win7 v1:
Because the display is now a hardware implementation of a cellular
automaton?
Date: 7 Aug 2015 21:10:01
Message: <web.55c555b2771bab4d2aaea5cb0@news.povray.org>
> I have no idea.
At first, I was thinking it could be a moire effect, but...
"LCD stands for "liquid crystal display" and the liquid crystal inside a screen
is subject to different levels of current to change the amount of the backlight
that passes through. When a screen is cracked, this process breaks down and
incredible patterns emerge, as some sections of the goo is electrified and some
isn't." -- Wired UK
Fractal forums had something about it possibly being a form of Diffusion-Limited
Aggregation.  Something like a Lichtenberg Figure, maybe?
Diffusion-Limited Aggregation is a process whereby, particles undergoing a
random walk via Brownian motion, tend to cluster together.
It would make sense that the crack in the screen disrupts the even distribution
of electrons through the liquid crystal, and the result is that the distribution
becomes chaotic and the electrons go where other electrons have been.
I have no technical expertise with electronics, so this is the best idea I can
come up with.  I have nothing on the red lines.
A.D.B.
Date: 7 Aug 2015 23:15:01
Message: <web.55c57306771bab4db426f96a0@news.povray.org>
> Aggregation.
http://www.fractalforums.com/fractals-in-nature/broken-lcd-screen/
Date: 8 Aug 2015 00:19:46
Message: <op.x207m3opufxv4h@xena>
On Fri, 07 Aug 2015 19:05:08 +0200, Orchid Win7 v1 <voi### [at] devnull> wrote:
> I have no idea.
Our laptop had vertical multicoloured lines and not much fractal beauty.
-Nekar Xenos-
Date: 8 Aug 2015 00:28:09
Message: <op.x20701v3ufxv4h@xena>
On Sat, 08 Aug 2015 05:09:58 +0200, Samuel Benge <stb### [at] hotmailcom>
wrote:
> fractalforums
After scrolling down, the next two images show these wonderful leaf-like
fractals.
Does anyone know the algorithm for these? I would really like to be able
to use it off-off-topic :)
-Nekar Xenos-
Date: 8 Aug 2015 13:30:00
Message: <web.55c63b67771bab4db426f96a0@news.povray.org>
> wrote:
> > fractalforums
> fractals.
I know of at least two ways.
The first method has a seed layer (2D or 3D array), and a 1D array of particle
positions. Each particle moves around randomly (usually via Brownian motion)
until it detects a positive value on the seed layer. At this point it dies and a
value is added to the seed layer. Another particle is then introduced from some
convenient location, such as a screen edge. Since a particle rarely slips
between pixels before making contact, branching growth occurs.
The second method uses an additional 2D or 3D layer representing a solution
(instead of an array of particles). Every cell is evaluated at every frame. The
solution layer is 'saturated' at initialization. If the solution layer has
material to expend and a neighboring cell of the other layer has a positive
value, then material is added to that other layer and material is subtracted
from the solution. The solution is blurred each frame, which simulates diffusion
(albeit with some loss).
I hope that made sense :/ Maybe I'll get something going and upload it to
glslsandbox.
Date: 8 Aug 2015 18:50:00
Message: <web.55c6875f771bab4db426f96a0@news.povray.org>
"Samuel Benge" <stb### [at] hotmailcom> wrote:
> Maybe I'll get something going and upload it to glslsandbox.
OK, here's something if anyone's interested: http://glslsandbox.com/e#27058.0
You'll have to place the mouse in the lower left corner to properly initialize
the layers (goofy mistake). Seeds are automatically placed under the mouse
cursor.
The effect tends to be large-scale compared with other diffusion-limited
aggregation setups, but it can be tweaked by changing the settings.
Date: 8 Aug 2015 19:40:02
Message: <web.55c69275771bab4d2aaea5cb0@news.povray.org>
> cursor.
neat. But is there a way to add constructive interference?  It could make a
great simulator for frost, if you could do that.
A.D.B.
Date: 8 Aug 2015 20:35:01
Message: <web.55c6a002771bab4db426f96a0@news.povray.org>
> > cursor.
I was thinking about another version that adds a water tank/ripples effect to
the solution... is that what you mean? It would be interesting to see how the
solid layer builds faster in areas of the solution where it's concentrated due
to CI. Hm...
Date: 9 Aug 2015 00:45:00
Message: <web.55c6d99f771bab4d2aaea5cb0@news.povray.org>
> > > cursor.
> to CI. Hm...
mostly, I was thinking that the end result would look less like a voronoi
diagram.
to have it really look like frost, it would have to grow in spikes that get
wider as they get longer.  I have no idea how you'd do that...
A.D.B.
Date: 9 Aug 2015 01:30:13
Message: <op.x225kglqufxv4h@xena>
On Sun, 09 Aug 2015 00:49:03 +0200, Samuel Benge <stb### [at] hotmailcom>
> initialize
> mouse
> cursor.
Beautiful.
It would be nice to have as a Pov-Ray texture.
-Nekar Xenos-
Date: 9 Aug 2015 14:40:00
Message: <web.55c79e12771bab4db426f96a0@news.povray.org>
> > to CI. Hm...
> diagram.
It could be done, of course. Not yet sure how I'd go about it though...
Either reduce the amount of solution consumed, increase the growth rate, or do
both.
And for water crystals, it helps if the system uses a neighborhood that tests
cells six directions from center:
..oo
ooo
oo.
The result has a six-fold symmetry but ends up skewed, so to look good the final
image would need to be transformed.
Date: 9 Aug 2015 14:50:00
Message: <web.55c79fd4771bab4db426f96a0@news.povray.org>
> > initialize
> > mouse
> > cursor.
> Beautiful.
Thanks.
You could always take a screenshot, crop out the window frame, and remove the
blue channel.
Alternatively, it can all be done procedurally in POV, if you're prepared to
render many, many frames, or endure an hours-long parse time :P
Date: 10 Aug 2015 03:02:36
Message: <55c84c8c$1@news.povray.org>
> I have no idea.
It's more than likely due to the column drivers malfunctioning. One
possible column driver scheme is to use only one DAC for each *pixel*
column (not sub-pixel) and then multiplex the output between RGB
subpixels. It saves by a factor of 3 the number of DACs needed and the
number of wires to/on the panel. What is likely happening is that when
each row is getting refreshed, the driver is reset as data is clocked
in, red is likely first and it gets screwed (because all the column
tracks are broken at the crack so the wrong capacitance and resistance
or possibly even shorted) and it never manages to switch the output to
the green and blue columns.
Another possibility, if the drivers are on the glass substrate itself,
or a bare IC bonded to the glass, is that they got damaged when the
crack was made.
The "growth" bit is because gradually moisture is getting in to the LC
material through the crack. They are normally completed sealed in, I'm
not a chemist but I know moisture+LC is bad and gives those patterns
even without a crack. Also does the pattern move when you press around
the crack? It's likely the cell-gap (distance between the inner two
faces of glass) has changed due to the crack, that normally needs to be
very accurately controlled to create a uniform image.
Date: 11 Aug 2015 13:19:59
Message: <55ca2ebf$1@news.povray.org>
That's just trippy. Not quite as intricate as some of the
reaction-diffusion systems I've seen, but mental none the less...
Date: 11 Aug 2015 14:25:00
Message: <web.55ca3d6f771bab4db426f96a0@news.povray.org>
Freudian slip? It /is/ probably more of a reaction-diffusion system than it is a
traditional DLA ;)
More detail can be added by making the following line changes:
line 28: float solSub = 10.0;
line 92: R = 1.1 * Sol;
It looks much darker, though. Also, the resolution can be changed via a pull
down menu in the upper left (the default for all shaders is 2x).
Date: 11 Aug 2015 17:25:44
Message: <55ca6858$1@news.povray.org>
> traditional DLA ;)
It hadn't really registered that it's DLA. It looks like the type of
organic growth you sometimes see with RD systems.
The difference, of course, is that I understand how DLA works. ;-)
