POV-Ray : Newsgroups : povray.off-topic : Friday afternoon project: a real time ray tracer in your browser Server Time
16 Oct 2026 16:05:03 EDT (-0400)
  Friday afternoon project: a real time ray tracer in your browser (Message 1 to 33 of 33)
Subject: Friday afternoon project: a real time ray tracer in your browser
Date: 24 Jul 2015 11:05:09
Message: <55b25425@news.povray.org>
An unbiased* global illumination ray tracer running in your web browser,
with a max_trace_depth of 8 and support for shiny, diffuse, transparent
and checkered spheres. What more do you want!
Just run the attached html on a PC with a fast GPU, you can drag around
the scene with your pointer. Inside the html file you can change the
size of the image (right at the end of the file you'll see width and
height tags), using non-power-of-two values may not work on your
graphics card.
You can get some pretty cool effects by looking through the glass ball
into the mirrored ball.
Disclaimer: It works on my machine (Chrome, Win7, nVidia GTX970) but
I've not tested it on any other machine. Particularly if you have a much
slower graphics card it may run so slowly that it crashes, or it may not
run at all. Also make sure you have the latest graphics drivers, no I'm
not just saying this it often makes a difference. The output should look
similar to the attached image after a few seconds.
After creating the standalone html5 page for blobs thread above, I
realised it would allow me to do something shadertoy doesn't - that is,
reuse results from a previous calculation in the next frame. I already
had an attempt at a path-tracer in C# (which was in turn translated from
some C++ code I found somewhere) but it was pretty slow. The main
sticking point I had was learning how to render to texture using webGL.
So it renders one "frame" at a time, which actually consists of 10
samples per pixel, it then averages this with all the previous results.
It then repeats until you move the viewpoint. The result is that once
you stop dragging the scene around the noise should disappear eventually.
Your browser will probably limit the speed of updates to 60 frames per
second, so that equals 600 samples per second. You can increase the
number of samples per frame on line 39. But I found if you make it too
high that a single frame takes longer than a second or so the video
driver crashes.
* One of the hardest bits is to get a random number generator running on
the GPU that is random enough to not show any patterns after a while.
There is still some subtle non-randomness visible, but it's way better
than it was originally. That's why there's random bits of code like
rng.x = sin(r1 - FrameNumber) in there. It seems to do the job.
Download 'rtpt.html.htm' (19 KB) Download 'image.png' (355 KB)
Preview of image 'image.png'
Subject: Re: Friday afternoon project: a real time ray tracer in your browser
Date: 24 Jul 2015 13:00:11
Message: <55b26f1b$1@news.povray.org>
Damn, that sounds nice...
Ah well. I just get a JavaScript alert telling me that it can't
initialise shader1, then a couple that say "null", and then a message
that it can't initialise shader2.
Ironically, I have a nearly identical setup: Opera (so, the Chrome
rendering engine), Windows 7, and an nVidia 600-series GPU.
Ah yes - it's not like you can just run the Mersenne Twister on a GPU... ;-)
Date: 24 Jul 2015 13:26:12
Message: <op.x2af1lr3ufxv4h@xena>
On Fri, 24 Jul 2015 19:00:19 +0200, Orchid Win7 v1 <voi### [at] devnull> wrote:
Same here. But that was on Chrome. My graphics card is only an Ati 5770
-Nekar Xenos-
Date: 24 Jul 2015 13:57:48
Message: <55b27c9c$1@news.povray.org>
>> GPU... ;-)
Hmmm odd, I wonder why that is. I just tested it on my work PC (nVidia
Quadro something) and it worked ok.
Maybe it's something to do with the length of the shader? You could try
reducing the number of samples down to 1 (line 39) and the trace depth
down to 2 or something (line 118), that should make the shader much shorter.
Date: 24 Jul 2015 14:26:59
Message: <55b28373$1@news.povray.org>
In other news, I just found this:
http://madebyevan.com/webgl-water/
Now I'm wondering why this thing that runs in a web browser and barely
taxes the system looks 500x better than the water in any computer game,
ever...
Date: 24 Jul 2015 14:54:00
Message: <op.x2aj3x06ufxv4h@xena>
On Fri, 24 Jul 2015 20:27:08 +0200, Orchid Win7 v1 <voi### [at] devnull> wrote:
> ever...
Good question. Looks awesome.
-Nekar Xenos-
Date: 24 Jul 2015 15:10:00
Message: <web.55b28cf0dee5de4ab426f96a0@news.povray.org>
Excellent!
Um... how about full support for POV-Ray's SDL? jk ;D
It works on my laptop (hardware is two AMD A6-4400M APU 2.7 GHz processors w/
integrated Radeon HD 7520G GPUs [not particularly bragworthy]) using Firefox
(see attachment). IE couldn't initialize shader1, but it did display the samples
counter.
I'll have to look into reusing samples again. My sole attempt used a 32 bit RGBA
texture (unsigned 8 bpp), but it never converged into an acceptably noise-free
result. I figured if I used a higher bit depth I might get better results.
Download 'ffss-cropped.png' (154 KB)
Preview of image 'ffss-cropped.png'
Date: 24 Jul 2015 15:12:16
Message: <op.x2akycjhufxv4h@xena>
>>> GPU... ;-)
> shorter.
Great stuff!!
It works with samples 1, trace depth 6. If I try samples 2, I can only go
up to trace depth 3.
-Nekar Xenos-
Date: 24 Jul 2015 15:44:35
Message: <op.x2amf8kvufxv4h@xena>
> ever...
Wow! It even runs on my cell-phone!
-Nekar Xenos-
Date: 26 Jul 2015 08:47:33
Message: <55b4d6e5@news.povray.org>
> shorter.
I too was able to get this working by turning down the number of samples
and the trace depth.
I also doubled the size of the image, so I can see what I'm looking at.
(It seems to not like any size that isn't a power of 2. Then again, I
have no idea how this stuff works, so...)
Date: 26 Jul 2015 09:19:59
Message: <55b4de7f@news.povray.org>
>> shorter.
I presume it looks weird due to the limited trace depth. (?)
Download 'webgl.jpg' (108 KB)
Preview of image 'webgl.jpg'
Date: 26 Jul 2015 10:11:47
Message: <55b4eaa3$1@news.povray.org>
...actually, apparently you *can* run MT on a GPU. o_O
Trouble is, it's laughably slow.
Have you seen this? The accepted answer looks simplish...
http://math.stackexchange.com/questions/337782/pseudo-random-number-generation-on-the-gpu
Date: 26 Jul 2015 14:16:23
Message: <55b523f7$1@news.povray.org>
>>> shorter.
Yes it's probably highlighting the limitations in the RNG by only have a
low trace depth. I uploaded a video of what it looks like here (samples
40, trace depth 8) - woohoo for compressing noisy video!
https://youtu.be/rXQa5kHspFk
It only works with powers of two because your graphics card only allows
power of two sized textures, and I'm not doing anything clever to check
for powered-of-two-ness of the canvas size and creating bigger textures...
Also it's strange after staring at grainy images for a while your
eye/brain just filters it out and you don't notice it. It's only when
you then switch to a smooth image you go "wow that's really smooth" :-)
Date: 26 Jul 2015 16:25:19
Message: <55b5422f$1@news.povray.org>
Damn, your graphics card is *drastically* faster than mine... (When I
pan the image, it comes out yellow for the first half a dozen frames.)
Apparently it's time to buy a more expensive GPU.
As I say, I never get to see it completely smooth. But hey, I guess I
need a bigger stick. ;-)
I wonder... how long will it be before games look like this in realtime?
(I'm guessing a while, since this scene contains a piffling half a dozen
bits of trivial geometry.)
Date: 27 Jul 2015 03:00:13
Message: <55b5d6fd$1@news.povray.org>
That's because you had to reduce the samples per frame down. That
variable controls how many samples the GPU averages over for each
redraw. When you're rotating the scene it continuously redraws from
scratch so if you've got samples set to 1 it's going to look *very*
noisy. 40 is about the max I can do (at 1024x512 resolution) and still
spin around at what looks like 60 fps. Any higher and it starts to
stutter (even just dragging around other windows start to stutter too!).
Of course once you stop dragging it starts to remember the previous
frames and average them out.
Bear in mind my implementation is about as unoptimised as you could ever
get, it's just relying on brute force rather than anything clever at
all. For something far more optimised look at this:
https://www.youtube.com/watch?v=aKqxonOrl4Q
https://www.youtube.com/watch?v=BpT6MkCeP7Y
I'm sure if nVidia designed a path tracing specific GPU today it would
be plenty fast enough, the trouble is you're trying to shoe-horn some
algorithm into a chip that was designed for something completely different.
Date: 27 Jul 2015 03:15:01
Message: <web.55b5da64dee5de4a16086ed00@news.povray.org>
> graphics card.
> driver crashes.
I got a "Could not initialize WebGL" message. with a quadro FX3800
Date: 27 Jul 2015 03:57:47
Message: <55b5e47b@news.povray.org>
Does WebGL work at all on other sites? Try these:
https://www.chromeexperiments.com/webgl
https://www.shadertoy.com/
Date: 27 Jul 2015 06:47:27
Message: <55b60c3f$1@news.povray.org>
Looks promising, I'll save that page and see if I can implement it. It's
surely going to be better than my trial-and-error bodge.
As highlighted on that page, the main problem is that every single pixel
runs exactly the same code with the same inputs (apart from pixel
coordinate). So you need some way of making every pixel generate a bunch
of random numbers that are in no way related to any other pixels in the
image (otherwise you get strange patterns like you saw with your 1
sample image).
Date: 27 Jul 2015 11:37:43
Message: <55b65047$1@news.povray.org>
> Looks promising,
Or not. There's a few bits that don't work in WebGL. Specifically there
is no integer power function, xor operator, bit shifters or unsigned
ints (only signed ints). Seems like you need the full OpenGL for this...
Date: 27 Jul 2015 13:34:11
Message: <55b66b93$1@news.povray.org>
Ouch. Really? Damn...
Date: 27 Jul 2015 13:35:24
Message: <55b66bdc$1@news.povray.org>
> sample image).
I wonder how long before GPU gets a hardware-based randomness source?
(It can't be that hard to sample a little thermal noise in hardware,
especially if you don't need cryptographic strength. The problem is
usually that hardware randomness sources are a tad slow...)
Date: 28 Jul 2015 02:45:01
Message: <web.55b724a0dee5de4aea9e60760@news.povray.org>
This works out of the box on OS X Yosemite under Google Chrome and it does so
very well indeed. This is a very clever piece of work. Thanks for sharing it
with us.
Date: 28 Jul 2015 02:55:16
Message: <55b72754$1@news.povray.org>
> with us.
Thanks! I can only claim credit though for modifying an existing path
tracing algorithm to run on a GPU and modifying JS/WebGL boiler-plate
code from various sources. I'm quite happy that it all runs from a
single html document though, hopefully it's a good platform for anyone
to tinker about with.
Date: 29 Jul 2015 04:19:24
Message: <55b88c8c@news.povray.org>
So do you remember a few years(?) back when 3D Mandelbulbs were all the
rage? IIRC there were some threads on these very groups about rendering
them in POV, however it was painfully slow.
Well now you can do it in realtime on a (fast) GPU near you :-)
I need to tidy up the code a bit to make it easier to "fly around" and
control the detail settings, but here's a quick teaser:
https://www.youtube.com/watch?v=r_Ek3Kfv8KA
Note there's nothing pre-calculated here, the GPU is doing all the work
on the fly.
Date: 31 Jul 2015 20:55:52
Message: <55bc1918$1@news.povray.org>
Am 27.07.2015 um 19:35 schrieb Orchid Win7 v1:
Well, GPUs should at least be able to provide plenty thermal for the
noise ;)
Date: 4 Aug 2015 04:55:14
Message: <55c07df2$1@news.povray.org>
> noise ;)
Yes :-)  It's not hard to sample the thermal noise, the problem is how
to sample it billions of times per second with enough resolution to be
useful.
Date: 4 Aug 2015 13:00:38
Message: <55c0efb6@news.povray.org>
>> noise ;)
> Yes :-) It's not hard to sample the thermal noise, the problem is how to
> sample it billions of times per second with enough resolution to be useful.
Well, no, you typically sample it a few times a second and use that to
seed a normal PRNG.
In other news, Intel added an op-code to generate truly-random numbers
using exactly this technique. The Linux kernel team added it to
/dev/random... and then took it out again, because they were apparently
concerned that the NSA would modify the die of your CPU to make the
random numbers non-random. (!!)
Jesus, that's next-level. Surely if you don't trust the hardware your OS
is running on, it's already game over. (?)
Date: 5 Aug 2015 04:24:23
Message: <55c1c837$1@news.povray.org>
>> useful.
> seed a normal PRNG.
But will that not cause the same problems seen already today with
unrandomness? If the pixel shader for every pixel gets exactly the same
random seed value, and just uses a PRNG to modify it, won't you see
patterns? I would have thought every pixel needs its own unique random
seed value every frame to really get rid of those sort of PRNG patterns.
If you want a *truly* unbiased ray tracer for example.
Apparently the on-chip thermal noise sampler outputs a stream of bits at
3 GHz. I don't know how big the hardware is for that circuit, but it's
not *that* far away from what you'd need to get a true random number for
every pixel processed on the GPU.
Yes, something like a true RNG in every home home PC seems like
something the NSA would be extremely interested in.
Date: 5 Aug 2015 16:28:40
Message: <55c271f8$1@news.povray.org>
>>> useful.
>> seed a normal PRNG.
> patterns?
My plan was more to have some hardware that seeds a PRNG with a
truly-random seed and then distributes a *different* random iterate from
the PRNG to each thread in the bunch. It's awkward to code in software,
but shouldn't be that hard in hardware...
OK.
It's slightly mental that the government of one country can insert spy
hardware into every computer that can ever exist... Especially given
that all silicon fabrication is done in countries hostile to America...
But hey, what do I know?
Date: 6 Aug 2015 03:20:12
Message: <55c30aac$1@news.povray.org>
Oh don't worry, I'm sure if the NSA were capable of inserting spy
hardware into CPU dies, the fab itself would be more than capable of
changing it back to something more to their (or their government's)
liking :-)
Date: 6 Aug 2015 04:40:00
Message: <web.55c31ceddee5de4a16086ed00@news.povray.org>
no. it doesn't. too bad.
Date: 6 Aug 2015 06:34:33
Message: <55c33839$1@news.povray.org>
Am 06.08.2015 um 09:20 schrieb scott:
> liking :-)
That's what I was thinking. Yes, absolutely, totally. They'd sure know
exactly what features to look out for in a set of lithography masks...
Date: 6 Aug 2015 06:56:23
Message: <55c33d57$1@news.povray.org>
>> liking :-)
Only if they were "run" by the government - then I'm sure a team of
100's to reverse engineer and "fix" the "problem" would be easily
available for the job...
