POV-Ray : Newsgroups : povray.off-topic : A monologue involving binary log Server Time
16 Oct 2026 17:07:33 EDT (-0400)
  A monologue involving binary log (Message 1 to 50 of 78)
Goto Latest 50 Messages Next 28 Messages >>>
Subject: A monologue involving binary log
Date: 14 Feb 2015 10:33:32
Message: <54df6acc@news.povray.org>
OK, so it's been a while since I posted a big wall of text. So here goes...
The name of the game is data compression. If you already know how that
works, this is going to be a VERY boring post. If you don't know, it
probably seems like magic; you take a file, throw it at WinZip, and
suddenly the file gets 4x smaller.
Now MP3 does that to sound files, but it does that by DELETING DATA. The
compressed file has lower fidelity than the original. It's not that
surprising that you can make a file smaller by removing data from it.
But LOSSLESS compression algorithms do something seemingly impossible:
they take a file, somehow make it smaller, and yet the process is
EXACTLY REVERSIBLE. When you decompress the file again, it is IDENTICAL
to the original. How is that even possible?
Well, it ISN'T always possible. Sometimes when you zip a file it gets
tiny, and sometimes it doesn't get that much smaller. You may not have
experienced this, but occasionally a file will get LARGER. For example,
zip a file - any file - and then go zip the zip file. It WILL NOT get
any smaller. I promise. (Think about it; otherwise you could take an
arbitrary file and zip it over and over until it gets arbitrarily small.
But that really IS impossible!)
Rather than dwell on this further, I'm going to show you some
compression algorithms now. We're going to start with Huffman coding.
As you probably know, the American Standard Code for Information
Interchange ("ASCII") assigns an 8-bit code to every letter of the
alphabet. (You may or may not know that technically ASCII is actually a
7-bit code; any text encoding which actually *uses* the 8th bit for
something technically isn't ASCII, it's an ASCII extension.)
You might also be aware that Unicode defines zillions of characters as
24-bit codes. In UTF-32, every character is stored as 32 bits. In
UTF-16, almost all characters are stored as 16 bits, but particularly
unusual characters take 32 bits. And in UTF-8, many characters take only
8 bits, a few take 16 bits, the really rare ones take 24 bits and a tiny
few take 32 bits. (The extra bits are necessary to signal how many bits
make up the character.)
The various UTF encodings are of course designed to make encoding and
decoding as painless as possible, while not wasting absurd amounts of
space. UTF-32 is particularly easy to deal with, but very space-hungry.
UTF-8 is the most frugal, but quite awkward if there are lots of
multi-byte characters.
But suppose we want to assign codes to characters, not so that
processing is easy, but so that space is minimised. Ease of use is not a
requirement; we just want to crunch the space down as much as possible.
It seems obvious that the fewer bits per character we have, the less
space this is all going to take up. If you have a plain ASCII file, just
dropping every 8th bit already gives us 1/8 compression ( = 12.5%).
We can go one step further: Scan the whole file, and see which
characters are *actually used* in this file. Codes 0 to 31 in ASCII are
all "control codes", and with the exception of the newline character(s),
they're all pretty much obsolete now. By not assigning any code at all
to characters we aren't actually using, we *might* be able to get away
with 6 bits per character. Maybe.
But even if we do, that's still "only" 25% compression. And if there are
64 characters used then 6 bits of character will do, but if there are 65
characters used then we have to have 7 bits - which is annoying.
But now, suppose we assign different code lengths to different
characters. By assigning shorter codes to common letters and longer
codes to rare letters, we can potentially store the same data in very
much reduced space.
Suppose, for example, that we assign a 2-bit code to the letter E, and
7-bit codes to everything else. Then every single time the letter E
appears, we're saving 6 bits (compared to the original ASCII file).
Since E probably appears quite a bit, that could add up to substantial
savings. (Hint: The character " " probably appears *way more* than ANY
actual letter of the alphabet, but hey.)
It might seem tempting to assign the shortest possible codes to
everything. However, for X number of bits, there are only 2^X possible
codes. If you make one code shorter, you have to make other codes
correspondingly longer. So if you take a character that isn't *that*
common and give it a really short code, you'll have to make all the
other codes longer to compensate. Because the character isn't *that*
common, the savings from the short code don't make up for the losses in
all the other longer codes.
In summary, for every character there is a mathematically "perfect" code
length, which will give best possible compression. And that length is
equal to [the negation of] the binary logarithm of the probability of
that character appearing:
   bits(X) = -log2 Pr(X)
If X takes more bits than this, you're wasting space. If X takes fewer
bits than this, you're wasting bits somewhere else. So this is the
"perfect" length of X.
(Note that if we were trying to encode characters with decimal codes, it
would be log10 rather than log2. The 2 is because computers are binary.)
You can work out the "probability of X appearing" by simply counting how
many X characters there are in the entire file, divided by the *total*
number of characters. So that's easy enough.
Now, how to assign codes to characters? And how to figure out where one
character ends and the next begins? In a normal (ASCII) text file, you
know that each byte is one character. But if different characters take
different numbers of bits, how are we to know where the start and end of
each character code is?
The answer is to use a binary tree. For example:
     +   C
   A   B
Starting from the top, go left for 0 and go right for 1. If we start at
the top and go right, we immediately reach C. So C = 1. If we go left
and then left, we get to A. So A = 00. And B = 01. So from this tree, we
have
   A = 00
   B = 01
   C = 1
As we read bits from the input file, we can walk down the tree, going
left when we read a 0 and right when we read a 1. When we get to a leaf,
we spit out that character, and go back to the top of the tree. Easy.
[But very inefficient. There are tricks to speed this up, though.]
So to build a code which can be unambiguously decoded, we just need to
build a suitable code tree. How can we do that?
One way is to build a "Shannon tree". We count the characters in the
file, and end up with a table like
   Char  Prob
    A      7%
    B     12%
    C      3%
Now we need to build a tree. What we do is to try to split the set of
all [used] characters into two sets who's total probability is as close
to 50% as possible. All the items in the left subset get codes starting
with a 0, all the codes in the right subset get codes starting with a 1.
Now recurse. When a subset contains only one item, we have determined
its code.
Trouble is, splitting a set into two subsets with equal sum... That's
the Partition Problem, and it's NP-complete. Which is a technical way of
saying that this is REALLY FREAKING HARD to do well. Worse, there may be
more than one partitioning that yields roughly 50%, and which one you
pick affects how easy subsequent partitionings are. This looks really,
really hard...
Worse still, it can be proven that Shannon trees are sometimes
unavoidably sub-optimal. So this algorithm is really hard to problem,
really slow to execute, and doesn't even give optimal results. Great. :-/
The thing is, you don't need to do any of this. Because there's a way,
way easier algorithm: You can build a Huffman tree instead.
Instead of starting with the set of all characters and trying to
recursively split it to build a tree, we start with single characters
and recursively join them to build a tree. The algorithm is:
   1. Start with a set of trivial 1-element trees containing just a
character.
   2. Pick the two lowest-probability trees and remove them from the set.
   3. Combine the two trees, and insert the new tree back into the set.
   4. If the set has more than one tree, to go step 2.
It's difficult to come up with an example big enough to see what's
happening, but small enough to not take thirty pages of printout. Let's
try this:
   Char  Prob
    A      2%
    B      2%
    C      5%
    D     20%
    E     68%
    F      3%
Our initial set of trees is therefore:
    2%    2%    3%    5%    20%    68%
    A     B     F     C      D      E
The two lowest-probability trees are A (2%) and B (2%). 2% + 2% = 4%. So
now we get:
    3%    4%    5%    20%    68%
    F     +     C      D      E
        A   B
        0   1
Now we join F to AB:
    5%    7%    20%    68%
    C     +      D      E
        F   +
        0  / \
          A   B
         10   11
Now we join C to that tree:
     12%    20%    68%
      +      D      E
    C   +
    0  / \
      F   +
     10  / \
        A   B
      110   111
Add on D:
       32%    68%
        +      E
      +   D
     / \  1
    C   +
   00  / \
      F   +
    010  / \
        A   B
     0110   0111
And finally, our Huffman tree:
        100%
        +   E
       / \  1
      +   D
     / \  01
    C   +
  000  / \
      F   +
   0010  / \
        A   B
    00110   00111
So we have
   Char   Prob   Code    Bits   Log2(Prob)
    A      2%    00110   5      -5.643
    B      2%    00111   5      -5.643
    C      5%    000     3      -4.321
    D     20%    01      2      -2.321
    E     68%    1       1      -0.556
    F      3%    0010    4      -5.058
As you can see, the actual number of bits is quite close to -Log2(Prob).
(Only C is a bit off.) If E really does make up 68% of the characters in
the file, then by encoding it with just 1 bit, we're saving a huge
amount of space.
The trouble with all this, of course, is that in order to *decode* the
data, you need a copy of the Huffman tree used to encode it. So you have
to store that somewhere. Fortunately, if you pick the codes in a
suitable systematic way, it's possible to reconstruct the codes just by
knowing how many bits were assigned to each character.
Alright, so that's nice and everything. But look at that table again:
    A      2%    00110   5      -5.643
    B      2%    00111   5      -5.643
    C      5%    000     3      -4.321
    D     20%    01      2      -2.321
    E     68%    1       1      -0.556
    F      3%    0010    4      -5.058
Ideally, we want to assign half a bit to E. Well, that's *obviously*
impossible, right? I mean, a bit is a 0 or a 1. What the heck would half
a bit look like?
It turns out you *can* actually do this. (!) Suppose we want to use
exactly 1.5 bits per character. If you ask the encoder to encode 1
character, then 2 bits come out. But if you ask it to encode 2
characters, only 3 bits come out. Not 4, just 3. And this is what it
means; the number of bits output is always a whole number (obviously),
but it's the fractional number of bits, rounded up. (It's a bit like
buying a box of 7400s priced at 21.225p each. Obviously there's no such
thing as 0.225p; if you buy one chip, they change you 22p. But if you
buy 1,000 chips...)
Huffman encoding can't do fractional bits. And there are some
limitations on the combinations of bit-lengths you can get. (E.g., C
should be 4 bits or 5 bits, but we've given it 3 bits.) But there is an
algorithm that lacks these limitations: range coding.
I'm going to demonstrate this in decimal, but the principle in binary is
just the same. We start off with an "active range", which begins with
0.0000 to 0.9999:
   Max = 0.9999
   Min = 0.0000
We then split that range into several subranges, one for each possible
character. The width of that range equals the probability of that
character appearing next:
         0.9999
    F    ||||||
         0.9700
         0.9699
    E    ||||||
         0.2900
         0.2199
    D    ||||||
         0.0900
         0.0899
    C    ||||||
         0.0400
         0.0399
    B    ||||||
         0.0200
         0.0199
    A    ||||||
         0.0000
Suppose the first character to be encoded happens to be a C. Then that
becomes the current range:
   Max = 0.0899
   Min = 0.0400
and we split this new subrange up as before:
         0.089999
    F    ||||||||
         0.085800
         0.085799
    E    ||||||||
         0.054500
         0.054499
    D    ||||||||
         0.044500
         0.044499
    C    ||||||||
         0.042000
         0.041999
    B    ||||||||
         0.041000
         0.040999
    A    ||||||||
         0.040000
This process continues for each and every character. Finally, at the end
of the calculation, we have a really, really tiny range. For example:
   Max = 0.04487515156722040876510168073524657069870453400
   Min = 0.04487515156722040876510168073524657069870453399
We then output one of the two values (it doesn't matter which), together
with some indication of how many characters are supposed to be decoded.
(E.g., if the input was just lots of As, the min value would stay at
zero forever, and we couldn't tell how many As to decode.)
This is great and all, but it looks like we need to calculate with
*ridiculous* precision. If I compress a 2GB file and it becomes a 200MB
file, that's 200MB for *one number*. We have to do all calculations with
200MB of precision?! That doesn't sound fun...
Fortunately, this is not the case. As the range gets smaller and
smaller, soon the leading digits all become the same. Look at the table
above: every single code begins 0.0xxx. So we can output the 0.0 part,
and shift it out of our calculations. The result is that when we get to
here:
   Max = 0.448737
   Min = 0.448611
we can output "0.448" and change the numbers to
   Max = 73799999
   Min = 61100000
We can then continue our calculation as before. So we only need to hold
in memory the handful of digits that are *actually changing*. To the
left are digits we've already output into the compressed file. To the
right, the max is 999 recurring, and the min is 000 recurring.
(There is an issue called "underflow", where the min gets stuck at 9999
and the max gets stuck at 0000 and the digits don't meet before you run
out of precision. You can work around that by "remembering" how many 0s
and 9s there are, and cancelling them out temporarily. When the digits
do align, you just need to remember to reanimate the cancelled digits.
It's fiddly, but not hard.)
Notice that the smaller a range is, the quicker the leading digits start
to match, and the sooner we write digits out to the compressed file. In
other words, narrow ranges take more precision to specify. To summarise,
rare symbols take more digits than common ones - just like with Huffman
codes.
Huffman coding and range coding are both examples of "entropy coding".
In either case, how much compression you get depends on:
   1. How much difference there is between the probabilities of the symbols.
   2. How accurately you can predict the probabilities.
#1 is a property of the file itself; you can't change that. Some files
just compress better than others. #2, however, depends on how you
estimate your symbol probabilities.
The simplest thing to do is to count how many times each character
appears in the whole file, and divide by the total character count to
get a probability for each character. That *works*, but the decoder
doesn't have access to the uncompressed file to compute the statistics,
which means you have to *tell* the decompressor what to do.
Fundamentally, there are two kinds of compression:
* In "static" compression, you scan the entire file, decide how to
compress it, and then do the actual compression.
* In "dynamic" compression, you decide how to compress the next item
based only on the data you've already processed so far.
Static compression has the advantage that you can "see" all the data, so
you can make the best compression decisions. But the decompressor can't
see that data, so you have to "tell" the decompressor what you decided
to do (e.g., tell it what Huffman table you built), or it won't be able
to decompress. "Telling" the decompressor takes up disk space, making
the file larger and partially negating the potentially superior
compression ratio.
Dynamic compression means you have limited information to work with, so
you can't make compression decisions quite as well, resulting in a lower
compression rate. On the other hand, the decompressor can "see" exactly
what the compressor saw, and by running the same algorithm it can come
to the same conclusion. In other words, you don't have to "tell" the
decompressor what you did; it can work it out automatically from the
compressed data itself. So you get lower compression rates, but there's
no extra data tables to send, so there's less file overhead.
In the end, it's swings and roundabouts. But I will say this: some
algorithms work better static, and some work better dynamic.
You can do dynamic Huffman compression. You can start estimating all
characters with equal frequency, and AFTER compressing each character,
update your frequency estimates and rebuild the whole Huffman tree. The
decompressor can do the same, and hence recover the Huffman tree without
needing any tables. However, rebuilding the Huffman tree takes time;
more likely you'll update it every dozen characters or something,
otherwise speed will suffer too much.
But in general, people usually do static compression when they use
Huffman coding. It's quicker to build the Huffman tree once, and then
send it once.
You can do static range coding. You calculate all your probabilities,
write them into the header of the file, and then encode everything.
It'll probably take a bit of space (it's not just bit-counts like
Huffman, it's limited-precision probability values for each character),
but you can do it.
The key advantage of range coding, though, is that it *costs nothing* to
completely change all your probability estimates for every single
character. So range coders are usually dynamic.
Whether Huffman or range coder, static compression of an English text
ASCII file usually gets about 50% compression. That's good, but not
fantastic. I just tried some random text files on my PC, and by zipping
them I got around 80% compression. So how do we do that?
A key thing you can do is to use a higher-order model. U is a fairly
uncommon letter. There aren't too many words with U in them. So the
probability of seeing a U might seem fairly low. But if the previous
letter happens to be Q... surely the probability that the next letter is
a U ought to be *a lot* higher now!
If you calculate a fixed probability for each character, that is a
"1st-order Markov model". If you calculate a different set of
probabilities for each letter depending on what the previous letter was,
that's a "2nd-order Markov model". And it can give substantially
improved compression.
Of course, coming up with probabilities for 256 different byte values is
one thing. Coming up with 256 tables of 256 probabilities, that's 65,536
probabilities we need to compute... If each one takes 1 byte to store,
that's 64KB just to store the probability tables! If you're trying to
compress a 5KB text file, adding 64KB of overhead is going to give you
some serious negative compression! (I.e., the "compressed" file will
actually be *bigger* than the original.)
Suffice it to say, nobody does static 2nd-order Markov. It eats too much
space. But dynamic? Sure. And *that* probably means you're using a range
coder.
But why base your probabilities only on the *last* character? Why not
the last two? Or three? Or then?
In fact, if you do this, you start hitting the problem that if you've
never seen a certain sequence of characters before, how do you estimate
probabilities following it?
The usual solution is "partial predictive matching" (PPM). The
probability tables [of which there are a hell of a lot!] are sparse. If
you haven't seen a certain 10-character sequence before, you ignore the
oldest character and look up the corresponding 9-character sequence. If
you haven't seen that, you try 8-character, until you finally get a
match. In this way, for each character you can make the best possible
probability estimate. And better probability estimates = better
compression. (And because this is all dynamic, there's no need to store
huge tables in the compressed file. The decompressor will run the same
algorithm and compute the same estimates.)
Compressors such as PAQ use range coding and PPM (amount other things)
to top the compression ratio ratings. (At the expense of speed and
memory usage, it must be said.)
Actually, PAQ is interesting, since it uses context mixing. That is,
half a dozen different algorithms (not just PPM) estimate the
probabilities for the next character. It then uses a left-learning
artificial neural network (!!) to combine these probability estimates to
get a final estimate.
It does all of this PER BIT!
The result is an excruciatingly slow compressor that gives astonishing
compression ratios.
Subject: Re: A monologue involving binary log
Date: 14 Feb 2015 16:10:21
Message: <54dfb9bd$1@news.povray.org>
Aha! The real Andrew is back.
An interesting read - have you ever thought of taking up teaching?
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Date: 14 Feb 2015 18:29:42
Message: <54dfda66$1@news.povray.org>
Will the real Mathematical Orchid please stand up...
Erm... I've thought about it. But I've yet to see a class of people who
actually *want* to learn stuff.
* Nobody at school wanted to learn a damn thing.
* The people at college were only there so they didn't have to get an
actual job. None of them seemed that bothered if they get their
qualification, never mind what grades they get.
* At university, everybody wanted the best grades, but nobody cared
about the actual subject. They just wanted a nice piece of paper.
* I went on a Microsoft technology course. Everybody wanted the bit of
paper, nobody really cared about the actual course content. Most of them
were only there because their employer paid for it.
In short, I haven't come across a lesson where people are there because
they actually *want* to learn something. Most of them are just seem to
want the bit of paper that makes employers think they're awesome.
The fun part is when the *teacher* doesn't particularly want to teach.
I'm sure I've told you about Mr Apathy, who I met at uni. I prefaced a
lecture on binary by saying "of course you don't *really* need to know
any of this. It's pointless really. I mean, the Java virtual machine
handles all of this for you. But it's in the exam, so I'm supposed to
teach it to you". Damn, I'm sold! Sign me up!!
Mind you, this was the same guy who spent ten minutes disinterestedly
explaining how "pointless" the rebuilding of Colossus is. "I mean, it
won't be the *actual* machine that they used. It's just a replica. And
they don't make half the parts any more, so they'll have to change the
parts and redesign the circuitry to compensate, and at the end of all
that, it'll be so different from the original that there's just no point."
Not my favourite lecturer. :-P
Date: 14 Feb 2015 19:50:25
Message: <54dfed51$1@news.povray.org>
<snip>
I was thinking about you going for a doctorate; you are as capable as
the Kat and I. All you need is an original project.
<snip>
Yeah. Come the revolution, he'll be the first against the wall. [I am
not joking]
John
Protect the Earth
Date: 15 Feb 2015 03:34:53
Message: <54e05a2d$1@news.povray.org>
You are too pessimistic I believe (or the world has changed too much).
Except for the last point (the Microsoft course) with which I agree, at
all other levels I have been with people who genuinely wanted to /know/
and to /learn/. Not all of them of course but a substantial part, yes.
And I agree with John: you would be an excellent teacher.
Date: 15 Feb 2015 05:33:29
Message: <54e075f9$1@news.povray.org>
My mum wanted me to do a PhD. I have no idea why. As best as I can tell
from reading Stack Overflow, if you have a PhD then you are basically
over-qualified for 99% of all employment opportunities ever, and you'll
never be able to work outside academia ever again.
> not joking]
Dude, if you hate your job so much, WHY ARE YOU STILL DOING IT?!?
Still, at least he could speak English. Many of my lecturers couldn't
(or at least not very well). Seriously, if your JOB is to teach people
who only speak English, not being able to speak English is surely an
instant disqualification. No?!?
Date: 15 Feb 2015 05:44:16
Message: <54e07880@news.povray.org>
I haven't met them. Everybody I've met regards having technical
knowledge as only something "nerds" and "losers" have - including the
people I work with, who are all professional computer programmers. They
all know how to write C#, yet they seem to think that understanding
relational algebra or knowing how floating-point arithmetic works is
only for lamers.
Again, I don't know. I'm good at writing long monologues that nobody
will ever read; interacting with a room full of live humans is quite
different. It requires a different skill set.
My Dad tells me [so I don't know how true this is] that Bach was a
virtuoso organ player, but a HORRIBLE teacher. He just couldn't
understand why nobody else could play like him...
Date: 15 Feb 2015 06:05:46
Message: <54e07d8a$1@news.povray.org>
Maybe Mother knows best. :-)
Going from your mathematical ramblings. I think that you would be
eminently suitable to do a PhD at a good university. Not one of those
who were ennobled, just to take the overflow from schools. When
politicians decided it would keep them off the dole for another three years.
>> not joking]
Yeah! Go on and tell him. I'm all ears. :-P
And while you are at it. Which revolution or counter revolution, would
that be? ;-)
It would be at a a school. Universities are different, they employ
lecturers for what they know and publish. Their world and ours touch but
occasionally.
Regards
Date: 15 Feb 2015 06:16:10
Message: <54e07ffa$1@news.povray.org>
> only for lamers.
That is because you have academic interests. Most professional computer
programmers, I work with. Do it because it is a job. Not for love.
Unless you can use your competitive dancing skills to be in front of an
audience.
And his throw away scales became the Brandenburg Concertos.
Regards
Date: 15 Feb 2015 06:16:55
Message: <54e08027$1@news.povray.org>
I doubt it. :-P
As I say, it seems to just preclude you ever getting employed, ever again.
> years.
Fun fact: They stopped giving out university grants just a year or two
before I started university. I AM STILL PAYING FOR MY TUITION! More than
a decade later... *sigh*
> occasionally.
Favourite anecdote: So we're in a Network Systems lecture, and the
lecturer writes the Shannon channel coding theorem on the board. [That's
the same Shannon who invented Shannon codes, so we're drifting back
on-topic now...] The formula states that the maximum data-rate over a
noisy channel is given by
   C = B log2 (1 + S/N)
And everybody is like "ZOMG! WTF is a logarithm?!" And the lecturer is
like "oh, really? I'm sorry, I just assumed that THIRD-YEAR
UNDERGRADUATES would already know that".
So it turns out that only two people in the room actually know what a
logarithm is. Obviously one of them is me. And the other one... is the
crazy beer-drinking rugby thug from Manchester. o_O And I'm serious; he
actually knows what he's talking about. First and last time I ever heard
him say something sensible...
Date: 15 Feb 2015 06:24:17
Message: <54e081e1$1@news.povray.org>
>> only for lamers.
This.
Everybody I met at university was like "OMG, this is SOOO boring! Just
give me the piece of paper so I can start earning thousands of pounds
per hour as a top London computing consultant."
Everybody seemed to think that computing is *excruciatingly* boring, but
also that there's billions of pounds in it. Like, if you have any
computer skills at all, you're going to be a millionaire. (Still, it
*was* right around the height of the dot-com bubble I suppose...)
> audience.
Uh, I do competitive dancing; what makes you think I have *skills*? :-P
Unless you mean I give the lecture while dancing the quickstep. ^_-
Hey, I think I have the score for that somewhere...
Date: 15 Feb 2015 07:14:23
Message: <54e08d9f$1@news.povray.org>
> I doubt it. :-P
For Arts graduates maybe. I have met so many PhD doctors at work. I only
look up to Misters. ;-)
Having a higher degree in maths type subjects would open doors to
better/more interesting jobs.
>> years.
Scandalous!
> Favourite anecdote:
It only saddens me it does not surprise me.
Regards
Date: 15 Feb 2015 07:26:17
Message: <54e09069$1@news.povray.org>
>>> only for lamers.
> This.
I am not a computer professional so that world is indeed foreign to me,
but what you and Stephen are saying truly appals me... But then I may be
from an alien planet: I have never been /really/ interested in money... :-)
That last is indeed true but can be learned with practice (like
dancing). Writing skills, which you have already, is more difficult to
learn. I must say that I enjoy your long monologues btw.
>> audience.
Seriously, in a good lecture before an audience, some kind of
choreography (even body language) is of paramount importance. Whatever
the subject.
Great stuff indeed.
Date: 15 Feb 2015 07:30:21
Message: <54e0915d$1@news.povray.org>
Having said that... The company I work for employs a grant total of 9
people. The company has sold less than 100 units in its entire 10-year
history. I cannot *imagine* that anybody here is particularly well-paid.
And yet, if you look through source control, you will find the
occasional commit performed at 2AM. Nobody gets *paid* to do that.
People occasionally choose to do that out of... well, something that
isn't money anyway. (And no, it's not deadline pressure; we don't have
deadlines. Or pressure of any kind, really.)
Still, while my colleagues genuinely want to make the software the best
it can be (and not just because they get paid to do that), I am
apparently the only person in the building who thinks that computer
science is a worthwhile endeavour. Everybody else just hits Google until
the problem goes away, without bothering to understand why. I find that
a little disturbing.
But not as disturbing as me getting paid to do C++ when I know nothing
about it! o_O
Date: 15 Feb 2015 07:31:04
Message: <54e09188@news.povray.org>
>> I doubt it. :-P
>> again.
I second that.
>>> years.
> Scandalous!
>> Favourite anecdote:
Sadly, I second that too.
Date: 15 Feb 2015 07:43:35
Message: <54e09477$1@news.povray.org>
On 15/02/2015 11:24, Orchid Win7 v1 wrote:
> This.
"They" forgot to mention that the high pay would drop when the demand
was filled by themselves.
>> audience.
Performance skills before an audience. I meant.
I did a job a couple of years ago where I had to deliver training
courses. I had never done anything like it before. When I got my sea
legs. It was SHOWTIME!!!
I really enjoyed it. But somehow I don't see you being comfortable in
front of an audience, yet.
Tap would be more appropriate. IMO. ;-)
The story goes that he gave them to his patron to play with his amateur
orchestra.
Regards
Date: 15 Feb 2015 07:53:29
Message: <54e096c9$1@news.povray.org>
 From a Dutchman! We will keep that quiet. ;-)
During my time in Aberdeen I met a lot of geologists who only studded it
to get a job in the Oil Industry.
> the subject.
Good body awareness is important. You don't want to knock your coffee
over your notes.
Regards
Date: 15 Feb 2015 07:53:30
Message: <54e096ca$1@news.povray.org>
There is something deeply worrying about... OK, so let's try this. Come
on this journey with me.
You see a job advert for an English / French translator. The advert says
there will be a test during the interview. You don't know a single word
of French, but you think to yourself "bah, nobody will notice. I'll just
Google search of the words when I need to. It'll be fine."
WHAT. THE. HELL.
I'm sorry, IN WHICH UNIVERSE IS NOBODY GOING TO NOTICE?! What the HELL
are you smoking?!!
Nobody thinks this will work. Nobody ever tries this. Because nobody is
that stupid. But replace being able to write French with being able to
write C#, and suddenly everybody thinks that somehow "nobody will
notice". Wuh?!
I went to one interview where there was an SQL test. The job advert says
that SQL knowledge is required. The job advert says there will be a
test. There is no time limit on the test. The test is OPEN BOOK; you
have access to the Microsoft SQL Server help file [but not the
Internet]. You have a computer in front of you to test your answers with.
According to the interviewer, people turned up with "20 years' SQL
experience" and failed to answer a single question.
That was the moment when I realised something: People LIE on their CV.
I mean, sure, I know people *exaggerate* their capabilities. But this
revelation left me stunned. Anybody who claims to have "20 years' SQL
experience" and yet cannot figure out how to select all customers from
the customer table is LYING. This is not an exaggeration for dramatic
effect, this is outright FRAUD. Strictly speaking, this is ILLEGAL.
I used to be worried about overstating my abilities on my CV, lest I
give people the impression that I have capabilities that I don't. Now I
only worry about how to tell people that I'm not just MAKING CRAP UP!
Some people's CVs clearly have no connection to reality. How do you
prove to people trying to hire you that you're not just talking nonsense?
Also: FizzBuzz exists. Because, from what I've seen, 99% of all the
people you interview have NO IDEA how to write software. I don't mean
they're not very good at it, I mean... Imagine hiring a lorry driver,
and finding out he doesn't know which pedal is the brake and which one
is the accelerator. This person CLEARLY has never sat behind the
controls of a vehicle - no matter WHAT his CV claims.
We started doing phone screenings rather than waste our time with
hopeless people. We find a website where you can watch the other person
type, in real-time, as they type it. Almost everybody who reaches this
stage doesn't get to have a face-to-face interview. A few people got
creative though:
* While talking to one guy, we could *clearly* hear somebody else
sitting next to him telling him what to type. Er, REJECT!
* Another guy, we asked him to write some code. We can hear typey typey
typey. Er, can you type into the window please? Typey, typey, typey,
BAM! Suddenly a huge block of text appears all at once. In other
words... you just Googled the answer and copy-pasted it, didn't you? REJECT!
Seriously, how the **** do people think we're not gonna notice this
stuff? Let us suppose, for argument's sake, that you somehow trick us
into interviewing you... Do you REALLY THINK it won't instantly become
EXTREMELY OBVIOUS that you're bluffing? How do you actually see this
playing out? Are you mental?!
I wonder... Does anybody have this much trouble hiring a carpenter?
> learn.
I guess that just leaves us with the problem of nobody wanting to learn
then. ;-)
Oh, well, I'm glad somebody does. Sometimes it does feel like I'm
talking to myself...
> the subject.
I'm sure if I give a lecture while doing the Charleston to some
authentic music, everybody will remember me. No idea if they'll remember
a damned thing I said, but... ^_^
Date: 15 Feb 2015 07:57:16
Message: <54e097ac@news.povray.org>
>> again.
According to the Academia Stack Exchange portal, it seems if you have a
PhD, everybody immediately assumes you're going to be hellishly
expensive to hire and summarily drops you from consideration.
Unless you want to work in the finance industry, which only exists in
London.
> Scandalous!
Hey, I spent 10 years earning minimum wage, so...
>> Favourite anecdote:
In fairness, while he only said a few sentences, it was immediately
clear to me that he knew what he was talking about. As in, logarithms
aren't just something he heard about once, he actually *understood*
them. (As opposed to merely rote-memorising some facts about them.)
Date: 15 Feb 2015 08:12:26
Message: <54e09b3a$1@news.povray.org>
Am 14.02.2015 um 16:33 schrieb Orchid Win7 v1:
I wouldn't normally respond to this posting of yours, but just to let
you know how much interest there is in reading such posts, I hereby
declare that I did read it with interest. Huffman coding wasn't new to
me, so I skipped over that part, and I'm also somewhat familiar with
Markov chains including PPM, but range encoding is an interesting
concept I hadn't heard of before. Also, I do start to notice that human
memory seems to be made up of DRAM cells, so a refresh cycle now and
then is most welcome ;)
Date: 15 Feb 2015 08:17:20
Message: <54e09c60$1@news.povray.org>
>> goes...
Hey, cool!
Yeah, it's interesting. I'm slightly fuzzy on exactly what the
difference between "arithmetic coding" and "range coding" is. Wikipedia
seems to think there's a difference, but I don't know what it is.
(Then again, I only just figured out the difference between LZ78 and LZW...)
More like, it's a neural network which "learns" by adjusting the
connection weights between cells - but *that* is the subject for another
wall of text, I imagine... ;-)
Date: 15 Feb 2015 08:18:12
Message: <54e09c94$1@news.povray.org>
That does not fit in with my experience. True often PhD's end up at the
top of the pile but lots of them do lesser jobs. They just have a PhD.
It does not rule them out from doing jobs they are "over qualified" for.
> London.
I am beginning to get the feeling that you are a member of a sect that
vilifies London as a pit of depravity.
>> Scandalous!
Even more scandalous.
>>> Favourite anecdote:
Regards
Date: 15 Feb 2015 09:45:00
Message: <web.54e0b0399f13a20899c37d0d0@news.povray.org>
> only for lamers.
they are useful idiots
Bach (and many other bright composers from the highly specialized and complex
instrumental music of that era) was much like as autistic as we are.  Hence, his
many bouts of fury against his patrons, arrests, etc.  He simply didn't know how
to harmoniously deal with other human beings as he did with an organ.  He did
teach his children pretty well though.  His oldest 2 sons were as capable as
himself as performer and just had a different composing style because times had
changed...
Date: 15 Feb 2015 09:56:58
Message: <op.xt3s46flufxv4h@xena.home>
On Sun, 15 Feb 2015 13:17:05 +0200, Orchid Win7 v1 <voi### [at] devnull> wrote:
I don't get it. We learned about logarithms in high school.
-Nekar Xenos-
Date: 15 Feb 2015 10:09:36
Message: <54e0b6b0$1@news.povray.org>
>> money... :-)
[snip]
As I said, I am truly appalled about what you tell. It is unbelievable
but I suppose I am naive... ;-)
No, but I am starting to worry.
>> learn.
> then. ;-)
Sad, sad, sad. I believe learning is one of those rare incentives that
make life worthwhile.
Oh dear, some would say /money/ of course ;-)
>> the subject.
Right. You can overdo it. Watching lecturers is a great school for do's
and dont's. I have seen hilarious examples of dont's... ;-)
Date: 15 Feb 2015 10:22:10
Message: <54e0b9a2@news.povray.org>
>> money... :-)
I am afraid I am already ostracised ;-)
Oh yes, there are those. To tell the truth, back in the sixties in NL at
least, those where mostly concentrated in another university than the
one I was in (Amsterdam) which was considered more 'leftist' and less
oil-minded :-)
>> the subject.
> over your notes.
Oh dear, no! Nor drop all your overhead sheets on the ground as I saw
happen :-)
Date: 15 Feb 2015 10:24:58
Message: <54e0ba4a$1@news.povray.org>
Not in fundamentalist America. There you can hire one to support every
belief that you want. ;-)
Regards
Date: 15 Feb 2015 10:38:55
Message: <54e0bd8f$1@news.povray.org>
> oil-minded :-)
Some universities can become specialised in certain fields, supplying a
market.
>> over your notes.
> happen :-)
You are giving your age away, now. ;-)
Those sheets seemed to have no friction between them at all.
Or so someone told me. :-)
Regards
Date: 15 Feb 2015 15:34:49
Message: <54e102e9$1@news.povray.org>
In which country?
For that matter, we learned about fractions in school. But I've yet to
meet anyone from my own generation who has the slightest clue how
fractions work... [I suppose that's another one of those "nobody cares;
the computer does it for you" type things.]
Date: 15 Feb 2015 15:36:21
Message: <54e10345$1@news.povray.org>
>> over your notes.
> happen :-)
You must never do a tango with an Eskimo. No no no, oh dear no!
[I still don't actually know why...]
Date: 15 Feb 2015 15:43:57
Message: <54e1050d$1@news.povray.org>
Why does that sound like a band name...
> changed...
Harmoniously.
I SEE WHAT YOU DID THERE! ;-)
Date: 15 Feb 2015 15:44:53
Message: <54e10545$1@news.povray.org>
> [snip]
I sincerely hope this is unique to the computing field.
I *think* it's because what we programmers produce is so intangible.
Like, if you hire somebody to build an office block, and they bash a few
bits of wood into the ground in the shape of a rectangle, you tell them
they're fired, and then you sue them into oblivion. [Which I gather is
some kind of MMO?] But if you commission somebody to build a payroll
system, you can't really tell that it's just an MS Access skin - unless
you're enough of a computer expert that you don't need to hire an expert
in the first place!
That, I *think*, is maybe what the problem is. Although I do wonder how
nobody gets electrocuted because the "electrician" they hired doesn't
actually know how electricity works...
It does make you wonder, doesn't it?
>> then. ;-)
I find all this stuff fascinating - but then again, I'm weird, so...
But still, there *was* a time when the great mathematicians, physicists
and engineers of the day were lionised as visionary idols... Now we have
Pop Idol. *sigh*
"The Charleston lectures" would make a hell of an Internet meme though...
...you know, I mean if I could actually *speak* while doing the
Charleston, instead of gasping for air...
Date: 15 Feb 2015 16:16:57
Message: <54e10cc9$1@news.povray.org>
>>> over your notes.
>> happen :-)
If you do, you'll get the breeze up
And you'll end up with a freeze up
[And you would not want her to break it off.]
Regards
Date: 15 Feb 2015 18:15:01
Message: <web.54e127bd9f13a20899c37d0d0@news.povray.org>
are you sure people in the UK still speak english?
Date: 16 Feb 2015 03:03:54
Message: <54e1a46a$1@news.povray.org>
>>>> over your notes.
>>> happen :-)
ROTFL
Date: 16 Feb 2015 03:09:46
Message: <54e1a5ca$1@news.povray.org>
>> happen :-)
I know. Overhead sheets are only found in museums nowadays.
No friction? well yes but often to the contrary. The damn things often
stuck together like hell with static electricity! But as you could put
them in individual holders they became a manageable pile.
Date: 16 Feb 2015 03:18:47
Message: <54e1a7e7$1@news.povray.org>
It does, and with the trash sent over from China it is often a nightmare
come true. Nowadays, I often control /where/ devices are put together,
even the labels with a traditional reputation. :-(
[snip]
LOL That would be a great show indeed!
Date: 16 Feb 2015 03:20:42
Message: <54e1a85a$1@news.povray.org>
Oh, I don't know. When I was at uni, every time assignments were due,
you could *guarantee* that some moron will have put overhead sheets
through the library laser printer - the WRONG overhead sheets. The ones
that melt in the fuser unit. :-S
Date: 16 Feb 2015 03:23:52
Message: <54e1a918$1@news.povray.org>
> London.
I work for a manufacturing company about 50 miles away from London, and
we have quite a few PhDs working in our R&D team (physics and chemistry)
and in more senior positions elesewhere in the company. We certainly
wouldn't reject your application just for having a PhD.
My previous employer was much more R&D oriented and at least 50% of the
staff had PhDs. Didn't you have some at your previous job too? Maybe the
problem you highlight is unique to people with computer science PhDs?
Date: 16 Feb 2015 03:40:53
Message: <54e1ad15$1@news.povray.org>
I have to agree with Andy here, my experience of school (compulsory up
to age 16) and sixth form college (optional up to age 18) is that most
people didn't want to learn. Obviously there were some who did, but the
majority you felt were there because someone else had told them to be
there but they didn't want to be. It was a place to meet people and hang
out, having to go to lessons and do homework was an inconvenience.
It was only when I got to University that it was suddenly full of people
who actually wanted to be there and wanted to learn. But I think there
are likely only a few Universities like that with that atmosphere,
speaking to friends elsewhere it sounded like other Universities were
just like school and college where people would spend more effort trying
to avoid doing any work that actually learning anything.
Date: 16 Feb 2015 03:52:35
Message: <54e1afd3$1@news.povray.org>
>>> happen :-)
Now we are getting back to the binary nature of life and Sods Law.
Regards
Date: 16 Feb 2015 03:54:10
Message: <54e1b032@news.povray.org>
> ROTFL
The old ones are the best ones. :-)
Regards
Date: 16 Feb 2015 04:26:37
Message: <54e1b7cd@news.povray.org>
>>>> happen :-)
Beware of the /binary/ nature though. I must have told this story many
times, maybe even here...
Settings: Split, in then still existing Yugoslavia; a lecture hall
during a conference with a huge stage in front of the audience.
Characters: (1) Somebody high up in party hierarchy going to give a
presentation on mineral resources; (2) his secretary.
Scene 1: The session's president introduces the next presentation
(applause); the presenter comes up on stage with his secretary;
presenter takes place behind the lectern; the secretary sits down
besides the overhead projector, facing us, a little nervously, the
audience; a few murmurs in the audience.
Scene 2: Presentation begins; English a bit difficult to follow;
presenter signals to secretary to put up the first overhead, which she
does; for about a couple of minutes all goes well.
Scene 3: Presenter asks for next overhead; image comes on screen;
/wrong/ overhead; presenter starts to become irritated; secretary starts
to become (more) nervous; overheads are successively put up and put down
again without success; nervousness increases; presenter tries to go on
from overhead then visible; secretary start to put up another overhead
before being told to do so; presenter turns red; secretary panics and
drops all the sheets on the stage;
Meanwhile, the audience: slow grins appearing on faces; bodies settling
down more comfortably in chairs; hands fold on bellies.
Scene 4: panic extending on stage; presenter, secretary, and session
president reassemble the sheets but no logical order can be found any
more; presentation ends in chaos. (applause)
Date: 16 Feb 2015 04:34:33
Message: <54e1b9a9$1@news.povray.org>
> WHAT. THE. HELL.
> are you smoking?!!
> notice". Wuh?!
I assure you the sames happens for French and everything else. My gf
works for a company that sells stuff mostly outside the UK, so they are
always recruiting people for customer service that are fluent in German,
French, Italian etc. People *do* apply for jobs that blatantly state
"German speaker" that cannot speak more than the 3 words of German that
everyone knows. Their reasoning is often along the lines of "well I can
speak a bit of French and I thought you wouldn't notice, and if you did
you would anyway see how uber cool I was and see I could learn German in
a few weeks and hire me anyway". Err no, go away!
The same happened to me in Engineering in my last job too. A guy applied
quoting 20 years experience in analogue electronic circuit design and
test. We got a bit concerned when he couldn't even say what a simple
2-component RC circuit was meant to do, let alone how to calculate any
response. After a bit of drilling down we got to the question of "have
you ever actually used an oscilloscope?". His answer was No. I mean come on!
> creative though:
> REJECT!
LOL
The scary thing is these people will probably be able to get a job
somewhere and somehow blag there way along. If they're lucky they may
even get to interview people at some point :-)
Have you ever seen shows like "cowboy builders" or "rogue traders"...
Date: 16 Feb 2015 04:40:33
Message: <54e1bb11@news.povray.org>
> about it! o_O
Because of your desire to learn though, I'm pretty sure you're going to
be better at C++ than them already, and if not you will be soon. And
undoubtedly you've got a wider area of expertise than someone who has
just spent their entire career coding C++ and nothign else.
Date: 16 Feb 2015 05:07:40
Message: <54e1c16c$1@news.povray.org>
Not to my knowledge. I have seen the same, a few times with slide
projectors. When the carousel has been loaded in the wrong order and the
ensuing panic ends up with the slides on the floor.
Ah! Well. It was the best that we had at the time.
Regards
Date: 16 Feb 2015 05:12:12
Message: <54e1c27c$1@news.povray.org>
Oi! That's me your talking about. Have a care.
Regards
Date: 16 Feb 2015 07:06:43
Message: <54e1dd53$1@news.povray.org>
My school experience was quite the opposite; there was even a fair
competition between pupils to get the highest scores. Good teachers were
venerated; the bad treated with contempt. It was hard work too, from
8:00 till 18:00 on average, six days a week, with only the thursday
afternoon free. I don't know. Time (50s and 60s) and place (Paris) may
play a role here...
Date: 16 Feb 2015 07:09:54
Message: <54e1de12@news.povray.org>
A man is entitled to his laugh, ain't he?
Date: 16 Feb 2015 07:37:36
Message: <54e1e490$1@news.povray.org>
Guilty!
Been there, done that. All I need is the t-shirt.
John
Protect the Earth
