POV-Ray : Newsgroups : povray.off-topic : Experimental Server Time
16 Oct 2026 20:18:28 EDT (-0400)
  Experimental (Message 1 to 13 of 13)
Subject: Experimental
Date: 4 Mar 2014 13:36:11
Message: <53161d1b$1@news.povray.org>
In the category of "things I suck at"... I can't sing very well either.
Notwithstanding, and in complete defiance of the terms of my lease,
today I've been recording my singing with Cubase. Or at least, humming
just loud enough for a microphone placed mere millimetres from my lips
to detect that something is happening.
You will be unsurprised to hear that this arrangement does not result in
high sound quality. In order to make anything audible I had to turn the
gain way, way up. So there's quite a lot of background hiss. Also, you
can hear every single breath I take.
Added to that, I have quite a lot voice, and because I'm trying to sing
quietly I tended to sing quite low notes. The result was quite "grainy"
in texture.
What *is* quite surprising - to me, at least - is that the whole appears
to be greater than the sum of its parts. As in, you can listen to each
of the parts I sung, and hear how the pitch waivers around hopelessly.
And yet, when you play them all simultaneously, something strange
happens: it sounds more in-tune than it actually is. It almost sounds
like I used the computer to auto-tune it or something. (I don't possess
that program.)
I eventually figured out how to increase the playback volume in Cubase
to the point where my vocals were actually audible. (The microphone is
returning a signal at roughly -16 dB, which is easily quieter than the
backing tracks.) Lots of hiss, but you can now hear me.
A curious problem is that every single line I sang seems to vary in
volume, seemingly at random. Some of them are louder at the end, some of
them are louder in the middle. In short, no matter which way you adjust
the volume, you can't seem to get them all the same volume.
This is where I break out Reaktor and load up a compander. This device,
I am told, exists to counteract this precise problem. It seems to work
reasonably well. With a 4-bank compander, the mic hiss is gone, and the
volume appears to waiver a lot less.
Sadly, a compander does nothing to fix my lack of timing or my wandering
pitch.
Again: I'm really quite surprised that do-wop harmonies sound anywhere
near this good with a fool like me singing them.
Subject: Re: Experimental
Date: 4 Mar 2014 15:04:02
Message: <op.xb7rcx0fufxv4h@xena>
On Tue, 04 Mar 2014 20:36:14 +0200, Orchid Win7 v1 <voi### [at] devnull> wrote:
> in texture.
> that program.)
> pitch.
You will probably get a more stable pitch if you sing louder. But if it
doesn't work you may have a problem with your neighbors ;>
-Nekar Xenos-
Date: 4 Mar 2014 17:19:50
Message: <53165186$1@news.povray.org>
Agreed.
> But if it
Also agreed. :-S
Since I had the day off work, I was home when (I presume) few other
people are. At least, nobody came to kick down the door, anyway...
Date: 4 Mar 2014 18:20:47
Message: <53165fcf$1@news.povray.org>
On 04/03/2014 10:19 PM, Orchid Win7 v1 wrote:
>> But if it
> Also agreed. :-S
WTF!
If you are worried about a clause in your lease that says that you
cannot make any noise. And if it specifically mentions singing. You have
no worries. It is (IMO) unenforceable.
As long as you don't make continuous loud noise after 10 pm (earlier if
they have babies). You should not have a problem.
Regards
I solemnly promise to kick the next angle, I see.
Date: 5 Mar 2014 00:33:48
Message: <5316b73c$1@news.povray.org>
Le 05/03/2014 00:20, Stephen nous fit lire :
> they have babies).
If they have babies, they are the one making more noise.
Unless you use some micro+amplifier, or are a true opera singer (or an
extinct singer from the era before micro came on the scene), your voice
is to be weaker than the one of a baby or a little child.
Strong volume of voice requires long daily practice, something that
adults rarely have, whereas the kids have nothing else to do.
Date: 5 Mar 2014 03:28:00
Message: <5316e010$1@news.povray.org>
This.
This is true. However, it is also true that the walls here are extremely
thin. I can often hear the people next door talking, and can mostly make
out the words they're saying, for example.
Date: 5 Mar 2014 03:29:14
Message: <5316e05a$1@news.povray.org>
On 04/03/2014 11:20 PM, Stephen wrote:
> WTF!
The lease says I may not play a musical instrument, sing, or operate a
TV or radio. These are things it specifically mentions.
On the other hand, I'm pretty sure the guy on the left has a TV, so...
Date: 5 Mar 2014 07:35:00
Message: <web.5317198bb1f8f68e7f6b03a40@news.povray.org>
> > they have babies).
Exactly! The clause is unenforceable.
Personal experience? :-)
Date: 5 Mar 2014 07:50:01
Message: <web.53171d2ab1f8f68e7f6b03a40@news.povray.org>
> > WTF!
Nor should you believe in the tooth fairy?
Seriously how could anyone expect a court to uphold a lease that forbids singing
or turning on a radio. Even Jails have TVs in the cells. AFAIK.
I am sure, from what I have read. That you will be safe if you ignore those
rules. If you behave reasonably what could happen? It is your house after all.
Date: 5 Mar 2014 08:54:50
Message: <53172caa$1@news.povray.org>
>> WTF!
So I guess getting a pipe organ in the living room is out of the
question.  Bummer.
> sing,
Define singing.  "Your honour, I wasn't singing... I was merely
practicing my Italian."  Is rapping allowed?  Humming?  Tuvan thorat
singing?
> or operate a TV or radio.
Does it mention MP3 player?  Streaming audio from the PC?  I smell a
loophole...
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 5 Mar 2014 09:19:05
Message: <53173259$1@news.povray.org>
>>> WTF!
> question.  Bummer.
>> sing,
> singing?
> loophole...
Forget the loopholes. As Stephen has said, the clause is almost
certainly unenforceable. Which raises the question, why didn't Andrew's
solicitors read the lease and point out the clause, if only to let the
other party's solicitors know that it should have been struck out.
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Date: 4 May 2014 16:20:54
Message: <5366a126$1@news.povray.org>
Well, my mum is out of the county for a few days, so I spent all of
today sitting in my old bedroom, singing my lungs out.
You wouldn't believe it could take 5 hours to record 5 minutes of
vocals, would you? (Or... perhaps you would... IDK.)
Now I'm trying to mix them nicely. Trouble is, if I apply an aggressive
compander, it makes all the harmonies the same loudness, but every time
I stop singing, it amplifies the hell out of the background hiss! I
wonder if there's some way I can cut out all the noise...
Date: 27 May 2014 15:56:19
Message: <5384ede3$1@news.povray.org>
Am 04.05.2014 22:20, schrieb Orchid Win7 v1:
There is. It is called a "noise gate" or simply "gate".
