POV-Ray : Newsgroups : povray.off-topic : Memory-mapped I/O Server Time
15 Jun 2026 17:21:46 EDT (-0400)
  Memory-mapped I/O (Message 11 to 16 of 16)
Subject: Re: Memory-mapped I/O
Date: 5 Feb 2015 13:49:52
Message: <54d3bb50$1@news.povray.org>
>> Or just, you know, the Pi emulator, which doesn't cost money. ;-)
> Because a Raspberry Pi is soooooo extraordinarily expensive, sure... :P
Presumably if you hunt far enough you can find one for available at the
> Drawback of the Pi emulator is that it doesn't come with all those neat
> I/O pins ;)
Pffft. What would I even do with those? It's not like any high-level
language lets you interface with them anyway. And you'd have to hook up
a bunch of relays to use them to drive anything that takes more than
0.3mW of power. :-P
Date: 5 Feb 2015 17:27:28
Message: <54d3ee50$1@news.povray.org>
Am 05.02.2015 um 19:49 schrieb Orchid Win7 v1:
Ah, yes... if you insist on buying yet another keyboard, mouse, USB hub,
micro-USB power adaptor, WiFi dongle and HDMI cable with that...
If you already do have those components flying around your house
somewhere, you /might/ however try ordering a bare Pi mainboard for 18
to 40 GBP, depending on the model. At Maplin. No further hunting required.
>> I/O pins ;)
Is Haskell a high-level enough language for your taste? :P
http://hackage.haskell.org/package/HPi
Not to mention C, C++, C#, Ruby, Perl, Python, Scratch, Java, Pascal and
BASIC of course; you can even control them from the command shell:
http://elinux.org/RPi_Low-level_peripherals#GPIO_Code_examples
> 0.3mW of power. :-P
Well, yeah, that's the usual way to drive anything even remotely
power-hungry with any digital controller.
As for the 0.3mW, if you go for the Model A you can go up to 0.5mW.
Date: 17 Feb 2015 18:15:42
Message: <54e3cb9e$1@news.povray.org>
Am 02.02.2015 um 19:16 schrieb Orchid Win7 v1:
> Is it even still *possible* to map the graphics card's
> framebuffer into the CPU's address space?
On Linux (and surely other unix clones): no problem at all!
Just open /dev/fb0, making some ioctl()'s on it to get the size and the
pixel type of the frame buffer and you can call mmap() to the file
descriptor to map the whole frame buffer memory into your address space.
> Similarly, if I want to ask the harddisk to do something, do I need to
> explicitly construct ATAPI commands, or does the chipset do that for me?
just mmap() your /dev/sd* to your address space and feel free to
read/write into it.
> I'm not trying to actually *write* a device driver, I'm just curious as
> to how this stuff works these days.
It works good. And a lot of software use these interfaces today (X
server, database systems etc.)
Lars R.
Date: 17 Feb 2015 18:25:30
Message: <54e3cdea$1@news.povray.org>
> read/write into it.
Yeah, that's not quite it.
When you ask the kernel "hey, mmap() this file for me, will ya?", what's
actually happening is that when you try to access those memory pages,
your application gets suspended while the kernel goes and issues the
necessary disk I/O commands to read a copy of that file into memory.
Your application then gets resumed, making it *look like* the logical
file is indeed mapped into the address space.
This isn't the same thing at all. This is clever software making the
process *look* simple, which isn't at all the same as the process
actually *being* simple.
Case in point: you can mmap() files residing on an NFS server on another
continent. Clearly the CPU and chipset know *nothing* about TCP sliding
windows and go-back-N acknowledgements. That's why you have a huge,
complex operating system controlling the CPU. ;-)
What I'm asking is, can the hardware itself map the framebuffer (or
whatever) into the address space, not whether some program can simulate
this behaviour.
Subject: Yes, it can. :-D
Date: 18 Feb 2015 07:15:16
Message: <54e48254$1@news.povray.org>
Even good-old ISA cards were able to do so (ok only in the first 16 MB
of physical address space *G*). With PCI they became able to tell the
chipset about the size of their "card memory" and the memory controller
in the chipset will respect these in its internal memory mapping (and
tell it to the CPU (and the operating system) so the CPU will disable
its interlal L1 caches etc. for these address ranges etc.)
Just look at /proc/iomem to see how heterogenious the physical address
space is on modern computers.
The mmap() just maps portions of this physical address space into your
logical/program/user address space.
Lars R.
Subject: Re: Yes, it can. :-D
Date: 18 Feb 2015 13:41:02
Message: <54e4dcbe$1@news.povray.org>
Now *that* sounds interesting...
