POV-Ray : Newsgroups : povray.off-topic : A question for big brains. Server Time
15 Jun 2026 21:54:31 EDT (-0400)
  A question for big brains. (Message 21 to 27 of 27)
Subject: Re: A question for big brains.
Date: 19 Nov 2014 04:01:29
Message: <546c5c69$1@news.povray.org>
> As Scott pointed out vapour
> pressure might have something to do with it as well.
The vapour pressure of butane will determine the pressure of the refill
can. When you fill a totally empty can with butane the pressure will
build until it reaches the vapour pressure (about 2 bar absolute
pressure at room temperature for butane), at this point any more butane
you push in will condense out as liquid and the pressure will not
increase any further.
The reverse happens if you were to slowly release the butane gas, this
causes the pressure to momentarily drop in the can which allows some of
the liquid to evaporate to restore the vapour pressure.
What you are doing in the refill situation though is to use the pressure
in the can to force the liquid up into an "empty" lighter (due to the
dip tube inside the refill can).
When you connect the lighter and refill can together the pressure in the
can will force the liquid up the dip tube and into the lighter.
Initially the pressure in the lighter is below the vapour pressure so
the liquid will evaporate rapidly as it enters the lighter (the same as
if you just sprayed it into the atmosphere). This will continue until
the pressure is equalised and both the lighter and the refill can are at
the vapour pressure of butane.
Based on that simple explanation there should never be any liquid
flowing into the lighter. If the pressure in the lighter is below the
vapour pressure then any liquid coming in will evaporate, and once it's
at the vapour pressure then no more liquid will flow in due to the
pressures being equal. But what I think happens is that when the first
bit of liquid evaporates inside the lighter it reduces the temperature
(eg it drops to 1.5 bar after a 10 degress C drop in temperature). What
this means is that once the pressure in the lighter has reached 1.5 bar,
the liquid entering it will no longer evaporate and will remain liquid.
At this point liquid will continue to flow until the pressures (and
temperatures?) have equalised.
Date: 19 Nov 2014 05:33:12
Message: <546c71e8@news.povray.org>
So far so good.
Oops! Are you using the photograph that Bald Eagle posted to work this
out? That is a disposable non-refillable lighter. Refillable lighters
have a different construction. The refill valve is on the bottom of the
lighter in the section opposite to the dip tube and the internal wall is
the other way round. So that the gap is at the bottom near the inlet valve.
I am not sure that I follow your logic. Are you saying that initially
only gas flows then liquid?
Regards
Date: 19 Nov 2014 07:52:27
Message: <546c928b$1@news.povray.org>
> So far so good.
So far so good... but we can add a bit of complexity:
The pressure to liquify the butane is the partial pressure, not the
global pressure, whereas the flow to equilibrate pressure is about
global pressure.
In the empty lighter, global pressure is 1.0 bar (btw, it's now illegal,
should be in Pascal), and no partial pressure of butane.
In a filled lighter, all the pressure is from the butane, 2 bar when
unused. (but lower when lighted, as butane is going out)
In a refilling lighter, if any pressure is not from butane it is cooled
by the expensing butane and that system is not equilibrated, so it is a
bit difficult to know the global pressure, but it should be less than
1+butane.
In the refilling can, we have butane in liquid form pushed through a
pipe by: saturated butane gas and we can add some compressed nitrogen as
initial filling, for a global pressure that will be greater than the one
in the refilling lighter.
Just because nobody complains does not mean all parachutes are perfect.
Date: 19 Nov 2014 08:49:26
Message: <546c9fe6$1@news.povray.org>
I meant the dip tube inside the refill can, not the lighter.
I am saying that initially the liquid butane evaporates as it enters the
empty lighter, only after a certain pressure has built up in the lighter
will the liquid from the refill can remain a liquid as it enters the
lighter.
> global pressure.
Correct, I had assumed only butane in the system in my working...
...wouldn't an "empty" lighter actually be full of butane gas at very
slightly above 1 bar (often you can hear the gas escaping but it's not
enough to make a flame)? Or should we assume some amount of air in there?
BTW I call it "total pressure" not "global pressure", so still legal
here :-)
Date: 19 Nov 2014 09:56:13
Message: <546caf8d$1@news.povray.org>
> here :-)
While I model it.
I prefer my pressure in "psi gauge".
As in 3-15 PSI ~ zero to full scale.
Regards
Date: 20 Nov 2014 06:43:59
Message: <546dd3ff$1@news.povray.org>
I'm sorry, but Mr Stacey doesn't know the current location of Brains.
Are you SURE this is a job for International Rescue?
Date: 20 Nov 2014 07:21:13
Message: <546ddcb9$1@news.povray.org>
LOL
I said Big Brains not Wee Brains. ;-)
Maybe not now you mention it. It is a job without any strings. :-)
Regards
