POV-Ray : Newsgroups : povray.off-topic : Hardware Server Time
16 Oct 2026 21:32:51 EDT (-0400)
  Hardware (Message 1 to 42 of 42)
Subject: Hardware
Date: 22 Dec 2013 11:35:10
Message: <52b714be$1@news.povray.org>
So the good news is, my PC works again now.
The bad news is I have no 3D acceleration and I'm limited to VGA video
modes.
Time to buy a new graphics card... :-(
Subject: Re: Hardware
Date: 22 Dec 2013 14:59:35
Message: <52b744a7$1@news.povray.org>
I wondered where you'd got to.
> modes.
I've just run one of my machines in VGA mode; OMG, what a difference.
Hope it's all fixed before Xmas.
John
Date: 22 Dec 2013 15:13:45
Message: <52b747f9$1@news.povray.org>
I especially enjoy how my monitor correctly displays the image, but
utterly fails to compensate for the radically different aspect ratio...
Are you kidding me? Chances of stuff getting delivered before Christmas
are almost zero now, I would think...
Date: 22 Dec 2013 16:20:45
Message: <52b757ad@news.povray.org>
Depends on when you ordered it, and how much you paid for shipping.  If
you buy something with next day guaranteed delivery, it should get there
- and if it doesn't, then someone owes you money. :)
Jim
Date: 23 Dec 2013 06:33:17
Message: <52b81f7d$1@news.povray.org>
> modes.
You should be able to at least run the new Windows 8 UI then :-)
Date: 23 Dec 2013 08:24:06
Message: <52b83976$1@news.povray.org>
>> modes.
GAAAH! IT BURNS!!
Date: 23 Dec 2013 13:16:08
Message: <52b87de8$1@news.povray.org>
...of course, the thing about buying a graphics card is, how much do you
want to spend?
For £80 I can get a GeForce GTX 650, which roughly the same 800 GFLOPS
that my defective GeForce GTX 260 produces. So, about £80 to get roughly
the same thing as I had before. But with slightly more RAM.
What exactly is the significance of the amount of on-board RAM? I
realise it's used for holding texture data, but what happens if the data
doesn't all fit? Does the program just point-blank refuse to work, or
does it merely cause a reduction in performance?
For slightly less than 2x the price, I can get somewhat more than 2x the
performance. The GeForce GTX 660 develops 1,800 GFLOPS, but costs £150.
So, 87% more expensive, 125% faster.
Then again, the GeForce GTX 760 is only a bit more expensive - £190. And
yet, it produces 2,200 GFLOPS (and has twice the RAM).
Decisions, decisions...
Date: 23 Dec 2013 15:41:55
Message: <52b8a013@news.povray.org>
It's not the size that matters. It's how you use it.
Date: 24 Dec 2013 03:18:40
Message: <52b94360@news.povray.org>
Do you want GFLOPS or FPS? You can use those performance charts like
GPUmark and also look at framerates in common games if that's what
you're going to be using the GPU for.
FWIW when I built my machine earlier this year I chose the GTX 650 (I
think about £90 at the time) and an AMD FX8350. Seems to run everything
ok, but I'm not one for playing lots of cutting-edge games, FarCry3 is
probably the latest one I have that is heavy on graphics - that runs
fine at max detail. I'm waiting for GTA5 to come out for the PC in
March, hopefully that will handle it ok.
Date: 24 Dec 2013 03:54:49
Message: <52b94bd9$1@news.povray.org>
If the data doesn't all fit, the GPU will simply overwrite the RAM that
hasn't been used for the longest and carry on (a bit like a circular
buffer). This is not an ideal situation if you are trying to use 600MB
of textures per frame on a card with 512MB RAM, because obviously every
single frame you'll be transferring texture data between system RAM and
video RAM (which is relatively slow).
Needless to say games are written to avoid this situation, they will
select which size textures or compression to use based on the amount of
video RAM you have. There is probably a minimum amount that below which
the game will refuse to run, but the GPU won't actually error out if you
try and load too many textures.
Or there are more complex algorithms, like keeping some "core" low res
textures for everything in VRAM all the time, then only swapping in the
high res versions for things near you in the world. If you can only move
around the world at a certain speed then you can plan to pre-load the
high res textures seamlessly.
Date: 24 Dec 2013 04:28:16
Message: <52b953b0$1@news.povray.org>
I would presume that render frame-rate and compute power are strongly
correlated. Then again, I guess I don't know that much about the render
pipeline, so...
My GTX 260 was able to handle Crysis, Crysis 2, FarCry 3 and just about
every other game I tried on very high detail settings. (Although I think
FarCry 3 became noticeably laggy when I turned everything up to maximum
- it was only slight though.)
If a GTX 260 can handle it, presumably a newer generation card with
multiple times the compute power will eat it up.
Ultimately, I'm probably going to wait for my next bank statement before
I decide. It's only a few days away, after all...
Date: 24 Dec 2013 04:41:26
Message: <52b956c6$1@news.povray.org>
Oooh, is that 1995 I hear calling again :-)
Date: 24 Dec 2013 05:03:55
Message: <52b95c0b$1@news.povray.org>
As well as that, I'm going to try to get CUDA to work again. I've got a
few bits of software which *claim* to use your GPU to do compute-heavy
work much faster. If only any of them actually *worked*...
Date: 24 Dec 2013 05:05:15
Message: <52b95c5b$1@news.povray.org>
What, you think I should be using Internet banking? I prefer it if bad
people *can't* steal all my money merely by guessing a password...
Date: 24 Dec 2013 05:27:36
Message: <52b96198$1@news.povray.org>
Oh it's 2005 calling now...
Date: 24 Dec 2013 10:26:55
Message: <52b9a7bf@news.povray.org>
What bank uses fixed passwords (rather than a sheet of single-use codes)
and thinks that it's safe?
Date: 24 Dec 2013 11:17:44
Message: <52b9b3a8$1@news.povray.org>
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Date: 25 Dec 2013 00:48:41
Message: <52ba71b9$1@news.povray.org>
Am 24.12.2013 16:26, schrieb Warp:
What bank uses a sheet of single-use codes and thinks that it's safe?
Over here in Germany we're past that age. Codes dynamically generated
from transaction details it is for us.
Date: 25 Dec 2013 07:39:35
Message: <52bad206@news.povray.org>
Well, much safer than a fixed password.
You can't do anything with the sheet alone if you don't have the user's ID.
Granted, it's not impossible to acquire both, but if you don't store your
ID anywhere and instead have it memorized, it becomes difficult. (Basically
they would need to install some spyware in the computer you are using in
order to get the ID, and then physically steal the passcode sheet. Not
impossible, but not likely to happen.)
How does that even work?
Date: 25 Dec 2013 14:02:29
Message: <52bb2bc5$1@news.povray.org>
Am 25.12.2013 13:39, schrieb Warp:
Just two words:
(1) Phising.
(2) Man-in-the-middle attack.
There are two variants in use:
(A) Each time you submit a transaction via browser, you get a
transaction-specific authorization code via SMS to your mobile phone,
including some essentials of the transaction (like the amount of money
transferred, and the target bank account) to make sure that you and the
bank are talking about the same deal.
(B) You get a code generator from your bank. Typically this would be a
combination of a bank card with a built-in chip, plus a card reader with
a built-in display to make sure that the code is generated from the
transaction details you desire.
(As certified card readers are expensive, have never really taken off,
and would probably be difficult to integrate into web-based online
banking, the common solution is an inexpensive battery-powered
stand-alone device using optical transmission from web interface to card
reader.)
Date: 25 Dec 2013 19:23:47
Message: <52bb7713@news.povray.org>
> Just two words:
> (1) Phising.
Does not help to get the physical code sheet.
I suppose SMS verification would add an additional layer of security.
How exactly is this different from a sheet of one-use codes?
(Except, you know, the obvious: That method requires you to connect
a special device and software to your computer and configure it
appropriately.)
Date: 26 Dec 2013 02:37:36
Message: <52bbdcc0$1@news.povray.org>
Am 26.12.2013 01:23, schrieb Warp:
>> Just two words:
>> (1) Phising.
Does not /need/ to get the physical code sheet. If someone can get in
between your screen and the online banking portal, they can tamper with
the transaction details to transfer an entirely different amount of
money to an entirely different target bank account.
Note that HTTPS only protects the network transmissions, not your
browser output.
> appropriately.)
As the code is now generated from the transaction details, tampering
with them is much less attractive for an attacker: If they hide any
changes from the code generator, the code won't be valid for the
modified transaction. If they pass the changes to the code generator, a
cautious user will notice that the details have been tampered with
(provided of course that the code generator has an inbuilt display on
which it shows the transaction details before spitting out the code, and
it provides no attack vector between that display and the actual
cryptographic engine).
As for "the obvious", that's actually a no-issue: The stand-alone device
I mentioned does not need any software on your PC, and the only
"configuration" required is a one-time calibration for your display
size; from then on, use is as simple as holding the device's light
sensor array against a flickering animation displayed in your browser.
Date: 27 Dec 2013 03:23:52
Message: <52bd3918$1@news.povray.org>
Le 24/12/2013 11:03, Orchid Win7 v1 nous fit lire :
The only cuda I ever saw in use is in boinc projects.
Date: 27 Dec 2013 08:07:21
Message: <52bd7b89$1@news.povray.org>
lol
Date: 27 Dec 2013 08:20:01
Message: <52bd7e81$1@news.povray.org>
said by someone with a small graphics card? lol could /not/ resist that!!!
Date: 27 Dec 2013 10:27:28
Message: <52bd9c60$1@news.povray.org>
Are there no computer parts stores in the UK?
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 27 Dec 2013 10:33:52
Message: <52bd9de0$1@news.povray.org>
> want to spend?
I guess it depends on the game.  some games will refuse to work at max
resolution, or with full textures and effects if they feel the HW won't
support it), others will plod along until something goes horribly (or
hilariously) wrong.  I remember playing a shoot-em up game where
sometimes, tanks or jeeps would show up as bright pink because the
texture wouldn't fit in ram.  (ex: in a field, tank is properly
rendered, because grass texture takes almost no room.  In a city, the
building and rubble textures already fill up the card's ram, so when the
panzers roll in, OOPS, they're pink!)
Date: 27 Dec 2013 10:47:15
Message: <52bda103$1@news.povray.org>
>> user's ID.
>> (Basically
> Just two words:
> (1) Phising.
So I now need to have a separate cell-phone contract just to be allowed
to pay my bills online?
I have a company-issued cell phone, and my employer allows me to make a
limited number of personal phone call per month, e.g. to let my family
know I'll be late for dinner, etc..., but I don't think they'd like it
If I started letting my bank send me confirmation requests to it.
Also, we lead a very boring life, so there not enough people outside of
work who need to reach us to justify having a personal cell phone on top
of our land line.
Date: 27 Dec 2013 10:47:52
Message: <52bda128$1@news.povray.org>
lol
Date: 27 Dec 2013 12:16:49
Message: <52bdb601@news.povray.org>
Why so obsessed with Nvidia? B uy the latest ATI graphics cards, great
performance, maybe a little better than Nvidia and less expensive.
Date: 27 Dec 2013 12:30:22
Message: <52bdb92e$1@news.povray.org>
Le 27/12/2013 18:16, Saul Luizaga nous fit lire :
with Linux, the ATI cards suck. At least that was my experience with
them, so I went Nvidia. (with multiscreen on linux, Ati was a PITA)
The nvidia driver taints the kernel, but at least they works.
The problem with nvidia is the numbering of cards: the even/odd hundred
might have the same chip (one for EOM, one for retails), and the two
last digits might be related to the frequency or/and the number of
units. The best card is not always the highest number.
Of course, if you only want 2D, any card with enough memory and the
right connector is fine.
The main issue with any top card is the power supply and the noise level
at full power. Best reading many reviews before choosing.
Date: 27 Dec 2013 12:33:45
Message: <52bdb9f9$1@news.povray.org>
Am 27.12.2013 16:47, schrieb Francois Labreque:
No, you can choose the other variant instead. Banks usually offer both.
Date: 27 Dec 2013 13:39:07
Message: <52bdc94b$1@news.povray.org>
Oh I didn't know that, too bad, on Windows some modded drivers are
further optimized for speed, besides the optimization ATI does, you can
find really nice performance, even on old cards. Well you have to use
what works best, yes looking reviews is always good as a reference.
Date: 27 Dec 2013 15:08:26
Message: <52bdde3a@news.povray.org>
At least on Linux, nVidia cards can be used for things like GPU rendering
in Blender.  The ATI cards don't work for that AFAIK.
The radeon drivers are better now, though Catalyst still seems to have
problems here and there.
Jim
Date: 27 Dec 2013 15:45:50
Message: <52bde6fd@news.povray.org>
From what I have gathered, right now the GTX 770 is the card that ought
to give you most bang for your buck. It seems to be right in the sweet
spot from a performance/price point of view. It seems to be the most
efficient of the medium-priced cards (at about 300 euros), the next
more efficient GTX card making a very significant jump in price (over
500 euros).
Given that performance charts put it at about exactly twice as efficient
as my own current card (GTX 560), and this one still performs extremely
well even with newest games, the GTX 770 should last for a relatively
long time before it becomes too slow.
If 300 euros is way too much, I haven't investigated what would be the
best performance/price card on the cheaper side (100 euros and under),
so I really can't tell. Personally, I wouldn't consider the 300 euros
a bad investment for the GTX 770. (Actually I would even buy it myself
if the GTX 560 didn't seem to fare so well even with newest games.)
Date: 27 Dec 2013 15:46:16
Message: <52bde718$1@news.povray.org>
Does ATI support CUDA yet?
Date: 27 Dec 2013 15:50:59
Message: <52bde833$1@news.povray.org>
Mmm. My preferred supplier lists it at £250 - pricey, but not
outrageous. (In fact, roughly what I paid for the card I'm trying to
replace.)
Again, I guess I'm going to wait for my next bank statement before I
make a decision. Also, my sister said something about maybe giving me
some money for Christmas, so...
Date: 27 Dec 2013 17:28:15
Message: <52bdfeff@news.povray.org>
Le 27/12/2013 21:46, Orchid Win7 v1 nous fit lire :
does not seem so.
Cuda is made by nvidia, Ati had a response with Stream.
Both could provide an interface for openCL. But that would be like
running a JVM on a non-java-native hardware: a bit of loss of
performance is to be expected.
The last move from Ati was Mantle: an alternative to OpenGL & Direct3D.
Not sure Ati is interested in GPGPU.
Date: 28 Dec 2013 01:36:14
Message: <52be715e$1@news.povray.org>
I don't believe so - one of the reasons my next card will probably be an
nVidia card.
Jim
Date: 28 Dec 2013 06:04:46
Message: <52beb04e$1@news.povray.org>
Am 27.12.2013 18:33, schrieb clipka:
As an added note, I just learned that variant (A) can't be considered
safe anymore anyway.
Date: 28 Dec 2013 12:05:12
Message: <52bf04c8@news.povray.org>
It is; the original driver for my HD7600 came with software and
encouragement to participate on Folding@Home GPPU client or something
like that, to aid research diseases.
Date: 2 Jan 2014 03:14:14
Message: <52c51fd6$1@news.povray.org>
Several banks in the UK use a small battery powered card reader. When
you make a transaction you need to insert your bank card, type in your
pin, then enter the numbers from the website (usually the destination
account number and the amount). The card reader then displays an 8-digit
code to enter back into the web browser.
