I got to try the development version of Oculus Rift.
One slight problem I have ever had with "fake" 3D, eg. with 3D movies,
is that I don't easily get the impression of things coming "out" of the
screen (ie. closer to me than the screen is). To some degree yes, but
the closer the thing is supposed to be to the viewer, the less capable
I am of seeing it like that, for some reason. (Instead, it tends to
look blurred, even doubled.)
With the Oculus Rift, however, the impression of depth was just perfect,
no matter how far or, especially, how close the detail is supposed to be.
Even things that are like a few centimeters from your face really looked
like they were that close. Nothing looked like I had trouble focusing,
nor did I get any image-doubling problems.
(The Oculus Rift uses lenses so that you can focus your eyes to the
distance, and the image will look sharp like that. It would obviously
not work at all if it didn't have such lenses.)
The only problem with the development version is that it has a
ridiculously small resolution. The final version will apparently have
a full-hd 1080p resolution, so it ought to look much better.
I am actually eagerly awaiting for the final version to come out.
I really want to play games like Portal 2 with one. (Even if it turns
out to be just a temporary fad, a curiosity that's in practice unsuitable
to be used for long periods of time to play games eg. because it's too
straining, I think that it will still be cool enough to purchase, even
if it's expensive.)
I really hope that they do the smart thing in games that have direct
support for it, ie. that you don't turn by turning your head, but turning
your head just turns the "camera" (not the direction where you are pointing
at, ie. the direction that your weapon points to and where you walk when
you press the forward key.)
I was reading about Oculus Rift yesterday as Elite: Dangerous will
support it. The impression I got was that it will do the smart thing, as
you put it. Do you know if you can wear glasses with Oculus Rift?
The write up sounds impressive.
Regards
I don't know the details, but it might be that you don't need to.
(I don't know if the lenses will be adjustable, like those of binoculars,
or something else. I doubt you would be able to wear normal glasses
while wearing the device.)
... which rules me out
John (aka 4 eyes)
> John (aka 4 eyes)
Adjustable lenses rules you out?
Sorry. I misread your post.
John
it's no more fake 3D than your own stereoscopic vision
holographic projection is still way off so static stereoscopic recording is
still our best bet
still I indeed believe photorealistic 3D imagery plus Oculus Rift-like tech will
become much more affordable than holography
Am 17.12.2013 19:22, schrieb nemesis:
You're mistaken there: Depth perception is not only a matter of
parallax, but - at distances of <5m or so - also of focus.
If the Oculus Rift manages to provide a sharp image regardless of what
distance the eye tries to focus at, then that's a big win (and a
literally incredible feat).
It's quite lacking compared to actual 3D geometry because the eye can
discern distance also by how it has to focus on the object. None of
these technologies can (yet) distinguish where you are focusing with
your eyes, and modify the image accordingly.
I don't know why I have trouble seeing objects close to the viewer
in 3D movies (it's not *impossible*, but I have to make some effort
to make it happen) but it might be at least partially related to this.
Btw, given that 3D movies are being (AFAIK) published in BluRay format,
it seems that Oculus Rift would be the perfect way of watching them.
Significantly more immersive than just a 3D TV (because the field of
vision with OR is pretty large.)
It's not like it somehow senses where you are focusing, but the lenses
allow you to focus to the distance (even though the display is just a
few centimeters from your eyes.)
I don't know exactly how or why, but the depth effect was way better
than with 3D movies. Objects close to the viewer really looked like
being close to the viewer (something I have trouble getting in 3D
movies, as I have mentioned.)
Am 18.12.2013 18:10, schrieb Warp:
In 3D theaters you need to focus to the distance; it may be that the
Oculus gives you a clear focus somewhere in between (or you might be
adjusting it that way), as a trade-off between close & distant objects.
This is definitely the future, it's one of those things that you wonder
why it hasn't been developed sooner already. You have been able to get
1080p resolution displays for years that size, the optical principles
involved have been known for centuries...
I suspect it will have the biggest take-up in car and flight simulators
initially (I know iRacing already supports it natively). Those are the
guys who spend $$$ on multiple-monitor setups to get good FOV coverage,
if the full-HD production version is on sale for less than the price of
3 monitors then it's going to be a winner.
If it does take off then there are significant opportunities for further
development, thinner, lighter headsets, higher resolution/framerate,
wider FOV, wireless connection etc.
Am 23.12.2013 10:23, schrieb scott:
I guess it's because earlier attempts to get this flying proved
unsuccessful, so the industry put the idea aside.
I've been wanting one of these ever since back in the '90s. Seems like
the time is ripe for it at last.
Looking forward for Elite: Dangerous with that headgear. (Not that I
expect to be able to afford the Oculus; I might have to beg, steal or
borrow for it.)
I think that you are right, there.
In the 90's I saw people using them at tourist traps. It looked like
they were wearing "duck heads".
> borrow for it.)
I am with you there, too.
And I might need to review the specs for my new laptop.
Regards
True, I imagine the big players think it's too risky to commit any
serious resources to at the moment. Hopefully the OR will take off and
then everyone will be jumping to develop their own (better, cheaper)
version.
> borrow for it.)
Reading on wikipedia it is rumoured to be under $300, so hopefully about
the same price as a decent monitor. This is why I'm holding off
upgrading to a 3-screen setup for sim racing :-)
I spent all of last night reading about holographic displays.
[No, I do not mean volumetric displays. I mean a display where you
compute the interference patterns of an optical wavefront, then use some
kind of display device to produce that pattern.]
The big plus with this is that objects at different distances have
different focal depths - exactly like they do in the real world. The
machine basically generates the same light rays that the real object
would, so your eyes can respond to it the way they normally do already.
No weird glasses required. Multiple viewers possible. Etc.
The big downside is... you need an *insane* pixel pitch. And then you
need a small supercomputer if you want to draw this stuff in realtime.
I did see a demo of a commercial offering which is supposed to be coming
to market soon - but it uses eye-tracking to slash the amount of
processing power required. (I.e., it won't actually work in the real
world and so will never be commercially viable.)
A friend from university did this:
http://lightblueoptics.com/videos/holographic-laser-projection-technology/
Judging by the (lack of) recent updates it didn't really take off.
FWIW before this, his research project at university was to modify a CD
burner to burn holograms onto a CD. I guess the "pixel pitch" on a CD is
enough for it.
Yes, eye tracking always introduces further issues. One demo I saw,
which I'm surprised hasn't taken off, is to use the video feed from a
camera as an environment map texture. This demo was running on a laptop
using the inbuilt webcam and the way shiny surfaces reflected your face
and what was behind you in the room was very believable.
Indeed.
I also found a website with software for computing interference
patterns. They claim that if you take something like a 600 DPI laser
printer and print the pattern onto a transparency, you can shine a laser
pointer through it and get a very fuzzy, very grainy hologram. (Assuming
your printer doesn't try to interpolate or otherwise alter the precisely
computed pixel patterns!)
> enough for it.
CD? Perhaps not; CDs don't use visible light, they use infra-red, so the
dot pitch might not be small enough. A DVD, on the other hand, uses a
red laser, so it certainly ought to be able to do a red-light hologram
without difficulty. (Provided you can convince the drive to put the dots
where you want them!)
When I was at university, we were told that several companies had 3D TV
technology that was "nearly ready for market". That was ten years ago.
(I suppose they were probably talking about the laughably primitive
lenticular lens technology that you occasionally see in shops and stuff.)
Oooh that sounds interesting, might have to give that a go. I got one of
those cheap $20 green laser pointers, if you focus it it's enough to
light a match or melt your name into anything plastic :-)
Well if a 600dpi print just about works, then by my rough estimations a
CD should be about 20000 dpi. Maybe not perfect, but it works.
You can't without modifying the drive. IIRC they had to bypass pretty
much the whole signal path and just drive the laser directly (well not
quite, but you get the idea).
10 years ago the company I used to work for was already selling a laptop
and mobile phone with a parallax barrier 3D screen (that could be
switched between 2D and 3D mode). That technology has developed into the
dispay in the Nintendo 3DS and LG Optimus 3D today. That type of 3D is
fine for single-user applications (because no glasses are needed), but
for multi-viewer it obviously doesn't work.
Am 23.12.2013 15:14, schrieb Orchid Win7 v1:
There are even people out there who, using nothing but a compass with a
sharp tip, cut patterns into acrylic glass to produce simple
stereographic images (point clouds actually).
And yes, it appears to actually work.
You can often see holograms in the paintwork of cars on a sunny day, it
looks like an odd lens flare effect that is hovering some distance above
the paintwork. It is caused by poor washing technique which drags grit
across the paint creating tiny (but nothing like the wavelength of light
tiny) grooves in the paint.
Knock yourself out:
http://corticalcafe.com/software_onlineCGHinstructions.htm
They demo it with a red laser; I don't know if that's crucial. (The
laser wavelength is probably adjustable in the program...)
Yeah, I've been sat here trying to figure out what the actual DPI of one
of these disks is. I guess it requires knowing how many inches per meter
there are. :-P
Doesn't LightScribe help here? Or does that only allow you to specify a
grey level, which the device itself then dithers?
Am 23.12.2013 16:18, schrieb scott:
Yup, that's essentially the method they use for it - except that they do
it on purpose :-P
> Knock yourself out:
Bookmarked - will definitely try that. I wonder if an ink-jet will work
just as well...
> of these disks is.
I estimated 7e9 bits of data (probably an underestimate due to error
correction bits etc) and an area of 17 square inches. sqrt(7e9/17) is
about 20000 dpi.
Maybe, but you'd probably still have to hack the hardware significantly
to allow the lightscribe functionality to work on the data side of the
disc at a much higher resolution.
>> Knock yourself out:
> just as well...
I suspect you'll find it nearly impossible to convince an inkjet to put
the dots exactly where *you* asked for them.
>> of these disks is.
> about 20000 dpi.
...or you could just look up the pit width figure from the spec sheet,
and work out how many times that fits into an inch. ;-)
That sounds like just a firmware nudge to me...
