There's a philosophical conundrum from antiquity (which name now
escapes me): Suppose you have a seaship. During its years of service,
every time a part breaks it's replaced by a new part. After sufficiently
time has passed, every single part of the original ship has been replaced
with a new part. So the question is: Is it still the same ship?
This question pertains to us really well. It's estimated that every single
molecule and atom in our bodies is recycled every about 7 years. In
other words, there's very few, if any, of the same atoms in your body
than there were 7 years ago.
So the question is: Given that probably you don't have even a single
atom in your body that you had 7 years ago, are you still the same person?
You could argue that even though your body may have been completely
recycled, your memories and thoughts have been retained, and these are
what makes you you.
But consider this: You have two computers that are otherwise completely
identical, except that there's data in the HD of one of the computers,
while the other's HD is empty. The data is now copied to that other
computer, making it identical. Is that other computer now the same one
as the original? Clearly not. It's just a copy of the original. It's not
physically the same.
Considering that, does that mean that I'm just a copy of myself of 7 years
ago? (And not even a perfect copy, because my thoughts and memories have
changed.) My whole body has physically changed so that not even a single
part is the same, and my memories have simply been "transferred" along.
So am I still the same person, or am I simply an (incomplete) copy of that
person?
we're all of it. We see these 3D slices of ourselves in the mirror and think
that's about it. But really, we're more like a ball of yarn that has been
spread all around space from birth to death.
obviously, that's from a materialistic space-time perspective. As for being one
thing or another philosophically, what is being besides a state? To be or not
to be. If you could erase the memory of a psychopath and give him instead happy
memory ones, would he be someone else? Or would the same deplorable behavior
keep creeping in?
The ship is not made of the same materials just as we are not, yet it's sailed
be the same crew, has its masts and sails where they're supposed to be and bears
the same name. That's all that matters.
The two computers are the same for all purposes, but separate by time and space
carry out different processes accessing different memory addresses. Just like
twins.
So you're saying that even biology uses FP-style copy-on-write mutation? :-D
> person?
Maybe an answer is that it's possible (or even normal?) to have a unique
"item" represented by different actual matter at different points in
time, but not at different points in space.
Also replacement parts (cells, molecules, ship parts) need some finite
amount of time to become generally "accepted" (in a philosophical sense,
not a scientific sense) as part of the original item. If you replace
every part of your PC within 1 hour, then you've got a different PC and
the "old" one is in a heap next to it. If you replace one part every
year then in the end you might still say you've got the "same" PC. It's
the constituent parts being together that make the item.
> person?
What do you feel like, yourself?
Regards
> person?
You are v1.01 RC1 of the previous version. All that happens is that a
few bugs get ironed out (and a few new ones introduced).
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
> > person?
I don't feel the same. I have learned new things, I have forgotten things,
I have changed my opinion on some things, and I look different.
Corollary: You have a rock group called YES. Over the years, band
members come and go, up to the point where none of the original band
members are still in the group. Is that band still YES?
If the four original band members decide to record an album together
again, can they also call themselves YES?
/* flabreque */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
/* @ */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
/* gmail.com */}camera{orthographic location<6,1.25,-6>look_at a }
>>> person?
Okay. But does that not mean that you are only three dimensional?
Are /you/ not the sum of all your selves?
Like and with /time/ *you* move forward, extending yourself, growing,
becoming what you will be.
<That reads like absolute tripe, some new age balderdash.
If you are not the you of your past. Can you beheld responsible for what
you did in the past?>
Regards
The answer is in the title. ;-)
> that
> person?
No you are not the same person, but you are still you. If that makes any
sense :)
This reminds me of the solutions I've seen for a "Beam me up, Scotty"
machine: iirc it would involve replicating a person atom by atom,
destroying the original in the process. Which sounds a bit too much like
murder and cloning all-in-one :S
-Nekar Xenos-
Am 20.01.2014 13:58, schrieb Doctor John:
>> person?
Heh, I do like that analogy ;-)
Am 20.01.2014 20:14, schrieb Orchid Win7 v1:
"YES: We can!" :-P
Am 20.01.2014 20:43, schrieb Nekar Xenos:
For possible side effects of this process, see the time machine
(originally conceived as a teleportation device) in the movie "Timeline".
Until some hacker figured out how to disable the "destroy after copying"
part of it (which no doubt the government has forced to be kept on with
some bad DRM system). That would open a whole can of worms :-)
