POV-Ray : Newsgroups : povray.off-topic : Where is Gail when you need her? Server Time
16 Oct 2026 21:32:10 EDT (-0400)
  Where is Gail when you need her? (Message 1 to 23 of 23)
Subject: Where is Gail when you need her?
Date: 5 Jan 2014 15:25:40
Message: <52c9bfc4@news.povray.org>
I am, as I have said several times to Stephen, not a database person.
However, I seem to have got lumbered with a (non-paying) job; to whit,
the design of a database to document 13th and 14th century bank
transactions using their surviving ledgers.
Originally, I thought a flat file would be sufficient but the more I
think about it the more I'm convinced I was wrong. I attach a very small
png that shows my current thinking.
To explain: each banking family (Gallerani, Borromei etc) has several
branches (London, Paris, Bruges ...). Each branch has several ledgers
(numbered by series) and every ledger contains several hundred items
containing details of transactions. Transaction1 is the initial approach
by the Actor to the branch and Transaction2 is the future outcome
(either payment to the same or a different actor and at the same or a
different bank/branch).
Ignoring the complexities of writing the code to view, manipulate and
play with the database, does this look sane to you? (BTW Solid lines
indicate Identifying Relationships and broken lines in Non-Identifying
Relationships)
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Download 'banks.png' (65 KB)
Preview of image 'banks.png'
Subject: Re: Where is Gail when you need her?
Date: 5 Jan 2014 16:03:43
Message: <52c9c8af$1@news.povray.org>
And he said "What's a database?" :-)
Regards
Date: 5 Jan 2014 16:18:10
Message: <52c9cc12$1@news.povray.org>
My database design lecturer would be complaining about ACTORS being
plural while everything else is singular. Myself, I'm a little bit
puzzled about the purpose of TRANSACTION1 and TRANSACTION2...
Date: 5 Jan 2014 16:18:24
Message: <52c9cc20$1@news.povray.org>
Ah, but when I said 'Would you like a whisky?' you queried the
distillery, the year, the barrels it was aged in, the name of the
blender's younger daughter etc etc. :-D
BTW What's SAP ;-)
John
Protect the Earth
Date: 5 Jan 2014 16:27:33
Message: <52c9ce45@news.povray.org>
TRANSACTION1 is the initial payment to the bank. TRANSACTION2 is a later
payment by a bank* to an actor; it therefore requires a different date
(usually but not always specified) as well as a way of specifying where
it will be enacted.
*It appears that  there was some degree of trust between banking
families so that the Gallerani (say) would pay out on behalf of the
Borromei.
Incidentally, the IsChurch boolean is purely there to make it easier to
isolate Vatican transactions.
John
Protect the Earth
Date: 5 Jan 2014 16:38:38
Message: <52c9d0de$1@news.povray.org>
Additional, TRANSACTION2 may not exist in every case which may imply
that the bank keeps the money. 'Plus ca change, plus ca la meme chose'
John
Protect the Earth
Date: 5 Jan 2014 17:02:01
Message: <52c9d659$1@news.povray.org>
Le 05/01/2014 22:27, Doctor John nous fit lire :
> it will be enacted.
So, what about calling T1 as Credit/Credence, and T2 as Debit/Restitution.
Date: 5 Jan 2014 17:10:03
Message: <52c9d83b@news.povray.org>
>> it will be enacted.
But that's just nitpicking. The planned views do not have to be named
after the tables.
I still ask though, regardless of names, does it look sane?
BTW Andrew, your lecturer was a pathetic pedant
John
Protect the Earth
Date: 5 Jan 2014 17:15:12
Message: <52c9d970$1@news.povray.org>
>> it will be enacted.
The other problem is it may be to a different actor at a different bank.
John
Protect the Earth
Date: 5 Jan 2014 18:32:37
Message: <52c9eb95$1@news.povray.org>
No. It was you that did that. I drink Grouse. </Hint>
  the name of the
Might have been, might have been.
> BTW What's SAP ;-)
A distant memory. They say it rises in the spring. ;-)
Regards
Date: 5 Jan 2014 23:43:59
Message: <52ca348f$1@news.povray.org>
... which will save me a heap of cash the next time we meet :-)
Incidentally, I rescued a book from our local library as it was closing
down (they'd built a new one just down the road) called 'When The Lights
Went Out - Britain In The 70s'. A bit lefty for my taste but interesting
just the same. Could I give it to you?
>> BTW What's SAP ;-)
So, when are you next in London and free for a night of debauchery? (One
proviso: Wednesdays are out. The Kat has lectures, seminars etc then, so
yours truly has to look after the Feegle)
John (wondering why he's still awake at this hour -see timestamp)
Protect the Earth
Date: 6 Jan 2014 03:35:26
Message: <52ca6ace$1@news.povray.org>
> Relationships)
> John
I stand by the objection that tables named from numbered "object" have
the wrong name. (old rule: if you have to number the tables's name, you
are doing it wrong)
Transaction1 might be BlackInk, Transaction2 RedInk, if you use the ink
colour of that time.
It seems that each item has at most one transaction#1 and at most one
transaction#2.
Can an item have no transaction at all ? (what would an item do in a
ledger in such case ?): if no, transaction1 should be incorporated into
item.
keying the relation between actors and transaction1 on a varchar(60)
seems to open the pandora box of data integrity. An explicit (numerical)
key of actor (automatically generated by the database) could be safer.
Transaction2 has city & bank, which I suppose are "on behalf of" or the
opposite ?
Now I wonder about the item: what would be the objects in the following
situation:
Bank A, City 1, Ledger L, an item K is provided by Actor X (btw, date ?)
Actor X goes to City 2, Bank B pays on behalf of Bank A the local
equivalent of item K.
Does Bank B, city 2, Ledger D get an entry ?(item & transaction2 ?)
Does item K of Ledger L be extended with transaction2 ?
Just because nobody complains does not mean all parachutes are perfect.
Date: 6 Jan 2014 07:55:44
Message: <52caa7d0$1@news.povray.org>
> are doing it wrong)
> transaction#2.
Correct
> item.
Yes. Remember, we are dealing with medieval banking before the days of
double-entry book-keeping - a 15th century innovation. Occasionally
there are Items that state the local branch's cash-in-hand and others
that record communications received from 'Head Office'
Thanks. I missed that. It has been corrected.
> opposite ?
> situation:
Date is assumed to be the same as the date that the ledger entry was
made (LEDGER.ItemDate)
No. It is hoped that some of the ledgers (variously located in archives
in Paris, Ghent, Siena and Rome) will record the fulfilment of the
transaction, in which case it will have its own record. The way I was
thinking was that Transaction2 purely records a future liability (which
may or may not be fulfilled).
A typical item reads:
n.16  25th May 1305
Item we received £25 13s 4d sterling from Messer Ricardo Anibaldi of
Rome, canon of the Lateran, for 38.5 marks (38 marchi meco di sterlini),
which were paid on his behalf by maestro Ruberto di Patriarcha which we
have written (rabbatuti) in the Ledger at f. 92 into his account. For
that sum we made him a letter of payment to ours at the [Vatican] Court
who are to pay to him 197 golden florins, and 3 grossi tornouis, at the
rate 5.125 florins per mark on 15th August. The letter of payment is
being sent to the Court for Artigino of Rieti, familiaris of Berardo del
Poggio
Until the ledger recording the payment by the Vatican branch is
unearthed we cannot be sure that Transaction2 of Item 16 was ever fulfilled.
John
Protect the Earth
Date: 6 Jan 2014 14:27:26
Message: <52cb039e$1@news.povray.org>
>> it will be enacted.
I was thinking more about collapsing them both into a single table...
If you're just trying to do double-entry accounting, there's no especial
reason why you need one table for one half of the entry, and another
table for the other half. (Then again, I do not have much of an
understanding of the problem domain behind this design, so...)
Date: 6 Jan 2014 14:55:01
Message: <web.52cb0934bdd2b0804bff9a870@news.povray.org>
Yes, of course. A paper book no less, how quaint. :-)
> >> BTW What's SAP ;-)
I am not sure, I wouldn't mind a night of debauchery, if. I can remember what
that is. :O
Old age, mate. :-P
> Protect the Earth
Date: 7 Jan 2014 08:13:12
Message: <52cbfd68$1@news.povray.org>
I must remember to put it in a prominent position so I don't leave it
behind.
> that is. :O
It'll come back to you. It's like riding a bike.
> Old age, mate. :-P
You and me both ;-)
John
Protect the Earth
Date: 7 Jan 2014 08:28:41
Message: <52cc0109$1@news.povray.org>
>>> it will be enacted.
>> Debit/Restitution.
They've now been renamed to TRANSACTION and LIABILITY
The last thing the team want to do is double-entry book-keeping :-)
The main aims of the project are:
1. How did the banks make their money? They couldn't charge interest
(the Church forbade the practice) and exchange rates seem to have been
the same between two currencies whichever direction the transaction
went. So were they using deposited money to trade in goods such as wool
and spices?
2. The Church had just started to use the banks to transfer money to and
from the Vatican. Did this sudden influx of substantial amounts of cash
give rise to an increase in trading all over Europe and thus provoke the
mini-Renaissance that only came to an end with the onset of the Black Death?
John
Protect the Earth
Date: 7 Jan 2014 11:43:44
Message: <52cc2ec0$1@news.povray.org>
Additional. I have just received a phone call informing me that the team
has unearthed 200 pages of of Vatican documents itemising payments into
and out of the Curial treasure chests. They cover the period in question
but are written by churchmen rather than financiers so they don't always
include some of the essential (to a financier) information. I'm now
waiting for a few pages of translated items (I don't speak or read
Medieval Latin) and then it's back to the drawing board. :-(
John
Protect the Earth
Date: 7 Jan 2014 14:41:00
Message: <52cc584c@news.povray.org>
Am 07.01.2014 17:43, schrieb Doctor John:
All this reminds me of a project my father has been working on for the
last few years: Transcribing records from a monastery about their
properties, tenants, cottagers and what-have-you-not (plenty of who
moved out of or into which piece of land, what they had to pay for
moving in, what they had to pay to stay, what their compensation was
when moving out, whom they married, whom they gave birth to - all sorts
of stuff like that).
Fortunately for him, he didn't aim for a database; transcribing the old
handwritings and adding some annotations of his own was all he was
aiming for.
He is now arranging for the results to be published as a book.
Date: 8 Jan 2014 15:12:24
Message: <52cdb128$1@news.povray.org>
> aiming for.
The Kat (Principal Investigator in this project) has expressed interest
in getting a copy of your father's book, let me know when he publishes.
The email you see for me is valid but put p.o-t in the subject line
John
Date: 8 Jan 2014 16:06:05
Message: <52cdbdbd$1@news.povray.org>
Am 08.01.2014 21:12, schrieb Doctor John:
>> aiming for.
Would she still be interested if she learned that the book will be about
a German monastery... and written in German?
Date: 8 Jan 2014 16:13:53
Message: <52cdbf91$1@news.povray.org>
Absolutely. She speaks (nearly) fluent German and and anything about
Medieval Church institutions is her field.
John
Protect the Earth
Date: 8 Jan 2014 17:31:29
Message: <52cdd1c1$1@news.povray.org>
Am 08.01.2014 22:13, schrieb Doctor John:
I'm not sure whether the records my father transcribed include stuff
dating back to medieval times; at least his original interest was in the
records from late 17th to very early 19th century. The monastery in
question is the (then Cistercian) convent in Vinnenberg, Westphalia.
I'll keep you updated nonetheless.
