POV-Ray : Newsgroups : povray.off-topic : Adventures with WCF Server Time
4 Jul 2026 08:14:00 EDT (-0400)
  Adventures with WCF (Message 11 to 20 of 30)
Subject: Re: Adventures with WCF
Date: 11 Nov 2013 05:56:42
Message: <5280b7ea$1@news.povray.org>
> Ooo, I can explain this one for you:
>    The difference between C++ and C# is... they bare absolutely no
> resemblance to each other whatsoever!
Bah! - I think if I change some "." to "::", then save my code with .cpp
extension, and another copy with .hpp (after deleting out any actual
implementation of methods) I should be good to go :-)
Date: 11 Nov 2013 09:12:06
Message: <5280e5b6$1@news.povray.org>
>>> (Seriously. HTTP provides *nothing* which is useful for transferring
>>> transient data. It's just pointless overhead. What the hell is *wrong*
>>> with the world? *Why* must *everything* be kludged to work over HTTP
>>> these days? Sheesh...)
>> There are two reasons for this:
>> - Everybody and their grandmother knows how to handle HTTP. You don't
>> need to rewrite a custom interface to handle AndrewTP over port 31337
>> when you want to interface with the application. (Just dealing with the
>> XML parser is enough headaches already!)
> But this is *still* using XML - it's just that it's sending it on top of
> HTTP rather than over a raw TCP socket.
XML is a document formatting language.  Not a transfer protocol.  XML
does not do error handling, retransmits, keepalives, etc...  If you use
raw TCP sockets, you need to reinvent all those wheels.
>> - Firewalls
> This is not a valid reason.
Yes it is.
I'm not talkinf about hiding your application traffic inside of http
octet streams to bypass the security nazis.
In an entreprise setting. you need to do application layer parsing of
your traffic to ensure that, amongst other things, PII does not excape,
so using HTTP means that a third party firewall will be able to do deep
packet inspection out of the box.
Also, HTTP is very easy to proxify, so your application will work in
most entreprise settings, without having to resort to Socks, or other
forms of tunnels.
>> Then program a keepalive message at the application level.
> Right, so now I have to have a second thread sitting in the background
> with a timer, and I have to remember to reset that timer every time a
> command is sent, and then when the timer runs down, I send a null
> command and reset the timer... Surely all this boilerplate code should
> be in the framework?
> Seriously, when I used plain TCP, I didn't need to do this. The helpful
> framework is forcing me to do *more* work!
> (Well, technically it's not the framework's fault that Mono implements
> it wrong, but anyway...)
>> How does your client know the difference between the server processing
>> the request and the server having exploded in a firey ball of ones and
>> zeroes?
> No, this is the *server* not waiting for the *client*.
Well, it works both ways.  If your client got abducted by aliens (or
more likely, bluescreened)  How long do you sit there wasting resources?
What if I just decided to start 65536 sessions on your server and let
them idle?  Can you spell "Denial of service"?
You may not need this robustness in your isolated test bed environment,
but the makers of the WCF framework can't (or shouldn't) assume that no
one will ever release one of these apps into the wild.
>> Client/server apps are the same. If you want the communication channel
>> to remain open, you should program a keepalive
> This shouldn't be necessary. (And when it was plain TCP, it *wasn't*
> necessary, because TCP already implements this for you.)
As I mentioned in my previous message, there should be no relationship
between the TCP connection and the application session.  Your
application, over the course of a single user session, may need to
create and teardown multiple TCP sessions with the same server.  Or at
least, this would be the smart way of doing it.  You shouldn't have to
rely on TCP's limited error-handling to survive a network glitch.
>> and ideally an
>> erro-recovery mechanism where it will try to reconnect in case the
>> keepalive gets eaten by goblins.
> It appears to be impossible to tell under WCF when the connection has
> been broken.
In that case, the framework is rather flimsy.
>>> OK, so under Mono it appears to be _impossible_ to stop the server
>>> disconnecting.
>> At the risk of repeating myself... program an application-level
>> keepalive.
> The solution I eventually came up with was to connect, send one command,
> and then immediately disconnect. So now the program makes a new
> connection for every individual command. It's inefficient, but what else
> can I do?
Unless you plan on sending multiple commands in rapid fire, that's how
it should be.  Yes, you sent 6 more TCP packets per "command", but your
app is now much more tolerant of network glitches and doesn't waste
resources on either end of the communication channel waiting for a
client or server that is no longer there.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 11 Nov 2013 14:22:25
Message: <52812e71$1@news.povray.org>
You might also need to rename all your "interfaces" to pure virtual
classes. Oh, and C++ has multiple inheritance. And by default C++ has
value semantics not reference semantics. Oh, and if you try to return a
local variable as the result of a function, your code may segfault. Oh,
and...
Date: 11 Nov 2013 14:29:03
Message: <52812fff@news.povray.org>
> XML is a document formatting language. Not a transfer protocol. XML does
> not do error handling, retransmits, keepalives, etc... If you use raw
You send an XML document explaining what method you want to call. The
server sends back an XML document either saying it went OK, or
describing why it didn't. Provided you standardise the XML, you don't
particularly need anything from the transport protocol.
How does HTTP have any baring on this?
> forms of tunnels.
If you're trying to send commands and replies, the *last* thing you want
is some proxy caching it for you...
This is the fundamental problem with HTTP. It's designed to transfer
static documents, not ephemeral commands and replies. Sure, if you bash
it hard enough, you can just about make it work. But that's like saying
that you *can* use a vegetable knife as a screwdriver...
>>> zeroes?
> Well, it works both ways. If your client got abducted by aliens (or more
Until the test runner kills the client and the server.
There will only ever be one client.
OK, well that's fair enough. But let *me* configure how I actually want
the thing to work.
[In fairness, WCF *has* the capability to configure it the way I want
it. It's just that the Mono implementation is broken - it blatantly
ignores my configuration settings!]
I don't see why you would ever need more than one TCP connection -
unless you're actually trying to issue multiple commands simultaneously
or something...
>> been broken.
Indeed.
>> can I do?
6 more packets, each with a round-trip delay. A bunch more kernel-mode
calls on both sides. And the network layer just got a bunch harder to
debug. It works, but it's hardly an ideal solution.
(Hell, UDP would be better if that's your plan... But WCF doesn't appear
to support that.)
Date: 11 Nov 2013 15:17:51
Message: <52813b6f@news.povray.org>
Strange, given that probably at least 80% of functions do that.
Date: 11 Nov 2013 15:48:07
Message: <52814287$1@news.povray.org>
Am 11.11.2013 21:17, schrieb Warp:
No, not at all. Those 80% return the /value/ of a local variable. Big
difference.
Date: 12 Nov 2013 03:25:24
Message: <5281e5f4$1@news.povray.org>
> and...
Minor details, minor details :-)
Date: 12 Nov 2013 03:31:14
Message: <5281e752$1@news.povray.org>
>> and...
If you think the fact that your code can segfault if called with a
specific set of inputs is "minor", then... enjoy C++! :-D
Date: 12 Nov 2013 05:16:51
Message: <52820013$1@news.povray.org>
Oh yeh, C++ memories are coming back to me now, how you can be chasing a
bug for hours and finally realise that it's somewhere completely
unrelated overwriting a different variable's memory by mistake... :-O
Date: 12 Nov 2013 09:01:43
Message: <528234c7$1@news.povray.org>
How would you implement splitting the payload across multiple packets,
with a direct socket connection?  How would your server know the
difference between a malformed XML document with missing closing tags
and a missing packet?
How do you tell your server (or client) that there should be more data
coming?
How do you handle errors?
The answer is to reinvent XML wheels that already exist in HTTP.
Everyone knows how HTTP is defined, so it's easier to find the relevant
data in an HTTP stream, than in a proprietary protocol.
>> forms of tunnels.
I'm not talking about caching, I'm talking about relaying.  Most proxies
are indeed caching proxies, but their priamry function is to relay
traffic from one network to another network and keeping both networks
isolated.
You are correct, that there are more specialized messagin protocols out
there (most of them proprietary), such as IBM MQ-Series or TIBCO
Rendezvous, just to name them, that are more suited to handling
ephemeral commands, than HTTP, but most of the civlized world has no
problems whatsoever using HTTP (or more often HTTPS) to exchange data
between systems and even companies.
Since the makers of WCF do not know ahead of time what you will be doing
with their framework, they decided to pick the most widely used tranfer
protocol to make most of their users' life less miserable.
> the thing to work.
Well, the Mono project webpage fully acknowledges that their support for
WCF is limited.
> or something...
In your particular case, maybe, but you are using a general purpose
framework that is built for general use.
Let's say a travel agent is discussing various possible plane/hotel
combinations with a client.  She shouldn't "hog" a tcp socket open for
minutes while the client makes up his mind, nor should she have to
re-enter her credentials everytime she checks the availablity at another
hotel, or makes the final reservation.
In the background, the application would open one session and issue a
session ID, after having verified the user's credentials.  Then after
that, whenever the travel agent makes a query through her reservation
system, the client-side application would open a new TCP sessions,
include the application ID inside the payload and send one (or more)
commands to the server.  The server would send the reply and the TCP
connection would then close to leave resources available for the next agent.
