Hi guys.
I just read the entire manpage for ptrace(2).
WAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAH!! O_O
OK, first of all, that's the longest manpage I've ever seen! (A typical
manpage seems to be about three paragraphs.) Second... OK, I was
wondering what strace(1) actually does, and how hard it would be to
reimplement it myself. As it turns out... yeah, pretty damned hard,
actually. O_O
On Thu, 27 Nov 2014 21:42:11 +0000, Orchid Win7 v1 wrote:
> Subject: Man oh man
I see what you did there. ;)
It's a good thing you weren't reading the man page for mplayer, postconf,
or smb.conf - those are all over 10,000 lines long on my system.
Comparatively speaking, ptrace(2) is relatively short (only about 1,000
lines). ;)
Jim
"I learned long ago, never to wrestle with a pig. You get dirty, and
besides, the pig likes it." - George Bernard Shaw
>> Subject: Man oh man
:-D
> lines). ;)
Sure. But look at the number of ifs, buts, elses and gotchas... That's a
LOT of information to absorb.
On the one hand, it appears that essentially what strace does is fairly
simple; execute the right ptrace() call, and the tracee will go to sleep
every time it gets a signal or does a system call. You call ptrace()
again to query what happened, and then resume the tracee.
On the other hand... all those ifs and buts... CLEARLY this stuff is
really, really fiddly to get right! (And don't even get me started on
decoding the system calls.)
Having read the manpage, it appears that parsing the text output of
strace is probably going to be easier than reimplementing it to output
XML or something.
(I did take a look at the source code for strace... Every single source
file contains hundreds of printf() calls. I was hoping for more
abstraction than that. Clearly there's no way of altering what its
output looks like without months of work.)
On Thu, 27 Nov 2014 22:31:05 +0000, Orchid Win7 v1 wrote:
> Clearly there's no way of altering what its output looks like without
> months of work.)
Perhaps easier to pipe the output through an awk script (or similar) to
get what you're looking for.
Jim
>> Subject: Man oh man
> lines). ;)
> Jim
Try: man gcc
16,153 lines on the machine I'm working on.
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
On 28/11/14 11:56, Doctor John wrote:
> Try: man gcc
> John
Whilst I'm at it:
john@aphrodite:~> man mplayer | wc -l
8754
john@aphrodite:~> man smb.conf | wc -l
7948
john@aphrodite:~> man postconf | wc -l
307
john@aphrodite:~> man gcc | wc -l
16153
john@aphrodite:~> man ptrace | wc -l
962
John
Protect the Earth
Doctor John <j.g### [at] gmail com> wrote:
> Whilst I'm at it:
> 8754
> 7948
> 307
> 16153
> 962
bash has all of its info on one single man page, 5450 lines long in
my system.
zsh has enormously more info, which is why it's subdivided into a
dozen man pages by category. There is, however, a 'zshall' man page
where everything is concatenated, and it's 27499 lines long on my
system.
> my system.
> system.
Just checked that on mine
john@aphrodite:~> man zshall | wc -l
24375
... same order of immensity ;-)
John
Protect the Earth
>> months of work.)
I spent 2 days writing an elaborate parser for it. But clearly, not
elaborate enough! Because I'm *still* getting parse failures... Hey,
it's not like it has a documented grammar or anything. Every time you
think you've covered everything, another special case pops up. :-S
I have, however, managed to boil 27 MB of strace logs down into a 2MB
HTML file that's colour-coded in such a way that you can just about see
what's going on. (It seems several processes received SIGINT, but for no
defined reason THEY CONTINUE RUNNING! >_< I have no idea why.)
On Sat, 29 Nov 2014 21:57:25 +0000, Orchid Win7 v1 wrote:
> (It seems several processes received SIGINT, but for no defined reason
Because signals can be captured, ignored, or their behaviours can be
changed. SIGINT is just a signal to a program, and writing an
interceptor isn't that difficult. :)
Jim
>> THEY CONTINUE RUNNING!>_< I have no idea why.)
But WHY are dd, cat, tee and md5sum ignoring this signal? They don't
usually, and I can see the signal is definitely being delivered.
The Bash script is explicitly trapping SIGINT, but I can also see it
receiving multiple SIGPIPE signals... Why doesn't that kill it?
Also, why does Bash keep cloning() itself? Is it to create subshells or
something? (Obviously clone() followed by execve() is how it executes
commands. But clone() on its own? Why?)
Sounds like a bug, or worse.
Jim
