Subject: How many digits of pi have you memorised?
Date: 15 Mar 2015 08:49:31
Message: <55057fdb@news.povray.org>
All of them. I'm just working on their order.
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Order?
Mine's a large one! Thank you. Dammed decent that man.
Regards
> Order?
\_/ There you go!
John
Protect the Earth
Subject: Re: How many digits of pi have you memorised?
Date: 15 Mar 2015 17:56:32
Message: <55060010$1@news.povray.org>
3.141592653589793238462643383279502884
Can't recall the rest accurately. (Hell, it's possible these aren't
correct.)
> correct.)
3.???
Can't remember the sequence.
101
Lionel
<b>Do not judge my words, judge my actions.</b>
L'absence de virus dans ce courrier électronique a été vérifiée par le logiciel
antivirus Avast.
http://www.avast.com
Am 15.03.2015 um 22:56 schrieb Orchid Win7 v1:
> correct.)
My pocket calculator says you're spot-on.
Though it makes me wonder whether you got the joke :P
(BTW, 3.1415 is all I can come up with on good days.)
Date: 16 Mar 2015 02:17:00
Message: <5506755c@news.povray.org>
>> correct.)
How I need a drink, alcoholic of course.
Gives you another three decimal places if you count the leters.
Regards
Date: 16 Mar 2015 14:36:46
Message: <550722be$1@news.povray.org>
Must be right then.
More like, this is probably the only chance I get to show off how much
free time I've invested in this pointless task.
Frankly, if you're measuring something that's 10 meters across, do you
even *care* about the last 5mm? Probably not.
Date: 16 Mar 2015 15:52:55
Message: <55073497@news.povray.org>
Am 16.03.2015 um 19:36 schrieb Orchid Win7 v1:
Not as much as other people, it would seem.
I guess they might have cared here:
http://en.wikipedia.org/wiki/Maeslantkering
Date: 16 Mar 2015 16:10:14
Message: <550738a6@news.povray.org>
> Must be right then.
I am impressed. Could you remember 355/113 as an approximation for Pi?
If you drew a circle a couple of miles in diameter. The circumference
would be less than a millimetre out.
Not if you are measuring it in cubits Otherwise that is a terrible
tolerance. For instance the first breakthrough from the English to
French side of the Channel Tunnel was 358 mm out over 22 Km.
http://www.quora.com/How-do-you-make-sure-the-two-drills-of-a-tunnel-meet
Regards
Depending on what it is, it's also probably going to change length with
temperature. For example a 10 metre bit of steel could easily be 5mm
longer in summer than in winter. Those 237 metre long trusses in the
other link could be 10cm longer. The system will be designed to cope
somehow with those changes in length, so the tolerances on those type of
parts is not that critical.
That's cheating though, that's like making your 10 metre bit of steel to
a +/- 5mm tolerance, then filing it down to fit :-)
Date: 17 Mar 2015 04:16:49
Message: <5507e2f1$1@news.povray.org>
or this: http://en.wikipedia.org/wiki/Large_Hadron_Collider
> a ± 5mm tolerance, then filing it down to fit :-)
It did say later in the article that that tolerance would have been
unacceptable for a running line.
I didn't mean to imply that it was good. Although I think that it is.
;-) The horizontal miss was less than 60 mm.
It is amazing the fine tolerances people can work to.
Regards
That's nothing - my car went 1200 km once and ended up with a less than
60 mm miss at the end :-)
Was that an undershoot or an overshoot? The latter can be very expensive ;-)
John
Protect the Earth
And my orange has a tolerance of half an apple. ;-)
Regards
Date: 20 Mar 2015 10:40:09
Message: <550c3149$1@news.povray.org>
I had a teacher who used to work for Pratt& Whittney and told us the
story of building his house. He was so used to working with military
specs that he built his house with tolerances in measured in microns.
He says that on the first rainy day, none of the doors in his house
would close.
(I have a feeling i was making this up, as you can't get that kind of
precision with a circular saw... and I'm pretty sure he didn't use a
5-axis CMC mill to build his door frames.)
/* flabreque */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
/* @ */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
/* gmail.com */}camera{orthographic location<6,1.25,-6>look_at a }
> specs that he built his house with tolerances in measured in microns. He
> says that on the first rainy day, none of the doors in his house would
> close.
I suspect in the military they take into account things like material
expansion ;-)
Date: 21 Mar 2015 16:57:42
Message: <550ddb46$1@news.povray.org>
>> close.
> expansion ;-)
Yep. That's one of the reasons the SR-71 leaked like a sieve on the
ground.
> close.
I would guess that it is an exaggeration for comic effect.
And a face saver. :-)
Regards
