POV-Ray : Newsgroups : povray.off-topic : Mouth ulcers and chocolate Server Time
16 Oct 2026 22:34:10 EDT (-0400)
  Mouth ulcers and chocolate (Message 1 to 40 of 40)
Subject: Mouth ulcers and chocolate
Date: 23 Aug 2013 18:04:51
Message: <5217dc83@news.povray.org>
When you get a mouth ulcer, it makes sense that spicy and acidic foods
and drinks will hurt like there's no tomorrow.
However, one of life's little mysteries is that chocolate does that too.
It stings like hell. But why? Chocolate doesn't immediately come to mind
when I try to think of foods that would be especially irritating to a
mouth ulcer. What is it in there that causes so much irritation? Normally
chocolate feels so smooth and soothing, like silk. But to a mouth ulcer
it feels like sulfuric acid.
Subject: Re: Mouth ulcers and chocolate
Date: 23 Aug 2013 19:10:01
Message: <web.5217eaea918a91dc73fc9ebb0@news.povray.org>
I'm guessing it could partially be the theobromine, which acts as a vasodilator.
It might open up the blood vessels and cause swelling and irritation - the
opposite effect that caffeine has - which is a vasoconstrictor and reduces the
swelling in the brain so it's not grinding up against the inside of your skull
when you have a throbbing headache.
Chocolate is also known to contain oxalic acid, which I'm guessing is the main
culprit.  It will instantly combine with calcium in your blood to form
needle-shaped calcium oxalate crystals which produce an intense burning
sensation in the mouth.
Get some Anbesol, or see if some tea or coffee (tannins) will form a protective
coating over the affected area.
Date: 24 Aug 2013 04:02:16
Message: <52186888@news.povray.org>
Almost *any* substance will have the wrong osmolarity compared to body
tissues, so almost any substance hurts when poured into an open wound.
(About the only exception is suitably concentrated saline.)
The thing about chocolate is that it's very sticky; it coats things, and
clings to them. So once you get it into the wound, it's quite hard to
get out again.
(Fun fact: The bodily fluids of almost every large land animal have
almost exactly the same salinity as sea water.)
Date: 24 Aug 2013 06:55:27
Message: <5218911f@news.povray.org>
Am 24.08.2013 10:02, schrieb Orchid Win7 v1:
Fun fact #2: The above "fact" is anything but.
The origin of this popular myth is probably that it has been suggested
that the salinity of mammalian bodily fluids resembles that of the
/primordial/ oceans, back when life first evolved.
Today's sea water is about 4 times more saline than human blood.
Date: 24 Aug 2013 14:01:15
Message: <5218f4eb@news.povray.org>
This claim is surprisingly hard to confirm or refute. The trouble is,
there are many, many different ways to measure how salty something is.
Consequently, I'm struggling to find anything that quotes the two
measurements in the same units, or even using the same dimensions.
Regardless, I'm still waiting to hear why the hell the sea has *any*
salt in it to start with... I never did understand that part.
Date: 24 Aug 2013 15:42:03
Message: <52190c8b$1@news.povray.org>
Am 24.08.2013 20:01, schrieb Orchid Win7 v1:
A detailed per-element list can be found in this article:
http://www.answersingenesis.org/articles/arj/v3/n1/sodium-chloride-abiogenesis
See table 1 there.
Yes, that's a creationists' page, and the quoted paper appears to be a
creationist's, too, but I see no reason to doubt the numbers they're
quoting, as the general order of magnitude appears to match numbers from
Wikipedia:
(1) The salinity of blood can be inferred from that of medical "normal
saline" solution:
"The solution is 9 grams of sodium chloridre (NaCl) dissolved in water,
to a total volume of 1000 ml. [...]. It has a slightly higher degree of
osmolarity (i.e. more solute per litre) than blood [...]."
(http://en.wikipedia.org/wiki/Isotonic_saline#Normal)
(2) The salinity of salt water is given expressively:
"Seawater has a salinity of roughly 35,000 ppm, equivalent to 35 grams
of salt per one liter (or kilogram) of water."
(http://en.wikipedia.org/wiki/Saline_water)
Never heard of minerals being washed down by rain into the oceans?
Date: 24 Aug 2013 15:52:37
Message: <52190f05@news.povray.org>
> See table 1 there.
> Wikipedia:
Given the propensity of creationists to lie, distort and misinterpret in
order to promote their religion, that puts into question anything that
they write, even if they are just quoting facts.
I would avoid quoting even facts from that source, and instead quote them
from a more reputable one.
Date: 24 Aug 2013 16:29:36
Message: <521917b0$1@news.povray.org>
> Wikipedia:
> saline" solution:
So 35 g/L verses 9 g/L, basically.
[You see what I did there? Because blood is mildly basic, right? Right??]
I've _heard_ this suggestion, but since salt doesn't occur anywhere on
Earth except in the sea, that doesn't make a lot of sense...
Date: 24 Aug 2013 16:57:12
Message: <52191e28@news.povray.org>
Um what?
http://chemistry.about.com/od/acidsbases/a/aa110204a.htm
And:
https://en.wikipedia.org/wiki/Bonneville_Salt_Flats
Jim
Date: 24 Aug 2013 18:04:49
Message: <52192e01$1@news.povray.org>
Am 24.08.2013 21:52, schrieb Warp:
>> See table 1 there.
>> Wikipedia:
The same thing can be said about most scientific studies as well (except
that there it's not about promoting a religion, but the sponsor's
interests).
As long as it's plain, easily verifiable numbers, I see no reason to be
wary of creationists than of anyone else (as long as it's not the type
relying primarily on populism, but rather the one trying to give
themselves an air of serious science). After all, they have no interest
in making themselves too easily refutable.
I'd have prefered some other source myself, but either there aren't any,
or they're drowning in an overabundance of creationist sources. (Or I
just used the wrong search terms on Google.)
Date: 24 Aug 2013 18:06:42
Message: <52192e72@news.povray.org>
The Earth's crust has 2.6% sodium by weight, making it the sixth most
abundant element on Earth.
There's a relative abundance of chlorine in the seas because of how the
seas were formed and due to things like underwater volcanoes, which
release quite large amounts of chlorine.
Sodium chloride is soluble in water, unlike most other minerals, which
makes it significantly more prevalent in seawater than other minerals.
There are also complex phenomena happening that keep the balance of
seawater salinity.
Date: 24 Aug 2013 18:18:31
Message: <52193137@news.povray.org>
> interests).
*sigh*
That's precisely one of the most persistent lies that creationists spout
all the time (in order to try to give more credibility to their own
position.)
Why do some people swallow creationist propaganda without any kind of
fact-checking? Also, that claim makes absolutely no sense. What possible
interest woud these "sponsors" have to make scientist come up with
conclusions that are opposite to creationist claims? (For example, what
possible interest would these "sponsors" have in making scientist claim
that the Earth is billions of years old? That claim just doesn't make
any sense.)
The worst thing about all this is that creationists lie all the time
while at the same time claiming to uphold one of the cornerstones of
Christianity: Honesty.
I do because creationists are infamous for constantly cherry-picking,
distorting, quote-mining and outright fabricating data. If you want any
credibility for your data, don't take it from creationists. Take it from
a reputable source. It doesn't even matter if the data is identical; just
the fact that you are linking to a creationist website decreases the
credibility and trustworthiness. Link to some better place.
Date: 24 Aug 2013 18:20:27
Message: <521931ab$1@news.povray.org>
Am 24.08.2013 22:29, schrieb Orchid Win7 v1:
http://en.wikipedia.org/wiki/Seawater#Origin
Date: 24 Aug 2013 18:24:23
Message: <52193297@news.povray.org>
> *sigh*
> position.)
I apologize for snapping like that. It's just that creationists irk me
to no end. I have had lengthy conversations with young earth creationists
both online and in real life, and their insincerity and stubborness just
drives me crazy. They are exactly in the same league as the worst
conspiracy theorists.
Date: 24 Aug 2013 18:40:14
Message: <5219364e$1@news.povray.org>
Am 25.08.2013 00:18, schrieb Warp:
>> interests).
> *sigh*
> position.)
I don't consider it a lie, nor is it a position I have taken on from
creationists. Normally I don't believe shit of what they say.
> any sense.)
I'm not specifically talking about scientific studies related to the
creationism-vs-science debate, but generic stuff like whether iodine is
good for your health, whether the global warming is due to the decline
of piracy in the caribbeans, and other some such.
Of all those studies, I'm not necessarily buying their results, but I
see no general reason to distrust the numbers they present, as long as
they can easily be verified.
Ho - stop right there! To say that "creationists lie all the time" is an
oversimplification or, to put it differently, an outright lie.
/Never/ believe /anyone/ who oversimplifies things. (*)
Any suggestion in particular? Because if you don't have a better source
for the particular topic at hand, I'll stick to what people have come up
who happen to be creationists.
That applies to the numbers, mind you - not their conclusions.
(* To be applied recursively ;-))
Date: 24 Aug 2013 19:00:06
Message: <52193af6@news.povray.org>
Am 25.08.2013 00:24, schrieb Warp:
> Warp <war### [at] tagpovrayorg> wrote:
>> *sigh*
>> position.)
One simple recommendation:
Don't.
I mean, have lengthy conversations with them.
Their model of the world differs from any scientific model by the
inclusion of the fundamental axiom that their model is built on
irrefutable axioms (vs. the scientific fundamental axiom that /any/
model is inherently wrong, as it is just a model), so you simply
/cannot/ convice them, nor can they convince you (or so I hope ;-)), so
what's the point?
Date: 24 Aug 2013 19:19:43
Message: <52193f8f@news.povray.org>
I'd say that "creationists lie all the time" is more accurate of an
assessment than anything that creationists say about scientists, much
of natural sciences, and atheists.
Date: 25 Aug 2013 22:10:41
Message: <521ab921$1@news.povray.org>
>> interests).
> *sigh*
> position.)
> any sense.)
The problem here is that there "are" now paid shills (lots and lots more
of them than back when the people paying them thought science would
vindicate their ideas, not disembowel them), like Cato, and those
working for certain corporations/interests, who do both cherry pick
their data, and lie, to promote the positions they are *paid* to.
Unfortunately, unlike doctors, you can't pull a scientists license to do
research, even blatantly bad, or false, research. All you can do is
refuse to hire them at reputable institutions. The problem being, the
public isn't stupid, and they know they people exist, but they don't
know enough to tell which ones are presenting facts, and real evidence,
and which ones where paid to muck up the details, then present gibberish
to policy makers, or anyone else that decides to listen. And, the direct
result of this is that you are as likely to find people believing the
"experts" who are paid to push bullshit, as they are to believe the real
science. And, this is *especially* true when the bullshit a) will
protect their job, b) makes false, but, to them, believable, promises,
or c) is made out to be, by various similarly paid shill news agencies,
to be one of two options, and the difference between those a "controversy".
Just look at things like Dr. Oz, and Dr. Phil. Both are obvious quacks,
both promote things that are just plain nuts, Phil had his medical
license taken away, and I can't imagine that Oz will last either, given
his insane tendency to use aroma therapy, and who the hell knows what
else, as "part" of his surgeries. Not only is at least one of them still
working in his field, both have prominent jobs as spokesmen for things
that imho, should get both of them permanently banned from even
suggesting they know anything about medicine. And, neither even works
for a so called "think tank". Those, can also promote any bullshit they
want, but they *must* do so in a way that is actually believable, to
people that should know better.
Sometimes they are doing "applied science". And, here is the thing -
that doesn't generate new information, since its directed at getting a
specific result, and producing a specific end product, and they only
give a damn whether it works, or it doesn't, not what gets "learned"
from it. They also, in such cases, all sign NDEs, and rarely, if ever,
will the public ever hear "anything" from them.
So, yeah, if some scientist has a "sponsor", you might want to question
what they are doing, especially if they spend like 90% of their time
writing papers about other people's work, and not doing any actual
research. Such people are not, however, conducting science, they are
"marketing", while presenting the sale, to the buyer, as though it was
science. Creationists are only notable in that they do this, with a
absurd purpose of, on one hand, trying to use as much real information
as they can, without undermining their argument, they think, all so they
can prove that the universe was created by a being that, by definition,
didn't need to use science to do any damn bit of it. Of course, they
can't manage it without claiming that he did such and such X way, but
didn't do it Y way, and did so in a way we can't detect, even though we
detected it, and on, and on, while often claiming two contradictory
things in the same sentence..
Most real scientists never so much as speak to the public, even if they
work for some "sponsor" company, are more often than not pissed when
they find out how their results got misused (or just misinterpreted),
and/or are doing their research on the government dime, not on the
behest of private companies/interests. At most, some of them might work
for colleges, who got some money, from some private source, but.. those
people are not looking to "make up" results, they expect to actually do
the research, find a real result, and only report on the details, when
they actually know what the hell is going on, whether its "useful" for
someone or otherwise. They are most certainly not expect to "produce"
such results. The very idea presumes they already know enough about what
they are experimenting on to know the outcome, or how to believably fake
one. Which makes, logically, about as much sense as an explorer thinking
they can get by with "describing" a location no one has been to, without
bothering to actually go there and look, because, of course.. no one
else is going to either, right? lol
Date: 25 Aug 2013 22:41:04
Message: <521ac040$1@news.povray.org>
>> position.)
The man Paulin, who came up with the idea of "megavitamins" was Nobel
prize winner, at one point, but was considered, by the scientific
community to have become a complete bloody nut, by the time of his
death. In 1994 the bloody congress decided they would rather believe
him, than the FDA, about the possible dangers of massive doses of
chemicals being added to people's diets, purely due to them being "natural".
In the same time frame, another scientist put out "preliminary" results
studying anti-oxidants, which was, in part, touted by Paulin as a great
discovery, and helped him push his ideas. This was a "preliminary"
study, which every idiot from the press, to the new-age/altie-med
community took off with. A year or two back he released new results -
animals that had their own natural anti-oxidant production disabled
lived 25% "longer" than the ones who had it, and given them supplements
reduced there life spans back to normal. The conclusion - taking more of
them might actually kill you faster. Might, that is. Its still
"incomplete", but.. since all the idiots ran with it the last time...
Oh, wait, no.. they didn't run with it this time. Why? Could it be
because they are making more money selling crap, on the idea that it
will make you live forever, than they can by telling you to not buy it?
Nah...
You will note that Paulin was not a biologist, nor made any pretense at
it. He was a physicist and mathematician (sort of the engineer effect -
i.e, if your are an engineer, or physicist, you are like twice as likely
to be a total idiot about biology, biochemistry, or any other less
mathematical/well understood, and messy, science). He never did any
research, at all, just read a bunch of (and misunderstood) preliminary
studies, and took one bbbiiiiggggg leap with it. The guy who actually is
a scientist, never fell for the vitamin craze, and waited for the actual
results, and is still working on understanding what is going on. He
probably only released his second "preliminary" study on anti-oxidant
disabling to make some limited attempt to stop the madness already
generated by Paulin, and his absurdities.
There is a lot of total BS out there. And, the general public often
can't, especially when news programs, magazines, etc. refuse to fact
check their own reporting, which of it comes for people guessing, making
things up, misunderstanding the details of real studies, and writing up
total gibberish about it, or actually reporting real information. Worse,
the real information is often behind pay walls, or inaccessible to the
public, even if they could understand the studies any better than the
news people, or magazine writers.
Date: 26 Aug 2013 09:40:17
Message: <521b5ac1$1@news.povray.org>
Does this mean that the salinity of a Finn's tears will be less than
that of a colombian, since the salinity of sea water changes between the
equator and the 60th parallel?
Fun fact #2: We've all evolved from sea-dwelling animals who had to deal
with sea water's osmotic pressure for millennia, so there's nothing
really surprising about fun fact #1.
Fun fact #3:  It's also why you should boil seafood in salt water.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 26 Aug 2013 10:49:50
Message: <521b6b0e@news.povray.org>
It's actually quite interesting to study what kinds of morphological and
biological similarities we still have compared to our amazingly distant
fish ancestors from hundreds of millions of years ago.
For example, all terrestrial tetrapods (which includes us) have the
same basic limb bone structure: One bone (upper arm) -> two bones (lower
arm) -> a bunch of small bones (wrist) -> a group of long thin bones
(palm/fingers).
(In some animals the limb's end may have changed so that eg. a toe has
grown into a hoof, but the basic structure is still discernible.)
This basic limb structure can be traced all the way back to the fish from
which all tetrapods evolved from. (Our fingers used to be the bones in
the pectoral fins of that fish.)
Date: 26 Aug 2013 12:50:07
Message: <521b873e@news.povray.org>
There's a good reason why science does not rely on individual scientists
and individual experiments, but everything must be peer-reviewed and
tested again and again by numerous independent parties (preferably from
different countries and cultures) before such studies are even considered.
Creationists (as well as many other pseudoscientists) promote the notion
that the entire scientific community is in a huge conspiracy to endorse
certain views. Naturally they never go to specifics (because those could
be easily verified), but the way they talk it sounds like they think that
"science" consists of a secret core group of people who decide what the
current "scientific truth" is, and then everyone else just abides by their
rulings.
This is a physical impossibility. You just can't make the entire scientific
community believe in the same thing that's contrary to facts. Said
community consists of thousands and thousans of people from different
countries and cultures. Most of them do it because of personal interest
and passion, and nothing would be more rewarding then making a new
discovery or coming up with a valid objection to a claim. There's just no
way to control all the scientists of the entire world and make them keep
quiet about problems in current scientific theories and not publish those
objections.
For example, let's assume that there are indeed big problems with
radioactive dating methods. Why would, for example, scientists from
India or Japan keep quiet about them, and moreover perpetuate the alleged
lies? What possible motivation could there be (especially since there is
a lot more motivation to raise objections when they are found)?
Date: 26 Aug 2013 17:16:44
Message: <521bc5bc$1@news.povray.org>
> (palm/fingers).
In a way, that's pretty amazing. But in a way, it would be far more
amazing if all these animals did *not* have the same bone structure -
that would imply a sudden change in skeletal design, which is quite
unlikely.
Take a dog, for example. The part of a dog's leg that *looks* like an
elbow is actually homologous to the human wrist joint. The *actual*
elbow is hidden inside the dog's body where you can't see it. And the
thing that looks like an angle is actually our finger joint. It's whacky
stuff...
Date: 26 Aug 2013 17:57:50
Message: <521bcf5e$1@news.povray.org>
> objections.
Of course, this is exactly what they often claim, that "their"
scientists, who never seem to actually, you know, do research, instead
of just comment on their misreading of everyone else's, are the ones
"speaking out" against the vast conspiracy that all the other ones (who
outnumber them like 100:1) are "in on".
They are, often, also believers in the "Main Stream Media", which is
just incompetent and unwilling to check their facts, but fans of "FOX",
which has actually admitted to paying people to make shit up, and only
put out biased news, according to what their companies CEO wants them to
say (which just happens, right now, to coincide heavily with the
pro-corporation, anti-regulation, small government, pseudo-libertarian,
"Tea Party"...), as well as the truly loony one, which is that energy
companies, which, just in the last few decades have a) sat in rooms to
fix oil prices, while claiming that its pure coincidence they all meet
together, not intentional price fixing, didn't so much as speak up
about, and probably just figured on waiting to see what happened, during
the Enron, "Gosh, we have an electricity shortage, so lets kill people
by shutting down their 'heating/air conditioning/who the fuck knows what
else', during rolling blackouts, and have shown, twice that they can't
prevent spills, or clean them up, or even stop their pipelines from
leaking. Oh, no, those people we are supposed to believe, but not the
"scientific community", which is somehow looking to make "big money" by
promoting alternatives, thanks to global warming.
Its never entirely clear how *all* of those people, never mind any but
perhaps a small fraction, are supposed to get money from doing this,
but.. hell, its how their side does things, so, I am guessing that at
least some of the idiots on the denialism side actually believe its not
happening, and that everyone else, just like them, pays people with
degrees to make shit up, and lie, to promote some sort of business
interests, what ever the hell those might be. Looks at in that sense,
presuming they truly believe someone, some place, is making money off
it, and that all the experts on their side are getting kickbacks, just
like they do for their "own" experts.. Its perfectly logical. Its should
also imho, be a sign that every damn one of them needs to be
investigated for ethics violations, and their paid shills, for some sort
of clear conflict of interest issues (not that you could, since they
would just admit they where paid to make shit up, so.. no conflict, then
accuse everyone else of doing the same thing).
Date: 26 Aug 2013 19:07:51
Message: <521bdfc7$1@news.povray.org>
Am 26.08.2013 23:16, schrieb Orchid Win7 v1:
>> (palm/fingers).
> unlikely.
You mean, like the disconnection of the collarbone from the sternum in
felids, or the disconnection of the pelvis and complete disappearance of
hind limbs in cetaceans?
Date: 27 Aug 2013 13:20:19
Message: <521cdfd3$1@news.povray.org>
>>> (palm/fingers).
>> unlikely.
I was thinking more like if there was one member of the frog family
which has five legs instead of the usual four, or something. THAT would
be weird...
Date: 27 Aug 2013 16:59:20
Message: <521d1328$1@news.povray.org>
>>> (lower
>>> (palm/fingers).
>> unlikely.
In most of those cases the genes are still there, or the bones "grow
together", such that they seem to have disappeared, but haven't, or they
are in fact there, in some limited form, but just not obvious on first
appearance. Deletion of entire sets of genes, for a limb, and their
replacement with something else, instead of just adjusting the size and
shape, doesn't happen much.
Date: 27 Aug 2013 17:09:19
Message: <521d157f$1@news.povray.org>
>>>> (lower
>>>> (palm/fingers).
>>> unlikely.
> be weird...
Yeah, well.. That isn't likely to happen, six maybe, since you have the
whole bi-lateral symmetry thing going on, but then, you would find that,
much like "missing" ones, the extras are either a) caused by
environmental toxins (common issue with frogs in fact), or b) a copying
on the genes needed to produce the limbs. Whether or not, without other
regulatory changes, you can get "functional" ones is another matter.
Now.. toes/fingers are a different oddity. Their genetics function like
this: Start growing the index finger, then add another, and another,
until you hit a stop number, *then* grow a thumb. This means you can get
one less, or one more, finger, or even several more, if the timing got
way off (and it will end up next to the "pinky" when it forms), but its
not going to be common, since you would have to nuke "all" of the
fingers for the process to be interrupted. The thumb on the other hand
is a separate process, but dependent on the first set being formed, so
you could, in principle, have it be knocked out all by itself, by, in
effect, having the genes just "skip over" the code for it. But, it isn't
formed in the same stage in the process as the rest of the fingers.
Date: 27 Aug 2013 17:28:28
Message: <521d19fc@news.povray.org>
Genes are, ultimately, rather inefficient at "optimizing" an organism
to adapt to new or changed environments. Parts that are no longer needed
can linger on for thousands, if not even millions of generations.
Structures that still have important functions, but are quite inefficient
at doing those functions (when there would be much better structures that
could do the same job a lot better), may be retained likewise for millions
of generations, for the simple reason that they were there to begin with,
and a complete replacement by slow modification would require changes with
so astronomically low probabilities of happening, that they just don't
happen. Sometimes the vestiges of old organs may happen to be adapted for
new functions, but they will almost invariably be very inefficient at
those functions (which makes sense; they didn't exist for those functions
to begin with, and thus it's no wonder they are not optimal for a
completely different task.)
Evolution is all about compromises. The genetic code is very slow to
change in the right way to do something efficiently. It's more like a
hack job than anything else (it's like there's a "if it works, don't fix
it" principle constantly going on), and remnants of obsolete parts will
linger on, just because genetics can't just get rid of them that easily.
There's no guiding process to drop those off, and thus they will be built
because the genes say they should. There's nothing stopping them, even
after those parts become useless. Thus you get things like blind eyes
that are physically unable to see (in many species that live their whole
lives in darkness) and thus serve no useful purpose whatsoever. But the
useless eyes are still there because the genes say so, even if part of
the resources used to build them have been turned off or allocated somewhere
else.
When you really start to study how genes work, you start seeing that
there is, in fact, no intelligent design behind it. No intelligent
designer, no matter how incompetent, would be so sloppy and so lazy.
A mindless process that's simply the by-product of natural laws is.
On the positive side, genes are a marvelous example of emergent behavior
in nature. Complexity arising from simple rules.
Date: 28 Aug 2013 03:35:52
Message: <521da858$1@news.povray.org>
>> be weird...
During evolution, Nature does it the other way round. During the
Devonian when lobe-finned bony fishes appeared and evolved into
amphibians, Nature experimented with different possibilities. There were
animals with 7 or more numbers of digits on their legs. Eventually, only
the animals with 5 digits made it. All the others became extinct.
Search for Acanthostega, Ventastega and Tiktaalik.
Date: 28 Aug 2013 13:22:07
Message: <521e31bf$1@news.povray.org>
I'm sure a lot of people actually think that somewhere in your DNA is an
encoded number that says how long your femur should be, what speed your
heart should beat at, and various other technical data - you know, like
a man-made blueprint would have on it. If only scientists could work out
how do "decode" this information, we would then know everything there is
to know about the human body. (Or, indeed, any other organism...)
What *actually* happens is that DNA encodes the instructions for
building various different proteins, which - by a MIND-NUMBINGLY
INDIRECT series of steps - results in something that has a recognisable
form.
I guess it's a bit like an IFS. Take, for example, this famous example:
w 	a 	b 	c 	d 	e 	f 	p
ƒ1 	0 	0 	0 	0.16 	0 	0 	0.01
ƒ2 	0.85 	0.04 	−0.04 	0.85 	0 	1.6 	0.85
ƒ3 	0.2 	−0.26 	0.23 	0.22 	0 	1.6 	0.07
ƒ4 	−0.15 	0.28 	0.26 	0.24 	0 	0.44 	0.07
This doesn't describe any geometric shapes at all. It merely defines
four spatial transformations. And yet, iteratively applying these
transforms yields a strange attractor which looks strikingly like a fern
leaf... even though there's no fern coordinates here.
It seems likely that an *actual* fern probably works the same way...
Date: 28 Aug 2013 13:37:52
Message: <521e3570$1@news.povray.org>
I love the suggestion some people are making that maybe humans will
"evolve" to be less fat.
This makes it sound as if "evolution" is some magical process whereby
each time we reproduce, our DNA gets optimised to our situation, so that
as generations pass, everybody slowly improves...
No, this is not how evolution works. When you say "humans will evolve to
be less fat", what you're actually saying is "all the fat people will
die". Because THAT has how evolution changes stuff.
Of course, we have all sorts of government institutions set up
explicitly to PREVENT this mass death happening. Thus, humans will NOT
in fact "evolve to be less fat". Because there's no selection pressure.
Organisms only evolve to avoid stuff that kills them. If it's not fatal,
it doesn't get fixed. And since humans no longer live in an environment
where the weak perish and only the strong survive, evolution has little
or nothing to do with it.
(OK, correction: It doesn't matter if it kills you or not. It matters if
it stops you reproducing. Killing you is just the most obvious way to do
that...)
Date: 28 Aug 2013 14:55:48
Message: <521e47b4@news.povray.org>
Indeed, genes do not "try" to do anything. They just change slightly with
each individual that's born. Whether those changes will be retained and
widespread throughout the population (during the next few thousands of
generations) depends on lots of things, but mostly on whether it helps the
individuals with that particular change to have a slight edge over those
who don't. (Although sometimes a change can be retained even if it's not
particularly beneficial, as long as it doesn't decrease survival rates.)
Another thing that many people don't understand is that a change in a
gene can have several consequences. The one and same mutation can cause
several effects, some of them can be beneficial and others neutral or
even detrimental. However, it sometimes happens that the benefit is greater
than the harm, in which case the change may get preserved and spread to
future generations. This is often the source of genetic mutations that
seem detrimental and hinder survival rates. On their own they may seem
contrary to natural selection, but more often than not, it's simply a case
of the same mutation causing both beneficial and detrimental changes at
the same time.
I have been thinking that humans have evolved to a point where rather
than becoming better, we may in fact be becoming worse. Because of
progress in healthcare, nutrition, and all other kinds of things that
help people survive, all kinds of detrimental changes to our genes are
not being removed from the gene pool, which means that over time our
genes will become more and more trash. I'm expecting that as further
thousands and thousands of generations pass, the number of genetic
disorders and diseases will only increase in prevalence, simply because
there's nothing removing them from the gene pool.
Basically the only hope we have is if medical science advances to the
point that we can fix those genetic disorders, and our moral philosophy
advances to the point where we allow ourselves to do so.
Actually, for humans to evolve to be less fat would require
1) for obesity to be an inherited trait (that can change without causing
   ancillary side-effects that are worse), and
2) for people with this trait to never reach a reproductive age.
Not very likely to happen.
Date: 28 Aug 2013 15:20:28
Message: <521e4d7c@news.povray.org>
If anything, the only thing "deciding" what genes will go into the next
generation is YOU - when you decide who to **** with. ;-)
Again, just like a fractal. But then, if you look at molecular biology,
you discover that cortisol is a hormone, and also just happens to be a
neurotransmitter too - how random is that? That's like making a
telephone that's also a video camera - oh, wait...
That's the idea I get too.
I think it already is.
It is obvious that how fat you are depends on what you eat. But it is
equally obvious that some people have more of a tendency to retain fat
than others, or more of a drive to eat more. As with most things, it's
partly genetic and partly environmental.
Well, technically we just need them to not reproduce - either by dying,
or by failing to find a mate, or whatever.
But yes, I share your conclusion. Not likely.
Date: 29 Aug 2013 03:19:35
Message: <521ef607$1@news.povray.org>
> that...)
It isn't beyond the realms of possibility that fat people have fewer
babies (for medical and social reasons).
Date: 29 Aug 2013 03:21:50
Message: <521ef68e$1@news.povray.org>
And how active you are. Which both probably are linked to how your
parents behave. Does an "inherited behaviour" count as evolution of the
mind?
Date: 29 Aug 2013 12:23:58
Message: <521f759e$1@news.povray.org>
> mind?
There also is, from what I've read, a genetic component to it.  How the
body processes nutrients can vary from person to person - otherwise
there'd be a "perfect" diet that everyone could use (beyond "be
sensible", that is).
Jim
Date: 29 Aug 2013 13:24:13
Message: <521f83bd$1@news.povray.org>
>> mind?
I've read stories about how lab rats injected with certain hormones
gorge themselves on fat, while if you inject them with different ones
they prefer to feast on protein. It's entirely possible that there's a
genetic component to your dietary preferences - and maybe even your
level of physical activity. Like I said, I'm not suggesting that it's
ALL genetics; the environmental factors are obvious for all to see. But
I think there's certainly a genetic component to all of this.
Date: 29 Aug 2013 13:42:50
Message: <521f881a@news.povray.org>
And let's not forget, once again, that genes very seldom affect only one
thing. Most often they affect several things. People tend to think that
genes encode individual aspects of the human biology, and that you can
just "fine-tune" each individual aspect by tinkering with its correspondent
gene. But that's not how it usually works.
It's not impossible that the fact that our bodies tend to store all the
extra fat they can get rather than being "moderate" about it may be the
result of a gene that, if modified, would affect something else much more
negatively.
(Although it's also not impossible that "fixing" the obesity problem by
tinkering with the necessary gene could also have other beneficial
ancillary consequences. However, I would guess this to be unlikely
because if it were the case, it would have probably happened on its own
a long time ago.)
Date: 31 Aug 2013 03:18:21
Message: <522198bd$1@news.povray.org>
>>> be weird...
> Thomas
Think I covered that. You are talking about "digits", not "limbs". And,
yeah, you can change the number of digits trivially, due to, as I said,
them being coded so that you get, starting with the "thumb" as 0: build
1, then 2, then 3, then 4, then... either stop and build 0, or keep
adding on digits, until the "kill point", when the process stops making
new digits, and goes back to finish with what, for us, is the "fifth",
i.e., the thumb. The same code that allowed for 7 or more back then,
still works the same now. It just hits the "stop" point in the cycle
sooner. But, you can see from, for example, some cats, a case where you
get 6 toes. Same thing, it start with 1, then goes up to 5, before going
back to make '0', i.e., the analogous "thumb".
